Old Aug 28, 2006, 04:18 PM
WDP is offline
WDP
Find More Posts by WDP
WDP
Somerset, KY 42503
Joined Dec 2004
Parkzone F-27C Stryker 3S 11.1 V Balance Plug
Does anyone know what brand of balance plug fits the new Parkzone F-27C Stryker 3S 11.1 V Li-poly battery?
WDP is offline Find More Posts by WDP
Old Aug 30, 2006, 06:44 PM
bEbOp ? is offline
Find More Posts by bEbOp ?
bEbOp ?'s Avatar
Mile High City
Joined Dec 2004
I need an answer as well. The charger has 2 or 3 cell charging anywere form 300 , 500 mah , 1amp , 1.5 , or 2amp charging with balancing ability.
The plug for balancing a 3cell lipo has 4pins and Plugs in front of charger.
The plug for balancing 2cells has 3pins and plugs into the side.
Are these Balancing charger plugs the Industry Standard.?? Or are they propriatary to parkzone only???
What type of plug is that on the batt + and - ?
What type of balancing plug is that.? Thanks for your help, I hope I can use a wide rage of different name brand batts for charging.. It looks like Duskey 2 cell has a 3pin port that looks alot alike.
bEbOp ? is offline Find More Posts by bEbOp ?
Old Aug 30, 2006, 07:33 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Looks like the same balancing connector as used on the X-Power (Dual Sky) but wired exactly opposite. Appears to be wired the same as GraysonPower,Electric Power and some others.
Perhaps this photo will make it clearer.
http://www.rcgroups.com/forums/attac...hmentid=938947
The X-Power (Dual Sky) just plugs into this charger however some others such as the GraysonPower require an extension which reverses the connections.
See extension / adapters here.
http://www.rcgroups.com/forums/showthread.php?t=535274
A photo of the X-Power 3S balancing connector.
http://www.rcgroups.com/forums/attac...hmentid=730378
It is possible to move(rearange) the contacts in the connectors.
Charles
Old Aug 30, 2006, 08:49 PM
WDP is offline
WDP
WDP
Somerset, KY 42503
Joined Dec 2004
I have done a little research since I started this thread. I believe that the balance connector is a JST XH. I will know for sure in a few days. I have one on order and when it arrives I will make another post to confirm this. As for the main battery lead plug it is a E-flite EC3. Horizon Hobby has them listed on their web site. Just go to Horizon's main page and type in EC3 in the search box and it will bring up all of the EC3 connectors.
Old Mar 14, 2007, 10:01 AM
CaptEvo is offline
Find More Posts by CaptEvo
CaptEvo's Avatar
Joined Jul 2004
Charles, if GraysonPower is opposite with DualSky, then is it the same with CommonsenseRC?
I'm using CellPro and have CommonsenseRC adaptor to TP. Thinking about giving GraysonPower a shot
CaptEvo is offline Find More Posts by CaptEvo
Old Mar 14, 2007, 06:03 PM
The L is offline
Find More Posts by The L
Joined Sep 2006
I can confirm that itt has the same adapter that my Common Sense RC packs have, but it's wired in reverse.
I can charge it with my Common Sense RC balancing charger by plugging the balance connector on the pack in upside down.
The L is offline Find More Posts by The L
Old Oct 29, 2007, 11:48 AM
isvana is offline
Find More Posts by isvana
Random Flier
Oxford (UK) and Mtn View CA (USA)
Joined Nov 2002
Presumably per http://www.commonsenserc.com/page.ph...acks_info.html the new CommonSenseRC packs share the same balancer as the Parkzone batteries / chargers?
If so - great!
[Hmmm I wonder which CSRC pack fits a Stryker C?]
isvana is offline Find More Posts by isvana
Old Jul 04, 2008, 06:49 PM
mikekomm is offline
Find More Posts by mikekomm
mikekomm's Avatar
Los Angeles
Joined Aug 2002
Presumably per http://www.commonsenserc.com/page.p...packs_info.html the new CommonSenseRC packs share the same balancer as the Parkzone batteries / chargers?
If so - great!
Most guys are using our 15C - 2100mAh
http://www.commonsenserc.com/product...products_id=39
or our conservatively rated 20C - 2000mAh (outperforms most every 25C pack on the market)
http://www.commonsenserc.com/product...roducts_id=142
Our new 30C 2200mAh pack (coming out very soon) will fit as well for very high output motors in the Stryker.
www.CommonSenseRC.com
mikekomm is offline Find More Posts by mikekomm
Old Oct 02, 2008, 07:46 AM
Bob O is offline
Find More Posts by Bob O
Negaunee, Michigan
Joined Sep 2008
I have both Parkzone and Common Sense Li-Poly batteries, and they have the same balancer plug.
F-27B Stryker
HL-55 YaK
Spektrum DX-7
Bob O is offline Find More Posts by Bob O
Old Jan 28, 2009, 03:08 PM
parkpilot101 is offline
Find More Posts by parkpilot101
Grafton, Oh
Joined Jun 2008
Has anyone's balance wire/plug fall out, or is that just my problem.(2200mah)
parkpilot101 is offline Find More Posts by parkpilot101
Old Jul 26, 2009, 02:44 AM
ender707 is offline
Find More Posts by ender707
ender707's Avatar
Sacramento, CA
Joined May 2009
Same as Electrify
Most advanced Lipo chargers sell a different "balance charge" Board. Thunderpower, Electrifly, and several other brands have specific boards for their batts that are sold for different chargers.
Parkzone, Zippy, and Electrifly have the same plug. The board you would need is Electrifly, See crummy cell phone picture.
ender707 is offline Find More Posts by ender707
Old Oct 02, 2009, 08:12 PM
pphabu43 is offline
Find More Posts by pphabu43
Joined Sep 2009
All I want to know is HOW to launch F 27 Stryker! Heavy arm or short high start?
pphabu42@aol.com
pphabu43 is offline Find More Posts by pphabu43
Old Oct 26, 2009, 08:44 AM
golfdad2 is offline
Find More Posts by golfdad2
Bedford, Texas
Joined Mar 2004
I give my fun jut and stryker a good hard and fast throw about 45 degrees to the horizon at about 1/4 stick. Let it start flying before you give full power. They are a blast to fly
golfdad2 is offline Find More Posts by golfdad2
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion ParkZone F-27C Stryker blindman Parkflyers 7 Jul 01, 2007 04:12 AM
Discussion Parkzone F-27C Stryker LoneStarLegendRC Electric Plane Talk 3 Mar 30, 2007 09:34 PM
Discussion Multiplex FunJet vs ParkZone F-27C Stryker GaryB Flying Wings 8 Nov 19, 2006 12:19 AM
Discussion li-poly twenty (20c) 2100-3s 11.1 v Problem. abxalltheway Batteries and Chargers 9 Mar 29, 2006 09:34 AM
