Old Sep 03, 2012, 05:31 PM
luke352 is offline
Find More Posts by luke352
Australia, QLD, Ipswich
Joined Sep 2008
That bust is I believe very close to 1/4 scale it's probably about 1/4.5 scale and per the images I looked at what is shown is pretty close to the full size aircraft. But I did some more searching and it appears in the Model 12s (single seat) the pilot sits lower or the lower canopy line is higher, that or the guy who owns the real Python is a short ass, lol. At the end of the day I wasn't looking for perfect, just something to add a bit of character. To be perfectly scale the the canopy either needs to go forward further to enable a two seat setup or be shortened so as to match the single seat setup. I set up the canopy to simply a position with which I was happy with the line the canopy drew for the aircraft outline, end result is a nice line per my eye but a elongated single seat setup, hence if it was real my pilot would need rather long arms, lol.
These are the pics of the two seaters I was looking at.
luke352 is offline Find More Posts by luke352
Old Sep 04, 2012, 06:39 AM
luke352 is offline
Joined Sep 2008
Well finally started covering fuselage. Rear lower surface and sides completed.
Old Sep 04, 2012, 12:35 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
My Bad The Canopy I sent you would be long enough for a two seater. It needs to be cut to fit.
and I probably did not say anything.
If you look at the photo off the Beast you will also note how low the pilot sits.
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Sep 04, 2012, 03:40 PM
luke352 is offline
Joined Sep 2008
Dennis
It's all good i wasn't referring to the canopy you supplied. It was perfect for the job and as you say can be used for either a two seat or single seat setup. Just needs to be trimmed as required. Was referring to the length I ended up trimming it too, I just went with what looked good from an outline perspective which has ended up as a 1.5 seat length.
I might have to ask Kevin Kimball over in Krazy Karl thread on the FG forum about the pilot seat height in the single vs. two seat.
Old Sep 05, 2012, 12:33 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
I would be interested in knowing, let me know.
Dennis
Old Sep 05, 2012, 06:15 PM
JetTech is offline
Find More Posts by JetTech
more power=almost enough
JetTech's Avatar
USA, ID, Boise
Joined Sep 2003
Well regardless of what/where the pilot sits, I like your plane and cockpit. I can't wait to see the finished results.
The weather here is finally starting to cool off some in the mornings so I am excited to get out and fly again. I am planning on going out this Saturday morning. Getting batteries charged up as I type this..... Whoohoo!!
The only consolation to not being able to fly is that it has made more time for fishing, and fishing has been awesome. Just went to Silver Creek again yesterday Dennis. This is no fish story I caught well over 25 fish yesterday.
Kerry
JetTech is offline Find More Posts by JetTech
Old Sep 05, 2012, 07:49 PM
kjkimball is offline
Find More Posts by kjkimball
Custom airplanes and boats
Zellwood, FL
Joined Aug 2010
The seat design is the same in all the model 12 fuselages. The carbon seats we make are the same or the single seater and the 2 seater. The canopies are exactly the same shape at the front of the turtle deck. The edge of the canopy along the sides of the cockpit are exactly the same height. Turtle deck is exactly the same on both versions. The differences I see in the photos you show are pilot size and with or without helmet. Bryan was over 6ft tall and a big guy. Some of the others are smaller. Some like to sit low and some high and can use 2" or 3" seat cushion as they see fit.
Kevin Kimball
kjkimball is offline Find More Posts by kjkimball
Old Sep 05, 2012, 08:32 PM
luke352 is offline
Joined Sep 2008
Kevin Kimball
Thanks Kevin! Didn't even realise you were a member over here as well.
Old Sep 05, 2012, 08:41 PM
luke352 is offline
Joined Sep 2008
Kerry
Was just going back through the thread and realised your pilot is the same as the one I was going to fit but my wife didn't like it, lol! So I got my current figure which is supposedly the same scale but in reality he is a bit smaller, my wife still doesn't like my current one she just doesn't dislike it as much, so that meant he's fine in my books.
Old Sep 06, 2012, 01:44 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
thanks for stopping in Kevan
Luke you are one wise person, It is the wives job to make the rulls, it is the mans job to know the rules and the wife may change the rules with out prior notice.
Dennis
Old Sep 07, 2012, 08:03 AM
luke352 is offline
Joined Sep 2008
Dennis
HAHA.
Well current covering progress below.
So far the fuselage is coming in at 2.75 lbs as it sits there. All 4 wings come in at 2.2lbs without servos. I'm pretty happy with that.
Old Sep 08, 2012, 07:05 AM
luke352 is offline
Joined Sep 2008
Today's effort, I fitted the fin and fin supports and worked on the covering. You can see how the stripe meets up with the fin leading edge, the idea was to give the impression it continues up the fin. I'm thinking of doing a stripe down each side aswell that meets up the Leading edge of each stab side. But a bit worried it might be a bit too much.
Old Sep 08, 2012, 10:25 AM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
I used Krylon spray paint to paint the cabaines to match the covering, they have very close to the red.
That is going to be a good looking plane
Dennis
Old Sep 12, 2012, 11:42 PM
luke352 is offline
Joined Sep 2008
Dennis
I don't believe Krylon is available in available in Australia, but i'm sure i'll figure something out. I had considered using heat shrink on the cabane struts if I could find a reasonable match.
My next question would be you mentioned not requiring any support struts for the stab, I'm a little concerned as the balsa that came from the laser cutter was a bit on the soft side for the stab. So i'm considering making up a support strut for each side of the support strut using some carbon rod.
Old Sep 13, 2012, 07:22 AM
luke352 is offline
Joined Sep 2008
Elevators and associated control linkages fitted. The elevator horns are almost exactly the same length from hinge centreline as the servo arms ensuring good resolution whilst maintaining plenty of throw.
does anybody know how to remove topflite econocote from foam flyer10 Beginner Training Area (Aircraft-Electric) 2 Feb 12, 2007 01:24 PM
Video 36'' balsa Pitts Python Dennis C Electric Plane Talk 2 Nov 12, 2006 11:02 PM
Pitts Special from 2" foam...Photos BQuick Foamies (Kits) 9 Oct 13, 2003 06:51 PM
Python from Ezone mrittinger Electric Plane Talk 28 Jan 23, 2002 04:26 PM
