Apr 04, 2012, 07:32 PM
Australia, QLD, Ipswich
Joined Sep 2008
Yeah I noticed on these thicker parts it almost seemed like the laser was out of alignment slightly as if it was on a slight angle. But I figured it was actually due to the laser removing slightly more material at top of cut vs. bottom of cut. It's not a big issue, I've just been tacking any joints with a gap using thin CA and then filling any remaining gap using medium CA, seems to be working quite well.
If you felt like going over your CAD files again it may be worth slightly narrowing the sections where the the cross braces sit into the outer frames on the tail pieces, as it's probably easier to remove a bit of material on your cross piece than adding CA to fill any gaps.
Anyway here is a pic for size comparison, also the canopy, L/G and cabane struts that showed up in the mail from Dennis yesterday.
