Old Aug 28, 2006, 12:11 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Pitts Python from foam to balsa
Ultimately you may have guessed that I have a love affair with biplanes, but since the ultimate has or will be done
( hurry up Setevens Aero) I decided to do a Python.
Tim Hart AKA foamy factory started a thread on his foamy Python and I copied the full scale 3views to make a prototype Lengthend the fuse and enlarged stab and rudder,for #1 and then movaed the wing and stab for #2 to help with C.G. and flying, the foamy flew so well that I decided to start a balsa model
36'' wing spand and 475 sq''
http://www.rcgroups.com/forums/showt...=8#post5978537
Here are the foamys, and a link to Tim's foamy thread
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Aug 28, 2006, 12:12 PM
dpoles is offline
Find More Posts by dpoles
Crash and Build
dpoles's Avatar
United States, NY, Ithaca
Joined Oct 2001
link?
dpoles is offline Find More Posts by dpoles
Old Aug 28, 2006, 12:15 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
Sorry Had to go back and find it
Dennis
Old Aug 28, 2006, 12:32 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
the flight and landing loads will be carried by an inner box, balsa stringer reinforced with carbon fiber
Dennis
Old Aug 28, 2006, 12:40 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
the cowel is big, 5'' diameter. the cowel rings are 1/8 light ply, I used depron to hold everything square while the balsa stringers were attached. it is covered with 1/32 balsa and will get a covering of light glass cloth attached with polyurethane. after glassing the cowell will be split in half to provide acces for battery instalation
Dennis
Old Aug 28, 2006, 12:43 PM
dpoles is offline
Crash and Build
dpoles's Avatar
Joined Oct 2001
sweet!
Old Aug 28, 2006, 12:45 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
the nose of the cowel is 1 1/2'' sq light!! balsa. I attached it to a plywood ring and used a drill press to turn and sand it to shape, it weighs .7 oz
Dennis
Old Aug 28, 2006, 01:00 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
rudder and elevator curved shapes are made up of 4 layers of 1/16x3/8'' balsa laminated into bow. I used depron foam to make the form and hot! water to soften the balsa to prevent splitting, heald in place with rubber bands untill dry. glued with thin Ca.
Dennis
Old Aug 28, 2006, 01:04 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
finished cowel
Dennis
Old Aug 28, 2006, 01:10 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
formers are set on the outside of the fuselage box to creat the finale shape of the fuselage. 1/8''sq stringers as longerons. the frount of the fuselage and turtle deck will be covered with 1/32'' balsa
Old Aug 28, 2006, 01:14 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
on the wheels to get a hint of what it will look like
Dennis
Old Aug 28, 2006, 07:21 PM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
now THAT is SWEET! if u decide to kit this i would love one!
MustangAce17 is offline Find More Posts by MustangAce17
Old Aug 28, 2006, 07:30 PM
JetTech is offline
Find More Posts by JetTech
more power=almost enough
JetTech's Avatar
USA, ID, Boise
Joined Sep 2003
Dennis,
Well brother you keep building beautiful planes. And all this without cad or laser cut stuff........ very impressive!!. Just like the "old" days huh? Not saying anything about your age there you understand. *grin* It looks beautiful so far. You might have interested me in another bi-plane again with this one. Looking fwd to seeing this one through to completion. Now, hurry up and build it will you.
Kerry
JetTech is offline Find More Posts by JetTech
Old Aug 28, 2006, 09:24 PM
RMS is offline
RMS
Find More Posts by RMS
RMS
RMS's Avatar
Westport, MA
Dennis,
You probably already know this but you can really soften the balsa with amonia or windex....it's not hot either and it is faster acting.
RMS
RMS is offline Find More Posts by RMS
Old Aug 29, 2006, 03:50 AM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
Very nice!
Using a section of 1/2 or 3/4 inch pvc pipe with one end capped is a good way to soak long strips of balsa.
Dylan
Dylwad is offline Find More Posts by Dylwad
does anybody know how to remove topflite econocote from foam flyer10 Beginner Training Area (Aircraft-Electric) 2 Feb 12, 2007 01:24 PM
Video 36'' balsa Pitts Python Dennis C Electric Plane Talk 2 Nov 12, 2006 11:02 PM
Pitts Special from 2" foam...Photos BQuick Foamies (Kits) 9 Oct 13, 2003 06:51 PM
Python from Ezone mrittinger Electric Plane Talk 28 Jan 23, 2002 04:26 PM
