Old Aug 27, 2006, 04:25 PM
jnm2512 is offline
Find More Posts by jnm2512
Big Island, Hawaii
Joined Jun 2003
Any Tips on Removing Epoxy from Covering Film.
Hello, Recently joined two wing half's on my Hanger 9 Corsair which required using tape while setting up. A slight amount of dried West Systems Epoxy was left on the wing after the tape was removed. I have tried acetone and lacquer thinner with no success. Any suggestions would be appreciated.
Thank You,
John
jnm2512 is offline Find More Posts by jnm2512
Old Aug 27, 2006, 05:27 PM
VillagePerson is offline
Find More Posts by VillagePerson
Tao Jones industrial ave.
Wisconsin, USA
Joined Apr 2005
Epoxy is resistant to solvents. Probably the only way to remove it is by sanding, grinding or chipping. Well, you could burn it off but this would damage your wing too.
VillagePerson is offline Find More Posts by VillagePerson
Old Aug 27, 2006, 06:28 PM
Karl Bē is offline
Find More Posts by Karl Bē
29 rods from you in western WI
Karl Bē's Avatar
Joined Jan 2003
When this has happened to me, I simply picked it off with a razor blade tip. Be careful not to scuff or cut the film.
Karl Bē is offline Find More Posts by Karl Bē
Old Aug 28, 2006, 12:20 AM
jnm2512 is offline
Big Island, Hawaii
Joined Jun 2003
Thanks for the tips. i will gently try using a razor blade.
JM
Old Aug 28, 2006, 12:26 AM
papa38 is online now
Find More Posts by papa38
Recovering nitro addict
papa38's Avatar
Everett,Washington
Joined May 2005
yep, #11 exacto, and VERY CAREFULL Kinda put some tension on it, and hold it, and the glue will pull off slowly.
papa38 is online now Find More Posts by papa38
Old Aug 28, 2006, 12:32 AM
LBMiller5 is offline
Find More Posts by LBMiller5
Use the Force!
LBMiller5's Avatar
San Marcos, CA
Joined Jan 2005
Actually, vinegar will soften epoxy. The acetic acid in the vinegar breaks down the epoxy and causes it to get into a rubbery state, kind of like stiff Jello. If you put some vinegar onto a cotton ball and let is sit on the epoxy for a wile, it will soften, and you can scrape it off with your finger nail. Just be careful and don't let it seep down into a joint, or it can soften that epoxy as well.
Lucien
LBMiller5 is offline Find More Posts by LBMiller5
Site Sponsor
Any tips on building my new Vortex CC? WilliamSettle High Performance 20 Aug 15, 2005 01:55 PM
Any Tips on the Esprit 2 from NE Sail? Blue Sky High Performance 2 Aug 11, 2005 07:43 PM
Any tips on flying a Soarstar for the first time? f2racer Beginner Training Area (Aircraft-Electric) 3 Sep 07, 2001 08:55 PM
Got my Soarstar, any tips on how to build? f2racer Foamies (Kits) 2 Sep 06, 2001 10:56 PM
Any word on that T72 from JKA ????? William A Foamies (Kits) 1 Jul 30, 2001 10:25 PM
