Old Aug 27, 2006, 03:53 AM
electriceye is offline
Find More Posts by electriceye
Kiss the Sky
electriceye's Avatar
Dorking, Surrey, UK
Joined Jul 2006
New F-16 build-This should be on H-J's F-16 Thread
Hi Hans,
Just to show my progess so far-Excuse photo quality but I used my phone to take the pics. Please note I have used 6mm depron for the inlet/main part of botton of fuselage for strength but to keep wieght down and to compensate I have removed small sections of the fuselage 'spine', centre of formers etc, also I will try and use 2mm depron for most of the upper fuse skin. Due to the strength of the 6mm depron (I formed the shape using heat gun) no formers were necessary and it has made the model very rigid.
Next challenge is the cannopy!! It looks like you incorporated a little anhedral on the rear elevators on your first T'Bird F-16. Is that correct or didn't you bother? Would putting anhedral (I hope that is correct term for the downward angle of elevators?) affect handling adversly or at all, or is it not worth the effort anyway? Thanks for giving me the inspiration to attempt this design.
electriceye is offline Find More Posts by electriceye
Old Aug 27, 2006, 05:27 PM
3dflyindan is offline
Find More Posts by 3dflyindan
PB #2212
London, England
Joined Dec 2005
nice and big lol
dan
3dflyindan is offline Find More Posts by 3dflyindan
Old Aug 28, 2006, 02:45 PM
Hans-Joachim is offline
Find More Posts by Hans-Joachim
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
Cool! Ive used 6mm Depron on the botton of the fuselage from F-16C, No. 3
for the minifan480 and mega 16/15/2. The use of a heat gun works very good.
Im forming the 3mm depron under hot water (~60C/~140F).
HJ
Hans-Joachim is offline Find More Posts by Hans-Joachim
Idea Mr. Lin this should be your next plane to built the F-35 Lightning II wedge98 GWS (Grand Wing Servo) 7 Feb 03, 2007 05:15 PM
My latest f 16 Parkjet, BL should be a screamer!! pipsta Pusher Prop Jet Models 5 Nov 16, 2005 03:21 PM
F-16 Falcon Flying Styro kit on EBAY, Cheap! Arthur_GA Aircraft - Electric - Airplanes (FS/W) 0 May 01, 2003 04:11 PM
Anyone know offhand where the CG should be on a GWS J-3 Stick? mefly2 Parkflyers 2 Apr 17, 2003 08:32 PM
What prop should be on this ZAGI? snowman610620 Foamies (Kits) 1 Feb 22, 2002 06:42 PM
