Old Jan 05, 2008, 12:42 AM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
stock stryker on 4s and 4.7 x 4.1 gets 94.7 mph and 18.9 oz thrust at 12 amps
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Jan 05, 2008, 08:06 AM
rtn9105 is offline
Find More Posts by rtn9105
Joined Jul 2002
Thanks for the info. That sounds like the way to go for now. I've also been considering picking us some A123 cells and building a 3 cell pack to try. Has anyone else used those cells in the Stryker yet?
rtn9105 is offline Find More Posts by rtn9105
Old Jan 05, 2008, 06:35 PM
eckace1 is online now
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by gotboostedvr6
looking for a quick reply....
sorry if off topic but
http://www.unitedhobbies.com/unitedh...idProduct=5223
good for stryker or no...
im currently runnning a 1600kv 25 amp on 4s and would like to run this on 4s for extra speed.
ill also use a 50 amp tower speed control
Seems very heavy for only 260watts 123g as you can get a 32g out runner same watts.
eckace1 is online now Find More Posts by eckace1
Old Jan 05, 2008, 06:55 PM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
You know of a 32g outrunner that can do 260 watts reliably?!
JWilliams2 is offline Find More Posts by JWilliams2
Old Jan 06, 2008, 06:58 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Easy with a micro dans 2505 speed motor www.gobrushless.com Robert
Old Jan 06, 2008, 07:17 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
outrunners are always lighter no? plus that inrunner has heat fins
Old Jan 07, 2008, 02:17 AM
Sirius35 is offline
Find More Posts by Sirius35
Saint-Méen le Grand (BZH)
Joined Jan 2007
this is mine
Parkzone F27B Stryker - Vol du 26 décembre 2007 (3 min 38 sec)
using a little screamer parkjet... i'll looking to use an inrunner HXT 2445 and next a LS Super Parkjet
Sirius35 is offline Find More Posts by Sirius35
Old Jan 07, 2008, 12:10 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
why don't you guys try Justgofly's line of outties?
really powerful for a good price, i was using a 400DF on my stryker and it proved itself to be a very competitive motor against the megas i was flying with
brian94066 is offline Find More Posts by brian94066
Old Jan 07, 2008, 12:15 PM
Sirius35 is offline
Joined Jan 2007
an other flight with onboard flycam
Caméra Embarqué - Parkzone F27B Stryker (4 min 34 sec)
Old Jan 07, 2008, 04:49 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
maidened my medusa powered stryker today
didn't really get a chance to open her up since the wind was pretty violent today, i did get to vertical a few times, and boy was i happy, half throttle, and it shot straight up!
gotta adjust the thrust angle on the motor, i need more downthrust
Old Jan 10, 2008, 11:37 AM
daddiozz is offline
Find More Posts by daddiozz
foamie re-cycler
daddiozz's Avatar
United States, WV
Joined Nov 2004
Originally Posted by FoamCrusher
Goop! (or any silicone sealer - the GE white bathroom silicon caulk is the same color as the white foam) Sticks very well and remains stiff but flexible - better than CA that is ridged. It only takes a thin coat to hold the foam and that's good because it is heavier than CA (but lighter than epoxy).
FC
since the only parts that truly need gluing on the stryker are the motor mount and (optional) elevons, I use hot glue ...set up time is usually less than a minute and its easy to remove if you put on too much or need to make an adjustment
daddiozz is offline Find More Posts by daddiozz
Old Jan 10, 2008, 12:14 PM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
That is what most of my planes are powered by.
As well is my Stryker...
500th 3300kv 3s 2100mAh with a 5.5x2.5 prop.
Stryker Video Link
I do have a New 550 size that is faster...But no video yet...
TaSaJaRa is offline Find More Posts by TaSaJaRa
Old Jan 10, 2008, 12:24 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
I also used a little hot glue..... I put a small bead around the base of the vertical fins to make sure they stayed in place.
Old Jan 10, 2008, 06:43 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
OFF-topic
Welcome back craig!
Old Jan 10, 2008, 07:07 PM
e2346437 is offline
Find More Posts by e2346437
Crash Test Dummy
e2346437's Avatar
United States, ME, Mapleton
Joined May 2005
Did anyone find a United Hobbies motor yet that would work for 100mph+?
e2346437 is offline Find More Posts by e2346437
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
