Phoenix, Arizona
Joined Jan 2005
here you go. There are 2 parts. If you scroll down you will see pt.2
They are having too much fun from the sounds of their laughs. |
Joined Mar 2006
I bent the motor shaft a little and now the vibration of it being unbalanced blew two props apart while flying and completely destroyed the motor mount. Is there any way to straighten it out again? I would hate to have to buy another whole new brushless motor.
Kalispell, in the Rocky Mountains
Joined Jul 2006
If you end up snapping the shaft, and the Mega shafts are hard and brittle and will snap ( ), you can send the motor back to Mega Motors USA and for $40 they will replace the shaft. They send it back to CZ so it takes about 4 - 6 weeks, but it comes back as good as new. Medusa will do the same - other brands and you may be out of luck. With some motors you can use CA de-bonder and unglue the shaft enough so it can be pushed out of the magnets. Then you have to find some drill rod and make a new shaft, push it back in and reglue with green Loc-tite. It's better to not break them in the first place - tap gently Quote:
FC |
The Stryker will high alpha even better when inverted because the fins are now below the CG point. What is also a neat move to do with the Stryker on a windy day is to make sure your CG is set to almost neutral and head upright into the wind, gradually backing off the throttle and increasing the up elevon. As the plane gets to under about 3 mph, kill the motor and go quickly to full up elevon (high rates) and hold it. The plane will stall, lose its forward motion and fall flat without spinning or falling off to either side - it just drops straight down like a Jump Jet landing, although you have no control over the speed or direction - gravity takes over and it just falls out of the sky. Again, the CG has to be very close to neutral for this to work. It is a nice safe way to land on a very windy day. FC |
Joined Jul 2006
"can I replace the stock 6X4 prop and not fry my plane."
this for the C model? if so, you should be able to. to tell you the truth, i can't find a better prop than the apc 6x4e. actually, i did try a 6x5.5 last week on my mega 16/15/4 vs my friend's C model. his was faster but i also think my battery didn't have a full charge (being the first flight of the day and all... i was rushing to get in the air). our last flight of the day was pretty close but i had switched back to the 6x4 by then. we would have tried again but he nailed the ground pretty hard and i broke my second motor mount for the day. he's got the C model's mount so he must have hit pretty hard to snap it. my lesson for the day was that soccer goals don't duck when you're going to hit them. if not for the bright orange duct tape my wing would have surely been snapped off. err... yeah, i think your motor and esc can handle it if you're using the C model: http://www.e-fliterc.com/Products/De...rodID=EFLA1025 25amps.... |
Joined Jul 2006
Boom
Well my tenth flight had my first major crash. I was just cruzing aound, did some no power rolls, a few stalls and was setting up for a low altitude high speed pass. As I was flying about 5ft above the trees, I hit full power. A second later a updraft from the hill the trees were on caught the plane by the tip of the wing rolling it over, the tip of the fin barely nicked a branch befor sending it cart wheeling across the trees, I tryed to get the plane as far away from the tops as posible befor it finaly nessled itself into a small tree. It was up there about 30ft... compared to 40ft. Well like I said it was a small tree (as in skinny) and for a 15 year old I was quite big (185lbs). Luckly I was flying on full battery so I had some time. Lesson learned, never climb a tree with no way to get yourself or the plane down... Well I did, anyway the Stryker lost the tip of one wing, and had serveal scrapes, and marks thoughout the whole thing. It was all cosmetic, so then I adjusted my trims a bit, and tosed her into the air again. Now that the stock paint job has taken one to many scuffs, I am thinking about my own paint job
Phoenix, Arizona
Joined Jan 2005
Thats what I get for trying an upsidedown fly by at a too steep of a angle of attack. I have anothe plug in the garage. But that hurts.
| Thread Tools | |
| Discussion Parkzone F-27C Stryker | That can fly?!? | Parkflyers | 109 | Sep 26, 2012 10:54 PM |
| Discussion Parkzone's New F-27C Stryker | itspat | Parkflyers | 1 | Nov 08, 2011 07:56 PM |
| Mini-Review F-27C Stryker Review | That can fly?!? | Parkflyers | 27 | Jul 29, 2010 08:25 PM |
| Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug | WDP | Batteries and Chargers | 12 | Oct 26, 2009 08:44 AM |
| Discussion Coming soon! F-27C Stryker RTF with lipo and brushless | Solcat | Electric Plane Talk | 0 | May 31, 2006 12:34 PM |
