Old Jul 03, 2010, 01:56 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Could I suggest that you "paint" the groove with epoxy before you install the CF, then wet the CF with the epoxy, then install the CF and wipe off the excess with a credit card or a business card ?? Let her sit for several days before you even breathe on it. ???
Skip NO steps
Do NOT deviate from the above and you will have a well bonded CF stiffner.
moparmyway is offline Find More Posts by moparmyway
Old Jul 03, 2010, 03:54 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
With C.F. Strips I can do a very clean job of C.F. install.
See the (3) CF running left to right. Those were installed with epoxy unlike the replacement CF tube where I used Gorilla glue.
To keep the flat C.F. Strips that clean is a huge pain in the butt but it is do-able, time consuming, uses a bunch of paper towels and some Isopropyl Alcohol, and regular packing tape....each short section/span gets those used on it over and over and ....over.
C.F. tube can never come out that clean looking. There are times where C.F. tubes must be used. There are places where C.F. tube must be used.
***When/if you guys see CF. Strips that are as wide as our wing span (well over 24"); buy as many as you can while you can. (usually at large fly in events).
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jul 03, 2010, 04:38 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Mopar and Gryphon:
Very impressed with the effort you are putting into this!!!!!!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jul 03, 2010, 05:50 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
[QUOTE=moparmyway;15459207]......You can use whatever epoxy you like, I find "Z-Foam" finishing epoxy to be perfect for appearance coverings. It will slightly discolor your paint, but when it cures..............you get a VERY slick surface. This brings up a great point. Strength is something different from looks epoxy wise. You can add some powder (bathroom) to your epoxy for a much stronger finish, one that doesnt crack on impact as easily.......QUOTE]
Mopar,
Would you mind "spelling" something out for me please?
What is the trigger point for you that drives your decision to go from a plain epoxy coating of the underside of your Strykers to the next step of using epoxy and a light fibreglass cloth?
Thank you in advance!
Regards
Peter
Peter M is offline Find More Posts by Peter M
Old Jul 03, 2010, 06:54 PM
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by Peter M View Post
Mopar,
Regards
Peter
1. Weight
(If you dont care about weight and are using it for stiffness and strength, go for the heavier glass. If you just need some extra strength and as little weight as possible, you only paint on epoxy. There is ALOT of ground in between and lots of weights of glass cloth to choose from)
2. How much strength do I want in that weight ?
(You must decide if you wish any additives to be added or not)
Old Jul 03, 2010, 08:40 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Do you suggest I go with the the same CF layout as the pic of the neu energy battery?
I really want to go with strip if possible across the motor mount.
I was thinking strip all the way around accept for the two tubes I take out, I would replace with 5mm cf tubes.
What do you think?
Thanks for all of the info, pics...
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jul 03, 2010, 08:44 PM
moparmyway's Avatar
New York
Joined Jan 2009
The bend CF is difficult to install and get even. Then it flies funny in flight and just doesnt want to seem to ever run straight, like you are allways changing trims..................at least on my builds...............so I stopped building the bent ones and do CF like this for BASIC strengthening
Post #10 starts it off
http://www.rcuniverse.com/forum/m_8867370/tm.htm
Old Jul 03, 2010, 10:39 PM
You down with EPP?
Houston, Tx
Joined May 2009
I notice that yours is a bit dfferent from Gryphons.
I also notice that there is no cf in front of the elevons.
I think I will draw one up based on the pics of both and post it, see what you think.
Old Jul 03, 2010, 11:20 PM
GryphonRCU's Avatar
Joined Mar 2008
johnnyrocco123,
You should not worry about mine versus Mopar's, or my old experiment versus new, Mopar's old experiment versus new etc....
You should worry about sketching up your own.
Had you listened to me when I told you to draw up a sketch of what you intend to do and post it before you add more C.F. then you would not have added C.F. in the "WRONG" places as you did on your last go around.
For the final time you need to connect your C.F. together.
More than one person has said that to you. You don't listen then keep complaining about Flutter and control issues.
It seems a bit frustrating. I want to have no part of that topic (was mentioned in a PM recently)....plenty of others can help and have tried to help.
Post a sketch of your plane's current C.F. and draw in what you intend to do....then give time for folks to give you feed back....then and only then go ahead and do it.
If next round does not work for you….start a new build and build more accurately and more precisely.
Some folks have had to do that in past and their next build incorporating the new things that they learned along with more accuracy and attention to detail served them well and ended up with great flying airframes.
Good luck
Gryph
Old Jul 04, 2010, 12:04 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Originally Posted by Arcteryxxx View Post
Was planning to use Gary's 36mm. However the 3648 is actually 37mm OD, so the only way to make it work is to reposition the shaft and make it an outboarder...
Arc,
Here's how I have everything mounted with the big outrunner and 6S-3300 batteries. Like I said earlier, it balances 3/8" ahead of the stock CG points.
You can always hang your outrunner off the back of the Custom RC mount. It has a nice flat mounting surface for the face of the outrunner. You're correct that flipping the shaft will be required, as the motor pulls air in through the mounting hole end and blows it out the bell end. I just made a new shaft for mine with a piece of 5mm stock and left it long enough to stick out both ends so I can put the motor in my heli. The shaft is secured with a 5mm collar. A T-Rex 450 main shaft would make a nice motor shaft if you decide to make your own.
murdnunoc is offline Find More Posts by murdnunoc
Old Jul 04, 2010, 01:17 AM
Arcteryxxx's Avatar
Joined Feb 2010
Originally Posted by murdnunoc View Post
Arc,
Thanks a lot, man!
Old Jul 04, 2010, 02:08 AM
GryphonRCU's Avatar
Joined Mar 2008
murdnunoc,
You do some very impressive work.
Let me quote Mopar (from a phone call a few months back):
"murdnunoc can build."
He does not easily say that about people.
Gryphon
Old Jul 04, 2010, 02:37 AM
GryphonRCU's Avatar
Joined Mar 2008
DX8
http://spektrumrc.com/Products/ProdD...tm_content=DX8
Also see the next two tabs on that same page
It can have Telemetry data on Battery Voltage, RPM, Temp, and Signal strength.
Data Interface
Gryphon
Old Jul 04, 2010, 03:29 AM
cdebaca is offline
Find More Posts by cdebaca
cdebaca's Avatar
USA
Joined Oct 2005
Hi guys, finally got a break in the weather to test out my new 808 mini-cam and Samsung TL110.
Hope you likes.
http://www.youtube.com/watch?v=wjHnpw1rA0E
cdebaca is offline Find More Posts by cdebaca
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
