Notar,
I suspect this issue is related to timing and not because the batteries are sagging under load and tripping the LVC. (If it was the LVC you wouldn't get the chirping noise). Consequently before you spend any money, I suggest you try different timing settings on your ESC to see if that will rectify the problem first. Regards Peter __________________________________________________ _________ Thanks Peter M, I will try that. |
Notar,
I agree with Peter that LVC doesn't normally make a chirping noise. You are probably close to their 52A rating or maybe into their burst range, but they aren't likely sagging that far anyway. I've heard chirping/squealing come from the following: 1. Loose/broken bullet connector or bad solder joint in the motor/ESC connection. Strip the shrink tubing off and visually check/wiggle the connectors. Resoldering the joints will make sure they're good. 2. Shaft slipping inside the magnets inside the motor. Not likely on a 4 pole motor, but it can happen. 3. ESC timing problems. Should likely be set for Low timing on your 4 pole motor, but you can experiment with Medium after you check the solder joints in the bullets. 4. Broken or burned motor wire inside the motor. Hope that's not it! You can check with a multimeter by setting for Ohms or continuity test and touching one probe to the motor's can and the other to each of the three motor bullets. If any of them comes up with zero resistance, there's a short in the motor caused by either a burned or broken wire. Check the bullets first, then mess with ESC timing. The other two problems will require motor repair or replacement. I may have missed a cause, but that's all I can think of. Are you able to get the motor making the sound on video? Might help if we can all hear it, and maybe someone can nail it without further diagnostic effort. Good luck... ![]() EDIT: One thing I just remembered after re-reading. I did have an issue like you experienced on that exact motor with a Hobbywing 80A ESC. For mine, the motor would start fine, but then on advancing the throttle, it would stutter and sometimes make it to full throttle, and other times just keep stuttering. It did the same thing on a Hobbywing 60A ESC. I then tried running the motor on a Castle ESC, and then a Tower Pro 40A that it's currently running on and it ran with no problems. First, check the bullet connectors. If they're good, see if it chirps with no prop on it. If it still chirps and the bullets are well soldered, there may be just an incompatibility issue with the Hobbywing ESC's for some reason. Do you have any other brand ESC that's 40+A you can try running on it? |
Passaic, New Jersey
Joined Mar 2010
need prop help
almost done building up my stryker it is equipped with a 3300kv outrunner motor on a custom rc mount, a phoenix 45, and will be using turnigy 2200 3s 30c lipos, need to know what size prop will work the best... and what kind of speeds should i expect..
Thanks guys, I hope you enjoyed my Stryker's miracle landing video. A few corrections: I was using an APC 7x5 Sport (Gas or Nitro) propeller on that flight and not an APC 7x5E prop and the receiver on the Stryker is NOT a 6200, but a 6110 DSM2 one. I have not yet found the cause of the ~3-5 second complete control lockout.
I did some brief static testing with the APC 7x9 Sport prop and although I have seen higher static thrust before, the customrcparts motor mount was almost hot where the Turnigy 2836-2350 K/V motor was! I did not take any Amp readings, but it must have been sucking Amps. That prop probably won't unload until very high speeds??? For safety on 5S nano-phosphate, tonight's flight will be made with a Master Airscrew 7x6, until I can get some accurate Amp draw readings. At least the prop doesn't slip anymore.
Murdnunoc and all, Here is a video that has the chirping. It chirps and cuts out and if I lower the throttle it recovers and keeps running.
I actually lost the plane on saturday when it went into a death spiral, I think from a receiver brownout. I checked the solder joints on the brand new hobbywing 100 amp esc before flying. It still could have been the cause but I pulled hard on the wires to chech at least. It launched fine and flew two curcuits around the field. I was deliberately pushing up the throttle when it cut out and dived into the ground in a jungle on the other side of the Kokosing river. Very hard to get to. This video is from another flight week before I lost the plane. It has the funny noise. http://www.youtube.com/watch?v=RGcMZ679hOw |
But I believe it is WAY better to crush some foam at the rear rather than add anything under the Custom RC Parts mount. You will be adding increased drag by sticking the front part of the mount up above the fuse foam. |
1. Test any one lead to the can. One probe from the meter on the can, one probe from the meter on one motor wire. If you get continuity, you have a short. 2. Test any two leads, lead to lead and you should have continuity. If you DONT have continuity lead to lead, then you have a broken wire. Check 3 different configurations............. A to B, B to C, and A to C. There should be NO continuity from any lead to the can, and each lead to lead should have continuity |
We need motor manufacturer, motor weight, motor resistance, motor size, etc |
| Thread Tools | |
| Discussion Parkzone F-27C Stryker | That can fly?!? | Parkflyers | 109 | Sep 26, 2012 10:54 PM |
| Discussion Parkzone's New F-27C Stryker | itspat | Parkflyers | 1 | Nov 08, 2011 07:56 PM |
| Mini-Review F-27C Stryker Review | That can fly?!? | Parkflyers | 27 | Jul 29, 2010 08:25 PM |
| Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug | WDP | Batteries and Chargers | 12 | Oct 26, 2009 08:44 AM |
| Discussion Coming soon! F-27C Stryker RTF with lipo and brushless | Solcat | Electric Plane Talk | 0 | May 31, 2006 12:34 PM |
