Old Apr 24, 2010, 06:16 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Originally Posted by finster View Post
Arcteryxxx-
Still using FM flash 5 tx and electron 6 rx...never had any probs till now but I never tryied to go out this far before either...its suppose to have a 1 mile range...I got maybe 1/4 mile when the 2 sec delay started...does that happen with 2.4G?
I've got a 35Mhz Sanwa system that I've discarded... only using 2.4MHz Spektrum DSM2 now... There was no problem with the range of the Sanwa...but it's not suited for el setups.... I guess you'll hve abouta mile range with 35MHZ(with the rx->way beyond visiual)and about 500m with a DSM2 Parkflyer setup(AR6110).......
There are lots of other tings to consider, though......
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Apr 24, 2010, 07:10 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by DoctorAudio View Post
A little off topic, but how are you doing with the 250?
If you didn't know there is a heavy duty tail belt for it, that can be bought from flying hobby.com.
I seen to go crashes with them on and the belt survived.
Later,
GREAT !!!
Awsome little hornet there, that T-Rex 250 really slices up the area. Got the headspeed dialed in to about 3100, and she is just wicked !!!!
Stock belt on mine, when she wears out, I will go kevlar.
moparmyway is offline Find More Posts by moparmyway
Old Apr 24, 2010, 07:36 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Originally Posted by moparmyway View Post
GREAT !!!
Awesome Man.
Better order it now, because then you don't have to wait for it to get to you!
But agree, I love my helicopters.
Later!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Apr 24, 2010, 09:51 PM
NOTAR 600 is offline
Find More Posts by NOTAR 600
ohio usa
NOTAR 600's Avatar
Joined Nov 2007
Originally Posted by johnnyrocco123 View Post
ARC 28-48-1.5
APC 6x4 Sport
Castle Ice 100
4S 3000mah 30C
HS-85mg's
http://www.neartowntech.com/strykers...ngestryker.wmv
Wow man, that looks real fast! I used the apc 6x5.5 prop for the first time today with medusa 1700kv motor and 4S lipo. Made mine most speedy.
NOTAR 600 is offline Find More Posts by NOTAR 600
Old Apr 25, 2010, 12:32 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
some pics
I use 5.3mm CF. 3 pieces in an A-frame. I use spray polyurethane to stiffen up foam and I put three coats of paint on. So far this has done the job for holding the wing together at high speeds. But....if you crash it's toast. A piece of CF from nose tip to back of middle fuse would help here.
I can't say the same for the elevons. I have had the elevons rip clean off in mid air. I found the ca hinges perfectly in tact in the basswood on the trailing edge of thw wing. I think it was the cheap hinges I used on the build. Not sure? It has only happened once out of 3 hinge jobs.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Apr 25, 2010, 05:56 AM
scousethief is online now
Find More Posts by scousethief
scousethief's Avatar
United Kingdom, England, Redcar
Joined Jan 2006
I use my fm t6xehp havent a clue what its range is supposed to be but i can take any of my planes/helis to a dot in any direction without any glitching i prefer to keep it closer than that though lol . A friend was flying my other stryker on his Sanwa 35mhz rd600 last night with no problems.
scousethief is online now Find More Posts by scousethief
Old Apr 25, 2010, 12:19 PM
all4smallrc is offline
Find More Posts by all4smallrc
Founder of the EDF20 club!
all4smallrc's Avatar
Minnesota
Joined Apr 2008
Even though simple, that's one of the coolest looking stryker paint jobs I've seen Johnny!
all4smallrc is offline Find More Posts by all4smallrc
Old Apr 25, 2010, 06:22 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
Arcteryxxx-
my DX7 is rock solid with an ar6200 full range Rx
if you considered or might think about doing FPV then stick to 72
if not you should wait until these come out
DX8
or the JR 11x
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Apr 25, 2010, 06:30 PM
friz is offline
Find More Posts by friz
Crash, Learn, Repeat
friz's Avatar
VA
Joined Feb 2009
Or this http://www.spektrumdx10t.de/vorteile.html
friz is offline Find More Posts by friz
Old Apr 25, 2010, 07:36 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Quick question for those using a DX6i radio with their Stryker:
How do you program the flap switch to be able to have some up elevator when launching the plane and then flip the switch back so the elevator return to it's normal position?
I'm able to program it with my other plane which is not using elevons wing type but it doesn't work with the Stryker
saucisse is offline Find More Posts by saucisse
Old Apr 25, 2010, 07:56 PM
ender707 is offline
Find More Posts by ender707
ender707's Avatar
Sacramento, CA
Joined May 2009
Go to "Mix 1"
Flaps-->Elevator ACT
Then you will have two parameters; Up and down, which go from -100 to +100. Move one value at a time up or down and find which one you need to adjust to make it happen! Should only take a minute or so to do this.
For "Switch" select Flaps.
For "Trim", I like to select ACT, which adjusts your "Launch Mode" in line with any trimming you do for flight.
My magic number is Up: -40% on the gear switch.
EDIT: Added more details.
ender707 is offline Find More Posts by ender707
Old Apr 26, 2010, 01:26 AM
moparmyway's Avatar
New York
Joined Jan 2009
Did you use real thin CA..........or the thick stuff ???
How many drops on each side of each hinge ??
Are you staying 3 cells with that super long ARC ???
Thats one nice paint job !!!
Kind of reminds me of Murdnunoc's a little.
His are VERY fast !!!!!
Old Apr 26, 2010, 04:42 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
[QUOTE=moparmyway;14943711] Are you staying 3 cells with that super long ARC ???
QUOTE]
Mopar,
What is the rule of thumb when using ARC 28-48's mounted in a Styker? Are 1.5's best suited to 3 cells and the 2's best for 4 cells?
I guess I'm asking if Johnnyrocco's fantastic example above would be even better (!) with a 28-48-2 given he is running a 4 cell 3000mAh battery?
Thank you
Peter
Peter M is offline Find More Posts by Peter M
Old Apr 26, 2010, 06:58 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Thanks for the help !! Works like a charm!
Originally Posted by ender707 View Post
Go to "Mix 1"
Old Apr 26, 2010, 10:48 AM
You down with EPP?
Houston, Tx
Joined May 2009
[QUOTE=Peter M;14944167]
QUOTE]
Mopar,
Thank you
Peter
Kv is too low on the 48-2
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
