Old Apr 11, 2010, 01:04 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Science or stupidity
Thanks for the feedback guys!
Seems like some of you have tried something like this before...??
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Apr 11, 2010, 03:33 AM
ender707 is offline
Find More Posts by ender707
ender707's Avatar
Sacramento, CA
Joined May 2009
Originally Posted by wtl0715 View Post
I purchased my Stryker parts separately instead of going with the PNP version. How do the elevons attach to the fuse? I see the tabs, but I'm afraid to pull on them in case they're not covering some sort of adhesive. Any info here would be much appreciated.
-TL
If you look closely at Skunkworks pictures a couple posts back, you will see that their are plastic tabs that go through the hinges to mount the elevons. You should have these parts as they come in the pack with the elevons. Good luck!
ender707 is offline Find More Posts by ender707
Old Apr 11, 2010, 08:55 AM
kittman is offline
Find More Posts by kittman
geek.
kittman's Avatar
Joined Jul 2006
Here's a tip that works well for me. Adding some electrical tape to the length of the elevons seems to strengthen them somewhat. I slapped a 4s battery into my "stock" Stryker with stock servos yesterday. I didn't experience any flex in the elevons that I've had in the past. I had full throws, therefore full control, at high speeds..
...but that didn't prevent me from touching the runway with my tail fins again during a low high-speed pass. I'm always amazed at just how quickly the plane will stop when inverted. It went from 75mph-ish to zero in 2.5'.
That's what I get for giving into the ProBro's at our club and their taunting chants of "lower! Lower! LOWER!".
Of course, YMMV...
kittman is offline Find More Posts by kittman
Old Apr 11, 2010, 11:54 AM
customrcparts is offline
Find More Posts by customrcparts
customrcparts's Avatar
Renton, WA
Joined May 2009
Does anyone have a Scorpion Brushless Motor HK2221-2010KV? If so, can the wires exit straight as shown in the picture? On the Scorpion site, it shows them exiting at an angle.
Thanks!
Gary
customrcparts is offline Find More Posts by customrcparts
Last edited by customrcparts; Apr 11, 2010 at 01:40 PM. Reason: Added picture, reworded question.
Old Apr 11, 2010, 09:55 PM
Renton, WA
Joined May 2009
Got the information I needed.
Thanks!
Gary
Old Apr 11, 2010, 10:10 PM
blanik213 is offline
Find More Posts by blanik213
BLANIK213
blanik213's Avatar
United States, NY, Phoenicia
Joined Feb 2008
Hi Gary I have HK 2221 and the wires exit at a right angle to the face.I don't fly a stryker but Excellent work on the the development and production of the motor mount for the stryker,looks top notch and speaks volumes of the investment of your time for the stryker crowd .
blanik213 is offline Find More Posts by blanik213
Old Apr 11, 2010, 10:21 PM
Renton, WA
Joined May 2009
Blanik213,
Thank you for your compliment!
Just to double check, can you straighten the wires out like the picture? One other user told me that they could. Don't try it if you think that it could damage something though!
Gary
Old Apr 12, 2010, 10:17 AM
BLANIK213
blanik213's Avatar
Joined Feb 2008
The wires are stiff but will bend if needed.
Old Apr 12, 2010, 10:31 AM
Renton, WA
Joined May 2009
Cool. Thank you very much!
Gary
Old Apr 13, 2010, 01:29 PM
donsinger1 is online now
Find More Posts by donsinger1
aka KF7DS
United States, OR, Portland
Joined Nov 2009
Motor Attachment
All:
I recently purchased a Stryker, and have Intermediate skills (have flown my Minimag a lot; pants off the Super Cub; souped up Easystar [very fast] etc...).
Have yet to assemble Stryker and read about starting off with a lower powered engine to start with vs. going with the stock motor.
As such, just purchased an EMAX CF2812 Outrunner...was wondering if this fits the stock mount or will I have to do some modding to get it to fit?
Also, I saw mention of a Stryker "lite" thread but could not locate it..anyone have the url?
Don
donsinger1 is online now Find More Posts by donsinger1
Old Apr 13, 2010, 02:24 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
the best way to mount the 2812 using the C mount is to use cable ties through the collar holes in the 2812 and then through the main mount holes, the holes line up so just thread through. Use a 7x6 prop and an 18amp esc 1500mah 3cell or 2200 mah 3 cell both are good. If you need to adjust the thrust angle just thread a washer inbetween the motor collar and the mount.
Youll love it , with the 1500mah the stryker slows down very nicely but has enough punch to satisfy until you are ready to upgrade the motor.
scousethief is offline Find More Posts by scousethief
Old Apr 14, 2010, 12:54 AM
aka KF7DS
Joined Nov 2009
Thanks so much. Sounds very straight forward. I have some 7x5 props around and will try that.
Don
Old Apr 16, 2010, 04:09 PM
Arcteryxxx's Avatar
Joined Feb 2010
Have anyone tried the NEU 1115/1Y on a Stryker?
Old Apr 16, 2010, 08:03 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Arcteryxxx,
That NEU would make a good 3S-5000 motor.
It can work on 4S but is not best choice for 4S...you can pick a better KV NEU motor if you intend to run 4S.
If you intend to run 3S, MEGA 16/40/1C 3100KV is a great choice at $20 less and can get built and delivered in less time....better quality, and more options too.
It has 5mm Combat shaft as compared to NEU 3.2mm
6 Pole MEGA will allow the motor to get pushed further than 4 pole NEU.
I will not knock the 3S performance of either one....we are talking some serious power there.....both will go far past 120 MPH even if you have a cam and also Co-pilot mounted outside of the Stryker.
Be prepared to run manly amount of AMPs.
Good luck, have fun.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Apr 17, 2010, 12:28 AM
Arcteryxxx's Avatar
Joined Feb 2010
Originally Posted by GryphonRCU View Post
Arcteryxxx,
Gryphon
Thanks. I will!
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
