Old Jun 02, 2007, 09:56 PM
ChrisWNY is offline
Find More Posts by ChrisWNY
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Fatts - I guess you just stated at least one advantage to NOT having landing gear on a R/C plane...
ChrisWNY is offline Find More Posts by ChrisWNY
Old Jun 03, 2007, 03:32 AM
CSI is offline
CSI
Find More Posts by CSI
CSI
I promise, just ONE more order
CSI's Avatar
Del Rio Intl, Texas, United States
Joined Feb 2004
Fatts,
That is too funny! I bet you would have been surprised if your Stryker has gone whizzing by your head?!!! We all slip up at one time or another. Of course that could be a very expensive lesson if you don't start unplugging those lipos after flight. Drain one down and you won't be doing donuts any longer with that pack.
Happy flying and thanks for sharing.
Ken
CSI is offline Find More Posts by CSI
Old Jun 04, 2007, 03:35 AM
finster is offline
Find More Posts by finster
finster's Avatar
Michigan
Joined Feb 2006
I have alot of horror stories myself...guess thats why they call accidents -accidents I been putting togather a new stryker...Im gonna keep it simple and lite...shaved off vents and used 2 solid FG rods across bottom...after a lite air brushing, Im done...it was time for a new battery too...I picked up a new 4s 25C TP Extreme thinking I may get more bang for the buck...I will get a vid of it when im done...I was sent a flying challenge and thought id pass it on to you extreme pilots...this is your time to shine...I got 48.8
Challenge
finster is offline Find More Posts by finster
Old Jun 08, 2007, 08:37 AM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
finster -
49.3M on that "challenge". Definitely a good time killer for those slow days at work.
The servo on left wing of my Stryker has popped loose during the past 2 flights. I had been using hot glue to secure the servos to the Stryker fuselage, but it just wasn't holding the left servo. I ended up pulling out the big guns and Sumo glued it in, then set a ball-peen hammer on top of the servo while the glue was drying to really lock it down. The right servo is still in there solid, for some reason the hot glue held fine there. If that servo pops out again, I am going to explode!!
Old Jun 08, 2007, 08:57 AM
That can fly?!? is offline
Find More Posts by That can fly?!?
Live, Die, FLY
Kalispell, in the Rocky Mountains
Joined Jul 2006
I still will be flying my Stryker... But I have been bitten by the heli bug...again. Going for the T-rex 450 SA.... Cant wait.
That can fly?!? is offline Find More Posts by That can fly?!?
Old Jun 10, 2007, 06:04 AM
rcozstyle is offline
Find More Posts by rcozstyle
rcozstyle's Avatar
gawler, South Australia
Joined Jul 2006
Hi Guys
I got a bare airframe stryker which is ready to go and I would like to know what throws to put on the elevons, can anyone please help me?.
rcozstyle is offline Find More Posts by rcozstyle
Old Jun 10, 2007, 03:23 PM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Originally Posted by rcozstyle
Hi Guys
Rcoz -
10-15mm above and below the deck should be fine. I used the long arm connectors that came bundled with the HS-65HB servos, and put the control rods through the outer most holes. Plenty of throw.
Old Jun 10, 2007, 03:53 PM
I.C.O.N. is offline
Find More Posts by I.C.O.N.
I.C.O.N.'s Avatar
Twin Cities, MN
Joined Feb 2006
I go for as much throw as I can muster! And it's still not quite enough for me.
Low rates at about 75% of full throw. I never use them anymore though.
I am using HS81's and have the rods on the outer holes and the control horns on the second to the outer hole.
Have Fun!
Andy
I.C.O.N. is offline Find More Posts by I.C.O.N.
Old Jun 12, 2007, 11:37 AM
Live, Die, FLY
Joined Jul 2006
Dose anybody have a DX6 Reciver laying around thats not in use???
Old Jun 13, 2007, 02:05 AM
Roryw is offline
Find More Posts by Roryw
Rory
Roryw's Avatar
Australia, Belrose
Joined Aug 2005
I am buying a Stryker C version this week. I am going to run a Mega 15/16/4 with 4S. Do i need to mod the airframe at all to handle this ??
Rory
Roryw is offline Find More Posts by Roryw
Old Jun 13, 2007, 08:54 AM
Live, Die, FLY
Joined Jul 2006
Rory
Yes. More carbon fiber supports, or even a carbon fiber arrow shaft.
Old Jun 13, 2007, 09:18 AM
I.C.O.N. is offline
I.C.O.N.'s Avatar
Twin Cities, MN
Joined Feb 2006
Excellent info here
Also the Mega 16/25/2 and 16/25/3 have been said to have great success on the Stryker.
Haven't tried one myself yet.
Old Jun 13, 2007, 04:22 PM
finster is offline
finster's Avatar
Michigan
Joined Feb 2006
I finnished my plane but the weather hasnt been so good...Maybe tomarrow I can get out and fly it...I molded a one piece hatch and it looks good but Im thinking I may go with a half hatch leaving the electronics open to get more air...For CG I pushed electronics as far back as possible and made 2 slots in back for the ESC and UBEC so they sit on top of each other with a small gap between for more air...Took out about 1/4 of foam below the battery so the battery could lay flat...I used 2 CF rods across bottom for strength...
Update: Few hours later the weather got better so I took it out...Zooming around and I noticed the nose started getting heavy...so I adjusted the trim to bring it back up...next thing you know....BAM...the plane goes from 80 to 0 like it hit a brick wall and starts tumbling thru sky...I seen something black flying thru sky and hit a tree with a loud bang...it was the new 4s battery...the plane landed up in neighbors tree with some damage to wing...the battery was couple hundred feet away in weeds with a big dent in it after it hit the tree...
Conclusion: dont forget to put valcro on your battery!
Old Jun 14, 2007, 02:09 PM
Opie68 is offline
Find More Posts by Opie68
Joined Apr 2007
Coating the Stryker with polyurethane
Hello, I'm on my third Stryker C airframe. And when I painted this last one, I coated it with Minwax waterbased poly. So far it has worked pretty good. Has anyone else tried this?
Opie68 is offline Find More Posts by Opie68
Old Jun 14, 2007, 02:31 PM
Opie68 is offline
Joined Apr 2007
Polyurethane
My third Stryker with polyurethane
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
