Old Mar 24, 2010, 08:53 PM
ender707's Avatar
Sacramento, CA
Joined May 2009
Aj,
I have the motor, I posted some basic tests on it a whole bunch of pages back. It can spin the 6x5.5 on 3S easy, because it can swing the APC 6x5.5 on 4S without getting too hot.
ender707 is offline Find More Posts by ender707
Old Mar 25, 2010, 06:36 AM
Raleigh, NC
Joined Sep 2004
Aj,
I think the issue with the 2835-2200 Turnigy (as well as the 2835-2700) is that the kv is lower that than what is posted. On the 2700, I've seen many posts claiming it was really 2550. I the 2200 I've seen some posts claiming it was 2000 or just below.
Even one of the reviewers on Hobby King stated that this motor had less punch than the stock Stryker C motor (which is supposed to be 1880 kv). But a 4s lipo or a bigger prop might solve the problem...
You might even be able to get away with a 7x6 prop on the 2200 kv one (if i can handle 6x5.5 on 4s). But check the amps...
cjbucher is offline Find More Posts by cjbucher
Old Mar 25, 2010, 12:32 PM
BUILDnFLY
jphong's Avatar
Edmonton, Alberta, Canada
Joined Apr 2006
or just go with the 2700 one, that what i have and it goes around a large field quickly
however now that ive flown it a handful of times its on full throttle the whole time so now im thinking of bumping it up to the 2835-3200 turnigy motor that i have
just have to figure a way to mount that huge@$$ esc
jphong is offline Find More Posts by jphong
Old Mar 25, 2010, 04:00 PM
Raleigh, NC
Joined Sep 2004
Yep, I also have the 2835-2700 with a 5.5x4.5 prop. It does perform quite a bit better...
Old Mar 25, 2010, 09:11 PM
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
johnnyrocco123:
How is that motor setup working for you?
DoctorAudio is offline Find More Posts by DoctorAudio
Latest blog entry: Composite 200 mm micro quad!
Old Mar 25, 2010, 11:46 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Well, I folded. I wanted to make sure I had some batteries to play with over Easter weekend, so I just placed my order from HC.
2x 3s 3000mah 40C
2x 2s 3000mah 40C
Should be a significant improvement over the 2200-30C batteries that I was using last season. Here I come for more speed! After shipping the batteries aren't as big of a deal as they would be at first blush, but it works out to around $11/cell. Not too bad for cheap thrills!
I can't wait to "break" (although im still not fully convinced) these puppies in and see how they perform.
Congrats to whoever orders after me, as you'll likely be seeing the 45C batteries released in the next week or so
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old Mar 26, 2010, 04:34 AM
ender707's Avatar
Sacramento, CA
Joined May 2009
Kid,
Sorry my order didnt do it, the Universe is all out of alignment. I just bought a lottery ticket.
Old Mar 26, 2010, 07:38 AM
Victim of C.D.O.
murdnunoc's Avatar
Roanoke, Texas, USA
Joined Oct 2007
Kid,
Did you go with Flightmax or Turnigy? I'm still up in the air as to which is better. Flightmax is always lighter and smaller, but it seems like the higher weight of the Turnigy cells should indicate higher discharge ability.
Any experience comparing the two lines head to head?
murdnunoc is offline Find More Posts by murdnunoc
Old Mar 26, 2010, 12:27 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Murdnunoc, I went with the Turnigy battery because of the form factor. The Turnigy battery is only 43mm wide, while the Flightmax is 45mm wide. Though this may seem like a small change, it is critical in being able to fit the batteries into my Siren as well as my Escape (pylon model). In all of my applications length and height is not as big of an issue as width, I need skinny batteries! The Turnigys should fit in my Stryker with minimal modifications. I have never tried a Flightmax battery, but they do look appealing. They aren't quite as cheap either (though this is nickel and diming it).
I have had great experiences with my Turnigy packs. They have taken a lot of abuse and keep on trucking. In bursts at 30C (their rating) I still see 10.8-11V for a 3s battery in my Siren. In the high performance community the HC batteries are beginning to show a little bit of a following. If its good enough for them its good enough for me!
Kid
Old Mar 26, 2010, 07:08 PM
Milwaukie , Oregon
Joined Feb 2003
A buddy of mine dropped this by the house to show me what he could do for me!
He said that he may be able to do it for about 25.00 a unit, they will be polished, and clear coated!
Old Mar 27, 2010, 11:09 AM
Victim of C.D.O.
murdnunoc's Avatar
Roanoke, Texas, USA
Joined Oct 2007
Is that a stock plastic mount with an aluminum finish??
Old Mar 27, 2010, 12:25 PM
Fly it like you stole it
SUPERGONZO's Avatar
Joined Feb 2007
why clear coat them??
I'll take mine brushed aluminum, does he have both sides done, or just the top plate?
SUPERGONZO is offline Find More Posts by SUPERGONZO
Old Mar 27, 2010, 08:09 PM
Milwaukie , Oregon
Joined Feb 2003
Guys, I am working on the deal to get these mounts done and brought to the public.
I have a order list that is getting larger by the minute!
These mounts are Laser cut out of aluminum and then welded together.
Me I would love to put a finish on them, things are starting to add up!
I may be able to get a friend to Anodize them for a cheap cost but we will see in the end!
Send all email request to this email address about the mounts and I will contact you as soon as we work this out!
epp4less@gmail.com
Thanks guys for your patience, is appreciated.
Elvan Wilson II
Old Mar 28, 2010, 07:57 PM
Joined Sep 2009
for 10.00 more the other unit on the forum is of much higher quality and is cnc'd beautifully
6s hydro is offline Find More Posts by 6s hydro
Old Mar 28, 2010, 08:25 PM
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
I would be willing to bet that the Custom RC mount is lighter as well
moparmyway is offline Find More Posts by moparmyway
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
