Old Mar 14, 2010, 03:54 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by ender707 View Post
Ask gary if you can get the 28mm mount with the "Slot" cut in it for outrunners.
If not, I got mine mounted by removing the bullet connectors and passing the wires through one of the bottom holes. Mine is still in this state as I am flying an ARC 28-47-2 right now. The 2836-2350kv is my current back-up, just need to put new bullets on it and its ready to go.
Running the wires Under the mount looks possible, but will require removing some foam. Post pictures if you do it!
Thanks dude. Hey what size motor hex screws are those?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Mar 14, 2010, 04:09 PM
ender707 is offline
Find More Posts by ender707
ender707's Avatar
Sacramento, CA
Joined May 2009
They are; Dubro 3mm x 6mm Socket Head Cap Screws. $1.89 from LHS.
ender707 is offline Find More Posts by ender707
Old Mar 14, 2010, 09:54 PM
You down with EPP?
Houston, Tx
Joined May 2009
I changed out my Turnigy 2835 2700kv for the 2835 3900kv. I propped down to a 5x3apc and measured 36amps static. The motor is rated for 40 amps.
About 4 minutes into the first flight the motor blew. I gave it maybe (5 sec) bursts of full throttle.
I have had about 20 flights on that motor but I haven't used it since last summer. I might try another one. It is so much faster than the 2700kv on a 6x4, and it still has great thrust.
Old Mar 15, 2010, 10:11 AM
You down with EPP?
Houston, Tx
Joined May 2009
ARC 28-47-1.5 in stock Light flight r/c $59.95
Mega ACN 16/25/1.5 in stock New Creations r/c $156.80
I was ordering a new spinner for a my hotliner and thought I would ask.
Old Mar 15, 2010, 10:22 AM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
When you were running it with the 5x3 prop, how hot did the motor get? Could you hold your fingers on it comfortably or was it too hot to touch? Either your motor was bad or maybe that 40 amp limit is a bit optimistic?
cjbucher is offline Find More Posts by cjbucher
Old Mar 15, 2010, 10:29 AM
You down with EPP?
Houston, Tx
Joined May 2009
Actually this morning I looked further into it and I think I blew the esc, but I landed it ok, and later that night I plugged a different motor into the esc and tested it, it flew about half power, then the esc smoked.
I am used to an esc just blowing all together, this one was gradual in the fact that I was still able to cintrol my plane and run it on a diffrerent motor for about 2 mins.
I was testing the limits of a turnigy 40amp esc. I believe the 3900kv was pulling 43amps on a fresh battery static.
A 40 amp should have been good....
Old Mar 15, 2010, 12:57 PM
jteplane is offline
Find More Posts by jteplane
Fly by Night
jteplane's Avatar
Phoenix, AZ
Joined Jan 2007
Can someone point me to anywhere in this thread that talks about how to adjust the stryker to roll cleanly. I've tried adjusting the end-points, throws, etc and this plane still doesnt want to roll clean. - thanks,
john
jteplane is offline Find More Posts by jteplane
Old Mar 15, 2010, 01:13 PM
all4smallrc is offline
Find More Posts by all4smallrc
Founder of the EDF20 club!
all4smallrc's Avatar
Minnesota
Joined Apr 2008
What do you mean? Like, they aren't very axial? One thing to check is cg. A perfect cg is very important.
all4smallrc is offline Find More Posts by all4smallrc
Old Mar 15, 2010, 01:16 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
That motor should not b e run with that prop.
You should be running a 4.3 graupner prop.
Anything else will kill it.
DoctorAudio is offline Find More Posts by DoctorAudio
Old Mar 15, 2010, 03:00 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Turnigy 2835 3900KV
Hi!
I also use the Turnigy 2835 3900KV in my setup. I use a little bit too large prop (6*4e) and it is drawing 54 amps and some 610watts with a 35C 2200/3s battery. Have plenty of perfect flights with this setup but are now going to try the Turnigy 2836 2350 Outrunner as I am more interested in push and accelleration rather than speed on my Stryker. Think it will suite the 6*4 or 6,5*4 really well, but I'll report back after making som static tests later this week.
Here is a video showing how the 2835 3900 setup performs:
F 27 Stryker over Riseng, Askim, Norway (9 min 7 sec)
-Arcteryxxx, Norway
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Mar 15, 2010, 03:45 PM
Milwaukie , Oregon
Joined Feb 2003
Originally Posted by Arcteryxxx View Post
Hi!
http://www.youtube.com/watch?v=FR84qprK-c4
-Arcteryxxx, Norway
I am running that motor 2836 2350 with a 4S setup.
80 amp ESC and 4.7 x 4.2 prop.
I can fly at about 120 mph level flight.
Pushing over 580 watts.
This is my everyday Stryker!
On a 3S setup it is good for 100 mph with a 6X5.5.
But it does get warm.
So, I just leave the 4 inch on and just fly with my friends until they want to go faster!
Every Park 2700 motor Stryker I come across on a 4S setup I leave behind!
Old Mar 15, 2010, 04:06 PM
You down with EPP?
Houston, Tx
Joined May 2009
4.7x4.2 on a stryker?
Old Mar 15, 2010, 04:49 PM
Milwaukie , Oregon
Joined Feb 2003
Yes, I will post a video later tonight.
Don't have to worry about cutting the fingers.
Of to drop some planes off, at the hobby shop!
Old Mar 15, 2010, 07:54 PM
ender707 is offline
ender707's Avatar
Sacramento, CA
Joined May 2009
For anyone interested, I have began working on my Doomed Stryker Project.
I am building a Stryker that will be Shot Out of The Sky this coming Memorial Day weekend starting with 22 Calibers and Ending with 12 guage Shotguns if the 22s cant get the job done!
You can follow it on my Blog at:
http://www.rcgroups.com/forums/showthread.php?t=1211105
Old Mar 15, 2010, 09:27 PM
Milwaukie , Oregon
Joined Feb 2003
http://www.youtube.com/watch?v=Vqjvl4DrAic
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
