I got some doppler readings off the 6x5.5 on that motor, and IIRC, it was about 98mph. I figured roughly 85-90mph true speed. To be honest, I think the 6x5.5 is too much prop, and bogs that motor down. Just judging my seat-of-the-pants feel, the 6x4 delivers the same speed with a tad more thrust.
Innisfail Australia
Joined Dec 2007
Hi Guys, I've been playing round with props and have been able to get a bit more speed out of my stryker (130Km with Eagletree). The only down side is at WOT I've got to put a fair bit of aileron in to keep it level. The fuse is showing signs of age on it and I suspected it was flex in the fuse causing the problem, I had already put base wood ailerons on it sometime ago so I figured they should be ok, so I thought putting a 5mm CF stiffener from wing tip to tip might help. This has improved it a bit but it's still not good. Could the problem be caused by the additional prop torque, can the problem be solved by angling the motor as with front engined planes?
Thanks for your help. |
It sounds like your Stryker is just plain old flexing at higher speeds, like you thought.
You could try adding some CF front to back, and then triangulating .210 CF tubing with whatever else you have installed. See picture below for examples. The lowest CF that looks bowed has proven to give wierd in-flight characteristics, so I NO LONGER bend the CF in the rear to follow the wing-tips, the rear most CF stays straight and additional tubes are added following the trailing edge angle What servos are you using ? |
![]() http://www.rcgroups.com/forums/showt...61678&page=478 |
Raleigh, NC
Joined Sep 2004
You might have a warp or something uneven in the shape of your wing that gets amplified with speed. Has it always done this or has it gotten worse with age? I've seen Strykers warp with age especially if they sit in the sun. |
i'd imagine your A fuse has quite a bit of flex in it. the foam was less dense back then... and they had the separate wingtips dovetailed to each side. i still have my first stryker fuse, too. it's empty of any gear. used to hold two 8cell nimh packs, two channel 1 receiver/esc and two motors. each receiver/esc connected to one servo and one motor. the motors were centered where the vertical fins would be. had to cut some elevon off for that. single vertical fin between the two motors. and can you believe, it worked! had a few flights before moving on. guess i envisioned using the fuse again at some point.
Raleigh, NC
Joined Sep 2004
Actually mine is the one piece body. The early A version was 3 pieces and not made of Z-foam. Mine is one piece and made of Z foam but is not the B version. I guess it was a "late model A". About a year later they started making the B.
The B version has the extra vents in the plastic covers and the proprietary electronics allowed for lipo. |
I originally bought a Stryker years ago because I lived in a windy place. I have flown it in much higher winds than I would recomend, but overall, out of the several planes I have owned the Stryker is my go-to on windy days. My EDF planes are much more sensitive to wind.
The inexpensive replacement parts ($20 Fuse!), easy customization, and ability to fly in wind and in areas with iffy landing zones (like while camping) are the reasons I have kept a Stryker on hand for the past 6-7 years. |
| Thread Tools | |
| Discussion Parkzone F-27C Stryker | That can fly?!? | Parkflyers | 109 | Sep 26, 2012 10:54 PM |
| Discussion Parkzone's New F-27C Stryker | itspat | Parkflyers | 1 | Nov 08, 2011 07:56 PM |
| Mini-Review F-27C Stryker Review | That can fly?!? | Parkflyers | 27 | Jul 29, 2010 08:25 PM |
| Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug | WDP | Batteries and Chargers | 12 | Oct 26, 2009 08:44 AM |
| Discussion Coming soon! F-27C Stryker RTF with lipo and brushless | Solcat | Electric Plane Talk | 0 | May 31, 2006 12:34 PM |
