The 1 1/2" industrial heat shrink will fit the HS 81and 85 servos size it's not the thin shinny battery heat shrink but rather like a tough thin rubber with a dull surface that works well with CA or hot glue if you wish.I use the thick gap filling CA on all three contact surfaces making sure not to get any on the servo itself just the heat shrink and there is no flex in the joint and the new rubber skin actually strengthens the servo well especially in a foam wing.Take your time and use just enough heat when shrinking the tube to avoid over heating the servo.If the heat shrink doesn't fit the servo it can be stretched open easily.
Joined Feb 2009
Hot glue is nice for putting things together where CA would either burn, make it too stiff, or isn't thick enough and Epoxy takes a while to cure. Hot glue is heavy and not too tough but it certainly does the job! I hot-glued balsa strips to the trailing edges of my Stryker to make it stiffer and make a hinge mount for my new elevons and it's perfect for that kind of thing. I will probably hot glue my new vertical stabilizers into place as well. |
Romford, UK
Joined Jun 2004
ZIPPY Flightmax 3S 2200mAh
I used that low temp gun tonight murdnunoc it worked a treat on the servos, really holds them in there very securely. I used clear packing tape to protect the servo areas where I applied the glue Unsullied_Spy worked well, thanks guys. Funny as one of the servos I bought from hobbycity has a terrible misalignment, it simply wouldn't mechanically allow me to place the control horn 90 degrees to the servo and it was only after I glued it in did I realise this! Thankfully hotglue is quite easy to remove as others have said.. I think today I have been through a crash course in hot glue! I read on the reviews of this servo on hobbycity that a few others also had this problem, luckily I bought three of these servos and had a spare which was able to be centred correctly. Be careful anyone that does buy Hextronik MG-14 14g/2.2kg/0.11sec servos, some do have this problem it seems and I wouldn't buy these servos again. |
Cheers Trancer for that link, I'll try that and see what I think. I didn't like the other fix due to using both mixes and not being able to mix throttle to elev. for launching, and adding up trim before launching causes it's own probs |
So basically everything looks good except those stock clevises. Best to just get yourself some DuBro 2-56 rods and hardware. The stock clevises can just break on you in the air for no apparent reason. I would try throws on the outer holes in your arms on the servo and the second hole away from your elevon. This should allow you the ability to yank and bank while also keeping your Stryker tame. Best insurance would be to program your DX6i for Dual Rates of about 60% throws on 50% positive expo, which will soften the center of the stick and limit the servo throw to 60%. Just flick a switch and you have your 100% throws, or your 60% throws with some expo. You could play with eithor after you get some flights and "tune" your transmitter to your Stryker and your flying style. One more hint; Sub Trim (on DX6i) will allow you to trim your servo without effecting the "normal" trim (which will alter the travel distances of your elevons). This allows you to trim your Stryker and keep the trim tabs centered, without messing around with the rods and clevises. Also makes for fast work in snowy/freezing flying fields when trying to dial in the flight controlls. |
Joined Feb 2009
+1 on the 2-56 rods, I just installed mine today and they are leaps and bounds better than the stock units. I got the spring steel clevises from my LHS for just a few $ and if I can manage to break those I need to hang up my wings!
Mopar's suggestions about the transmitter setup sounds spot-on, should be able to be aggressive with it at low speeds then flip a switch and be able to control it at higher speeds. |
Joined Feb 2009
I've put quite a bit of use on my stock ESC on 4s and it seems to be holding up just fine. It has a switching BEC so it handles higher voltage better than other ESCs that just have a linear regulator. It says right on the shrinkwrap 3-4s lipo, has a setting for 4s cutoff, and there is nothing in the manual to suggest it's a bad idea so I'm going to continue running mine until I either get my new ESC or toast the stock one.
The only drawback to running an ESC with a built in BEC (instead of an external or additional BEC) is that if your ESC goes "POP" (usually from drawing too much current on the motor side) you run the risk of NOT having controll of your plane.
An external BEC can allow you to dead stick your plane and land even if your motor shorts out and takes out your ESC as well If you do run an external BEC, it is GREAT insurance to power it from a seperate source (flightpack) and not the main battery. If you can make the room, it just about guarantees you a return 'controlled" landing. |
Vinnie |
| Thread Tools | |
| Discussion Parkzone F-27C Stryker | That can fly?!? | Parkflyers | 109 | Sep 26, 2012 10:54 PM |
| Discussion Parkzone's New F-27C Stryker | itspat | Parkflyers | 1 | Nov 08, 2011 07:56 PM |
| Mini-Review F-27C Stryker Review | That can fly?!? | Parkflyers | 27 | Jul 29, 2010 08:25 PM |
| Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug | WDP | Batteries and Chargers | 12 | Oct 26, 2009 08:44 AM |
| Discussion Coming soon! F-27C Stryker RTF with lipo and brushless | Solcat | Electric Plane Talk | 0 | May 31, 2006 12:34 PM |
