Old Feb 09, 2010, 11:42 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Thanks for the tips guys. I will try these ideas tonight.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Feb 09, 2010, 11:57 AM
Trancer is offline
Find More Posts by Trancer
Romford, UK
Joined Jun 2004
Originally Posted by moparmyway View Post
Trancer,
Spektrum (DX6i) needs to be programmed for Elevon or Delta (page 43 in your DX6i manual). One servo goes into Aileron (left, I think), one goes into Elevator (right, I think), channel 2 and 3 get reversed.
Thanks I have that sorted now.
I am about to glue in the servos but before I do what is the recommendation as to where the control rod should go into the servo? I want to have some decent travel but nothing too wild. I currently have the control rod linked in at about the middle of the control arm on the servo, should I move it down further?
Epoxy ok to glue them servos in?
Trancer is offline Find More Posts by Trancer
Old Feb 09, 2010, 05:07 PM
Unsullied_Spy is offline
Find More Posts by Unsullied_Spy
Joined Feb 2009
I run my rods on the outtermost holes, but that's to get maximum travel (I also attach as close to the elevon as possible).
For gluing them in I used hot glue because it isn't as permanent. A bit of glue on one side and tape on the other and they should stay still but still be removable when this airframe needs replaced.
Unsullied_Spy is offline Find More Posts by Unsullied_Spy
Old Feb 10, 2010, 04:14 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
With the DX6i, there's a problem with the Elevon mode, in such that you get reduced travel on the servo's. Ther'e a fix where you use a couple of mixes instead of using elevon mode, but if you forget to activate them and launch, you're in trouble. I find the best way is servo arms as long as poss, use outer hole, and use the lowest hole on the control horn. I don't think you'll get full travel, i.e. recommended deflection, but this helps to give a bit more.
More info.... http://www.rcgroups.com/forums/showp...2&postcount=35
feefo is offline Find More Posts by feefo
Old Feb 10, 2010, 05:58 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Trancer,
May I ask you for your setup ?
I know you referenced a Turnigy 2836, but what kv, what ESC, and what battery ?
I think it would make a difference knowing your setup, What servos and arms, what controll horns, how heavy it is and where she CG's before reccomending servo arms and hole heights. If you are nose heavy, you will need more travel. If you are on the CG, alot of travel will make for a Stryker on crack.................usually gets back to the ground in a loud crash, and we do NOT want that. DX6i can run Dual Rates, so there is more mix to stir in your pot.
Up to you, but you can PM me if you want more details, or stay on-line..................allways here to help.
I too like the hot glue way to secure servos, easy and clean. VERY strong !!!
moparmyway is offline Find More Posts by moparmyway
Old Feb 10, 2010, 09:43 AM
lowdive is offline
Find More Posts by lowdive
lowdive's Avatar
anaheim, ca
Joined Apr 2005
i just realized that i've never glued my servos into place. max speed is likely around 80mph, though, so it's probably not as big a deal. they are held in by friction with the foam and packing tape. eegads!
lowdive is offline Find More Posts by lowdive
Old Feb 10, 2010, 10:44 AM
blanik213 is offline
Find More Posts by blanik213
BLANIK213
blanik213's Avatar
United States, NY, Phoenicia
Joined Feb 2008
Friction and packing tape eegads is rite lowdive the gods have been with you.
blanik213 is offline Find More Posts by blanik213
Old Feb 10, 2010, 10:46 AM
lowdive is offline
lowdive's Avatar
anaheim, ca
Joined Apr 2005
yeah, but like i said i'm not going near as fast as some of you. i'll have to point a cam at the servos during a future flight to see what they do in the air.
Old Feb 10, 2010, 11:02 AM
Trancer is offline
Romford, UK
Joined Jun 2004
I was getting myself in a right confused mess last night with working out what hole the control rod should go into servo, was torn between outer hole or inner hole. Will clear packing tape work ok? I found a low temp 11w laying around but will get a hot gun today instead.. what is the method for removing hot glue?
A couple of days ago I came across another thread that talks about reduced travel with the DX6i and a fix for it (http://www.rcgroups.com/forums/showt...=860537&page=4). The link you have posted seems to have a different solution to this problem will take a closer look after work thanks
Trancer,
Hi moparmyway
My setup is
Turnigy2836 brushless Outrunner 2350kv
TURNIGY Plush 40amp ESC
Hextronik MG-14 14g/2.2kg/0.11sec servo
3S lipo
AR500 RCX
Control horns, surfaces, rods are all stock replacement stryker f27c parkzone parts.
Looking for control which isn't too wild but will turn out of winds easy.
Thanks all
Old Feb 10, 2010, 11:14 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Trancer,
That low temp glue gun you already have may be just the right thing.
Low temp hot glue is what you NEED for Stryker foam. High temp will just melt a hole in it. So if you do get a bigger gun, get a low temp or dual temp. You'll find a higher wattage, low temp gun will help in the future for big jobs like gluing in carbon spars, as a low watt glue gun can't reheat itself fast enough and you can find yourself not able to get enough glue out.
Low temp glue sticks work better than all purpose ones, as they stay liquid longer for parts positioning.
murdnunoc is offline Find More Posts by murdnunoc
Old Feb 10, 2010, 11:23 AM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by murdnunoc View Post
Trancer,
I notice alot of you talking about hot glue. What is the advantage of hot glue over foam safe CA??
Old Feb 10, 2010, 11:25 AM
lowdive is offline
lowdive's Avatar
anaheim, ca
Joined Apr 2005
at the servos, control rod is in furthest hole from center. at elevons, control rod is nearest the elevon. my elevons are almost vertical at full deflection. i use small inputs when racing around then cut throttle and hold full up to land. sucker almost floats straight down where you want to put it. i don't think i could live with less control.
Old Feb 10, 2010, 11:27 AM
lowdive is offline
lowdive's Avatar
anaheim, ca
Joined Apr 2005
i have always used foam safe ca (err, not on the stryker but for other planes) and never had issues if i need to replace a servo. just takes a sharp exacto knife to work around the edges and loosen it up, then pluck it out.
i expect that hot glue is easier to work with, when applying and removing.
Old Feb 10, 2010, 12:24 PM
BLANIK213
blanik213's Avatar
Joined Feb 2008
A good quick way to install a servo is to rap a piece of blue painters tape around the servo(two layers) before using a small amount of ca to install them then when or if it must be removed simply cut the tape open on the front side of the servo and work the servo free. You can then clean up the servo cavity after and remove the tape from the servo leaving a clean servo to start all over.Even better than the tape is a large piece of heat shrink tubing. Cut a piece like a wide rubber band and shrink it around the servo,works out cleaner than the tape and can be found at most industrial electrical supply houses. I use this method where gluing is the only or best solution to an install and it works like a charm,easy in easy out.
Old Feb 10, 2010, 01:43 PM
You down with EPP?
Houston, Tx
Joined May 2009
I heard about the heat shrink. Do you know what size will fit most micro servos?
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 11:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 08:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 09:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 09:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 01:34 PM
