Old Jan 25, 2010, 10:39 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Originally Posted by murdnunoc View Post
DbleX,
The closest inrunner HobbyCity will have to your old motor will be the Turnigy 2835 2700kv inrunner
It is definitely slower than 2700kv. More like 2300 or 2400. Expect power handling around 40 Amps, and 3 cell speeds around 75mph. 4S maybe 85mph. Just ballpark figures.
If you're willing to do just a little hacking on your stock motor mount, you could run the Turnigy 2300kv outrunner.
You'll have to shave down the inside of the motor mount just a little with a Dremel sanding drum to allow the outside of the motor to spin, but other than that, it'll mount just like the inrunner motors. See pics here. I've run this motor to 100mph with no problem on 4S, and others have had great experience with it on Strykers, too. Expect 85-90mph ballpark on 3S.
One thing based on my experience with outrunners on Strykers is they don't handle crashes well. I've had both outrunners I've run get magnets knocked off in crashes, effectively ruining the motor. Just something to keep in mind if you're planning on the plane seeing some abuse in combat.
If you feel like being a tester, there's another inrunner at HC that hasn't gotten much press that I've seen, but looks like it could hold promise. It'll fit your mount fine, and the specs don't look too bad. I'd love to hear how one of these flies on a Stryker.
My preference for performance would be the 2300kv outrunner, unless the impeller inrunner is a real sleeper!
Have fun, and let us know if we can help narrow it down any more.
Just for you, Murdnunoc, in case you havent seen it yet...
http://www.rcgroups.com/forums/showthread.php?t=1169504
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old Jan 25, 2010, 11:02 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Kid
Thanks, Kid!
I did see in the Ritewing thread where Jak blew up that motor, but for some reason I was thinking it was the 480 size he was working with.
Looks like they're worth a shot!
Shame the 480 size is 30mm diameter. Means no stock mount. But for anyone who can get around that, it may be a cheap ticket to some power. I'm going to throw the 1370kv onto my next order to try some cheap high voltage!
hmm... am I the only one to whom it sounds weird to say "cheap" and "high voltage" in the same breath?!
murdnunoc is offline Find More Posts by murdnunoc
Old Jan 25, 2010, 11:10 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Thanks, Kid!
I might try the 480 in my hotliner.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 25, 2010, 11:11 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
murdnunoc,
Gary's new 28mm mount will take up to 30.25 mm. (in case you were already getting one)
http://www.customrcparts.com/motorMo...005&bannerID=9
__________________________________
Change of subject (from mount):
What did you do with the Medusa 28-56-1400KV V1, did you run that on 7S?
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jan 25, 2010, 11:25 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Gryphon
I haven't even run a prop on it yet.
It's out right now getting some very useful data harvested from it
Once it's back, I'll drill cooling holes, install the homemade rotor with larger magnets, and hopefully send it out to get more data. I expect the KV to drop while resistance stays the same, leading to crazy efficiency on 8S, where I plan to run it.
For now, the Scorpion 3026-1400 is installed and will hopefully fly next weekend. I may be hitting my ESC's RPM limit, as it's stuttering at high throttle on 7S. Not good if that's the case. I'm in the middle of resoldering all bullet connectors to make sure that's not the cause. Next step (which will happen regardless) is to get a better ESC. If that doesn't do it, I'll know a 10 pole motor just won't work for me if I want to run over 6S.
Old Jan 25, 2010, 11:58 PM
GryphonRCU's Avatar
Joined Mar 2008
murdnunoc,
I've been thinking of what to ask MEGA to add to his motor line up next.
One random idea was to max out power while using the Castle Creations ICE 100A which is good for 8S. (not ICE Lite)
For that I would need to see what specs might the MEGA 16/35/2.5 and 16/40/2.5 have....such as estimated KV and resistance.
2 motors, each in S and R version would give me 4 possibilities...so I have to think this through carefully.
That should be a very nice setup. Quality ESC (not most expensive), awesome 28mm MEGA motor, people can run a couple of medium sized 4S packs to distribute weight.
Choice of 7S with bigger prop or 8S with 1/2" smaller prop.
8S, 95A/100A is BIG POWER.
...I just don't see how any other top shelf motor (non 6 pole) could swing same size props with 28mm motor at same power levels & RPMs.
_____________________________________________
Tachometers:
http://www3.towerhobbies.com/cgi-bin...&I=LXPT31&P=ML
Even cheaper in hobby city.....actually a recent post showed a VERY high RPM tach was available from hobby city.
Most all tachs top out at 32,000 RPM...but not that new one from HC. If anyone has a link for it, post it please.
Eagle Tree Data logger can read 6 pole 50,000+ RPM
Gryphon
Old Jan 26, 2010, 12:20 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
this looks like it. 99,999 RPM!
Good deal! My tax return wish list is building.
Still a lot to hang on to while at the same time trying to capture a snapshot of amps and volts, too, from a separate wattmeter. I like the Eagletree logger you mentioned.
The possibility of a 16/40/2.5 sounds really nice for HV stuff. 8S is usually more attainable than 7S since it's much more likely people have access to 4S packs they can series into 8S than a matching 3S and 4S set to series into 7S.
I have noticed it is very, very tough to come up with an 8S ESC. I've only come up with two candidates for my stuff. One's the Ice 100, and the other a Hobbywing 120A HV.
They just aren't out there, in any price range. Everyone tops out at 6S (which, in reality, is as high as most people would care to go, I guess.)
Old Jan 26, 2010, 12:29 AM
GryphonRCU's Avatar
Joined Mar 2008
Yeap, that's it.
I hope you'll spend that extra $20 for the 150A data logger as compared to the 100A Logger.
Gryphon
Old Jan 26, 2010, 08:12 AM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Emax 2812 , 7x6 prop , 30 amp esc 2200mah 11.1v lipo: flies fine , i even have a copilot on there which is just dead weight really and i should remove it , flight times are quite short even though im not using the throttle all of the time , speed isnt too slow and she flies sell enough at half throttle. Need a few more flights to see if i want to keep it this way/try diff props but at least i know she flies.
scousethief is offline Find More Posts by scousethief
Old Jan 26, 2010, 08:22 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
ScouseThief,
Glad to hear it worked!
If you're OK with dropping some of the speed in favor of longer flight times and better climbing/fun flying, you could run a 7x3 or 7x4 prop. The APC-E props will draw more current and produce more power than equally sized Sport props.
Old Jan 26, 2010, 11:21 AM
Joined Jan 2006
Thanks murdnunoc , ill order some more props and try some more see what i can work out , it may be that they cheapo esc cutting out too early on the lipo , see what i can find out
Old Jan 26, 2010, 11:37 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
ESC I designed and manufactured
Look at what I came up with today. By my calculations, which 60% of the time are right every time, it should be good for 1,000,000,000 amps
Here I come stryker record
Old Jan 26, 2010, 12:13 PM
GryphonRCU's Avatar
Joined Mar 2008
Thekid3418,
Your calculations are right in this case, except you left out 1 word: "Pico"
..., it should be good for 1,000,000,000 Pico amps
Gryphon
Old Jan 26, 2010, 12:15 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Gryphon, you don't take into account the distinct lack of copper in the board. This new technology, perfected by yours truly, results in the ESC not conducting ANY heat
I can promise you, from my initial testing, that it wastes 0 watts in typical usage
Kid
Old Jan 26, 2010, 05:08 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Kid,
Let me know when you put these up for sale.
Is it rated for 80 cell?
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
