Old Jan 22, 2010, 12:48 AM
customrcparts is offline
Find More Posts by customrcparts
customrcparts's Avatar
Renton, WA
Joined May 2009
The motor mounts have been listed.
Gary
customrcparts is offline Find More Posts by customrcparts
Old Jan 22, 2010, 08:44 AM
finster is offline
Find More Posts by finster
finster's Avatar
Michigan
Joined Feb 2006
Check out this toy for the guy who has everything...
finster is offline Find More Posts by finster
Old Jan 22, 2010, 09:40 AM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
sweet , but can you get one in yellow ?
scousethief is offline Find More Posts by scousethief
Reply With Quote  (Disabled)
Old Jan 22, 2010, 05:28 PM
Joined Jan 2006
If not building for speed : Do you guys think the stryker could be flown using an emax 2812 1500kv outrunner motor ?
Im perfectly happy with my 3900kv turnigy inrunner , i was just wondering if the motor was powerful enough , i have a couple spare as i use them on my swift , divinity and my toro wings.
Just sedate-ish flying if i want to go fast ill use the turnigy.
What do you think ?
Old Jan 22, 2010, 05:37 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
"Here, Honey...
Hold the fire extinguisher while I set the radio on the ground and light up these turbines."
murdnunoc is offline Find More Posts by murdnunoc
Old Jan 22, 2010, 06:16 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
What do you think ?
the stock motor was around 1880kv, so ur fine just dont make it too heavy
a lot of people build light strykers and fly them indoors!
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Jan 22, 2010, 06:43 PM
Joined Jan 2006
Ill give it a try , cant hurt , i only want to see if it can be tamed , something inbetween the light stryker and stock would be more than enough.
Old Jan 23, 2010, 03:14 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
The stock motor is LISTED @ 1880kv, it is actually more closer to 2200
What do you think ?
A 1500 kv motor would need a much different prop setup than your 3 cell 3900kv setup is now, you will probably have to start using slow fly props.
If you try 3 cells with 1500 kv, you will need a BIG prop with little pitch because you will not have alot of RPM's spinning it, and you will need all of the thrust you can generate to get her in the air.
To fly slowy-sedate-ish like................pitch could be kept low with an 8 inch slow fly prop if you are staying with 3 cells.
moparmyway is offline Find More Posts by moparmyway
Old Jan 23, 2010, 03:41 AM
Unsullied_Spy is offline
Find More Posts by Unsullied_Spy
Joined Feb 2009
I read somewhere that props bigger than 6 inches can cause prop-strike issues that bend motor shafts, is he going to have an issue with bending shafts if he goes to an 8" prop?
Unsullied_Spy is offline Find More Posts by Unsullied_Spy
Old Jan 23, 2010, 04:58 AM
Joined Jan 2006
Im going to try a 7x6 prop first as its what i have handy. The motor is quite a bit lighter and the battery is 100g, ill give it a try, if i dont like it ill just slap the 3900 back on.
Old Jan 23, 2010, 02:26 PM
ender707 is offline
Find More Posts by ender707
ender707's Avatar
Sacramento, CA
Joined May 2009
Landing Speed is also a factor here. I had a shaft bend using a 7 inch prop, but I was using a heavy setup (~30 ounces) so my landing speed was quite fast compared to a Stock Weight Stryker.
I would imagine a Lightweight Stryker using an 8 inch prop can still have a slow and floaty landing. Now if the shaft on that motor is only 2.3mm, who knows...
ender707 is offline Find More Posts by ender707
Old Jan 24, 2010, 12:54 AM
finster is offline
finster's Avatar
Michigan
Joined Feb 2006
I put my strykers up for the winter and made a new toy for the snow...vid of my 2K Twister
Old Jan 24, 2010, 08:45 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Would running a prop saver (rubber O-ring type adapter) be a possibility on that 1500kv motor and slow flyer props? That would help immensely with the bent shaft issue.
I just don't know for sure what kind of RPM they're good for. The 13K or so on 3S with that motor may still be too much.
Old Jan 24, 2010, 09:48 AM
NOTAR 600 is offline
Find More Posts by NOTAR 600
ohio usa
NOTAR 600's Avatar
Joined Nov 2007
That looks fun finster. Very original. How did you make the augers? At first they looked like plastic soda pop bottles.
NOTAR 600 is offline Find More Posts by NOTAR 600
Old Jan 24, 2010, 11:20 AM
finster is offline
finster's Avatar
Michigan
Joined Feb 2006
NOTAR 600-
Yup...it is 2-liter pepsi bottles...I can only give it 1/4 throttle rite now but its alot of fun to drive...
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
