Old Nov 25, 2009, 07:21 PM
Joined Nov 2009
ok so now it is shutting off and i put it on the watt meter...and it was shutting off at 23amps so it is not over amping
bigdog5332 is offline Find More Posts by bigdog5332
Old Nov 25, 2009, 07:23 PM
York,PA
Joined May 2009
hey thanks! to bad i use it as a beater! haha..i guess what else is a stryker really built for? cheap as hell and super fun
yoshgixxer is offline Find More Posts by yoshgixxer
Old Nov 25, 2009, 07:24 PM
York,PA
Joined May 2009
stupid question i guess... but did you try another motor??
Old Nov 25, 2009, 08:14 PM
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by bigdog5332 View Post
ok i have a problem...with the arc 28-47-2...when i go full throttle, it will shut itsself with the thunderpower 25c 2200 mah and it was only pulling 43 amps with the apc 6x5.5 and it was shutting off even with the 6x4e
o and i have a 60 amp castle esc
thanks
bigdog
Lets forget about the readings you are getting from the wattmeter for a few minutes......
Is it a Phoenix 60 ?
Did it emit any beeps immediately after shutdown ?
Can you do it again and count them to be sure ??
It should repeat the series of beeps after a short silence (no more than 20 seconds) then, if you could please post the beep/flash count, that would be greatly helpfull here.
moparmyway is offline Find More Posts by moparmyway
Old Nov 26, 2009, 01:20 PM
Joined Nov 2009
hey mopar...i figured it out..my tp 2s 2200 went bad.....but i had a terrible incident today while flying....i had a stock airframe except i had a piece of carbon fiber running about an inch infront of the motor mount....i was flying on 3s with a 7x5 prop and i wad comming out of a high speed dive and as i pulled up(like i had many times before) but then my left elevon ripped off...i was using the hs82mg servos and the thing just drove its self into the ground from about 150ft and about 50 ft of that fall was inder 3/4 power before i could react to it poping off but what should i do because it bent the motors shaft it is a arc 28-47-2
thanks
bigdog
Old Nov 26, 2009, 02:23 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Looks like the kv of my Medusa 28-56-2800 is more like 3150 under 3s voltage. Sounds pretty close to what I was expecting, so its time to have some fun with it!
Thekid3418 is offline Find More Posts by Thekid3418
Old Nov 26, 2009, 03:25 PM
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Thekid3418,
That motor is a fantastic 3S motor in a Stryker.
If V2 then Sweeeeeet.
If original version, then it needs cooling vent holes drilled on both ends, OR you better keep to 1100W for short duration.
That power level is what my friend ran, but later burned the motor when over propped on 4S.
1100W is not set in stone; it is just what my wattmeter showed during his maiden. This was roughly double his last motor and he was shocked.
If looking for a 4S motor, you can buy better suited motors for a Stryker due to its high KV (even if V2).
__________________________________
Happy Turkey day to all who celebrate.
Gryphon
GryphonRCU is online now Find More Posts by GryphonRCU
Old Nov 26, 2009, 04:59 PM
What goes around......
feefo's Avatar
Staffs, UK
Joined Apr 2009
Are ARC motors available outside the US? Get hit by customs AND excessive charges from PO when stuff comes from USA, which sours the deal.
feefo is offline Find More Posts by feefo
Old Nov 26, 2009, 05:49 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Originally Posted by GryphonRCU View Post
Thekid3418,
Gryphon
It is V2, and it'll really only be doing stryker duty to annoy people with the rediculously high RPM It actually has a GB on it currently. Its sort of strange to see a 28mm motor with a 16x10 prop on it as I was testing earlier .
Old Nov 26, 2009, 07:03 PM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I can't wait to finish my new stryker, it's been 2 months since I lawn darted my last one.
The stryker has got to be one of the best things for the hobby in the past 5years, so much fun.
Hopefully santa will bring me a Mega 16-25-2 to try out in my new one.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Nov 26, 2009, 09:50 PM
Joined Nov 2009
right now i am kind of sick of strykers....i dont want to glass it but i want something over 100 and i had 4.5 good flights and the last half of the 5th one was that bad one where the elevator ripped of doing close to 100 and it probably hit the ground at 80 noes in with no up
Old Nov 26, 2009, 11:20 PM
gilbert AZ
Joined Oct 2007
I tried finding the answer to my question but no success.
has anyone tried a park 400 type out runner on the stryker. if so how did you mount it.where did you get mount and what prop did you use.
also how many amps did it draw..im trying to use a 4s A123(1100 mAh) which is roughly a 3s lipo equevelant pack when under load, in the stryker. these cells will sustain a 20c discharge so I was wondering if a cut down prop will work with this type of batt limitation
INCARUS is offline Find More Posts by INCARUS
Old Nov 26, 2009, 11:24 PM
gilbert AZ
Joined Oct 2007
Old Nov 26, 2009, 11:26 PM
gilbert AZ
Joined Oct 2007
11...............
Old Nov 27, 2009, 11:20 AM
Victim of C.D.O.
murdnunoc's Avatar
Roanoke, Texas, USA
Joined Oct 2007
INCARUS,
Most outrunners require a motor mount other than a stock Stryker C mount.
The most common successful ways to do it are:
Angle bracket mount
The motor mount area of the plane's body will need to be modified with reinforcement in the form of a plywood plate or fiberglass to distribute the pressure of the mount. You'll also need to reinforce the bottom of the plane since you'll be running bolts through it.
Here's a homemade one I'm running on my Stryker.
You can also use a stick mount, also listed on the first link above. It mounts to a 10mm square stick that you bury/glue to the rear part of the fuselage.
Another method that works if your motor has the prop shaft on the opposite end as the mounting holes is to simply mount it to the rear side of the Stryker's motor mount. This moves the CG aft, so you'll have to compensate for that by moving batteries forward or using a heavier battery, but it also moves the prop back from the body, resulting in better prop efficiency.
BTW, 1100mah will only be OK if you plan on running a very lightweight, efficient, slow flying setup. What 400 size outrunner are you planning on using? Some great fun flyers have run on low kv motors (guessing 1200-1600kv) and slow flyer props.
murdnunoc is offline Find More Posts by murdnunoc
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
