Illinois
Joined Jan 2005
Yeah, The inverted harriers are very cool! If you have enough elevator throw (move in a hole?), try the inverted near flat spin, down to near the ground, then pop it into an inverted harrier on the deck... Very cool. Ussually, to get into the inverted flat spin, approach stall inverted and go to full down elevator, and partial aileron in one direction.... Play with the amount of aileron with full down. Little or no power. Have Fun, David |
Crashed today...
I took the day off and decided to get a flight in this morning. The flight was going well, maybe one glitch. My battery was out of charge and I began to setup for my final. This a roll from a few hundred feet, a dive, then a glide across the field to the landing. In the dive I got a glitch and the plane shut down. I just stood and watched the crash. Luckly it started to pull out on it's own, but the there was still a lot of damage. It is repairable.
I stopped by the hobby store to look into parts, and the guy their took a look at the plane to see if he could see why it shutdown. This is what he found: -The wires for the motor were kinked baddly and wrapped around each other -The battery wire from the speed control to the receiver was wrapped around one motor wires -The antennae was wrapped around one of the motor wires and the speed control We straighted the wires out and rerouted some stuff. I am going to fix the plane this afternoon and see later if this helps take care of the glitches (which happened at full throttle or at the end of the run), and the speed seeming slower than it should be. |
LeadSled,
Sorry to hear about your flight. I hate it when the equipment gets ya. Ya might want to hold off on fixing anything. I would shoot an e-mail off, or make a call to ParkZone, and see about a complete replacement.Unless you bought it at the hobby store, in which case I would let them do the return. From what the guy at the habbitual store found, I would say there were assembly problems that caused your glitch. Yes you should have found and fixed this stuff in your pre-flight, but this was sold as charge and fly, not check our work, then charge and fly. From the amount of glitches you have had before this happened, you should have stopped flying it sooner. What if that glitch caused your plane to hit someone? I think their reaction would give the community a good feel for the company and how they stand behind the merchadise they sell. I would tell them you are documenting this problem online if they give you any grief or not. Range test, and don't fly if it fails. Good Luck, Rich |
I already fixed the plane. I will do some testing later. The guy at the hobby store rerouted everything, and I fixed the structure. A little glue, and new elevon, glue the cockpit, and it is back to "normal".
I am just taking this as a learning experience. Unless someone had told me I would not have known about the wires. Now I know, and hopefully the plane will be better. As for indangering people, all but my first flight have been in a large open area about 300 yards long by 200 yards. It is fenced off, and only has one entry and exit point. It is an AMA sactioned field that is used by sailplanes and electrics, and I have been flying before other pilots show up and keeping the plane in the boundrys of the area, just in case I mess up or run into a technical problem. I was planning on letting the plane break cover and be introduced to the others, but that will have to wait till after more testing. My only thoughts on the build quality is that you get what you pay for. Most likely I will learn more with this plane, then build a second with a Spectrum system and better components. I wonder if anyone else has looked under the "hood" to see how their planes wires are routed. |
Got me A 'C" & thought s on noise rejection
Lead sled,
I predicted this was going to happen when you were describing you initial flight glitch s. I'm sorry you crashed ......it is a tough plane and easy to fix. I had THE exact problems you had with my F-27B 's.............it is the position of the ANTENNA WIRE mostly and then a bit postion of the reciever and other cables, inrelation to the antenna. There may be shielding problems on the RX that allow the anteena to pick up noise .........anyway it is mess. Most of the time I could IMPROVE this sort of hated irratic behavior by messing with the anteena under the canopy. SOmetimes it was only mm's I moved it away or in a certain direction ........this effected its ability to COLLECT noise. Other PZ planes show less tendency , it has to do withe arrangement of components and the tight compartment of the F-27 If you can get the wires sorted out JUST SO, you might go glitch free for good periods. It can be a trail and error. I used to put the plane out 100 feet and watch it best I could on ground to see if I could get it to glitch , and keep screwing with it till I got it right. THAT SUCKS. to much headache I think I warned you that this can be annoying trait with this plane. I bought my Stryker "C" PLUG N PLAY yesterday.......before the hurricane... When I'm healty enought to fly it in a few weeks ........I will have a SPEKTRUM DX6 reciever cramed in it tangled wires and noise won't be a worry. A DEANS connector ( I hate that dumb connector they put in it) for batt and a TP-2100 LIPO. THE DX is IMPERVIOUS to all noise this plane is capable of producing.. Install a DX6 RX and You can also cut that stupid antenna wire plum off that hangs frailing about and brings many a good rc plane down tangled in rudders , snagging tree limbs or what ever else ect. , causes drag and other problems . The DX operates in a freq range ABOVE all the noise crap that is happening around it. I fly near airforce base areas, around cell towers , you name it ..no problems. Except when I DUMB THUMB and smash a jet.....but thats fault and I can live with that. I a use a 2.4gig DX6/rx in my MUTIPLEX TWIN JET ( another delta wingfoamie)....it was my test bed for that rx........ The RATS NEST of tangled wires in that plane is enought to make a seasoned RC pilot SCREAM But , it doesn;t matter one bit........I practiacally have the RX TAPED to the side of the ESC and I have NEVER HAD a glitch . I did everything YOU shouldn't do on purpose trying to screw that RX up and It doesn't care. The Spektrum RX makes building a plane ALOT easier, you can plunk that RX about anywhere you like........I have 10 of them in every postion in all kinds of planes ( except gas)and can't get seem to get a failure. It also allows Alot of flexibility in the placement of components and a big headache out of the build too.I now figure my DX6 has saved me many a plane and paid for itself over ten times in the past year. With the speeds of the 'C" model and fast jets and pushers like my TWIN -JET , a glitch can shoot you down in a heart beat as you now know. You can't afford to loose control for even one sec with a plane like this . Airwaves were alot cleaner 20-30 years ago 72 mhz was ok...... we have these cool high-tech planes now.......time to use better technology....don't ya think? |
It lives
I flew the plane this morning, and had no glitches, and the plane flew very well. I guess straightening the wires out helped. It flew well with the repairs. I did notice a little gitter in the control services, but nothing that caused any problems. I could run the engine at max and no glitches. Overall it was a great flight. But, I am going to get a Spectrum DX6 for the next plane and avoid these problems.
Joined Sep 2005
I have a spektrum that I operate my glow aspire EP on, I get it around 2,000 feet in the air (estimated, spec out) with a 2m wingspan... spektrum radio does fine.
I have a stryker with an Align 2500kv, i'll be racing a C tomorrow and see what happens. It I throw a 5.5 pitch prop on it i'll be doin 145 mph pitch speed, but that might burn up the motor... |
Hey guys,
I just picked up a ready to fly version of the Stryker C. I was wondering if there are any mods to do to it? I know in the B version when you put a brushless motor on it you needed to add a carbon rod to the bottom to prevent wing flex and fiberglass the motor mount area. Are these needed here? Also planning on using a JR 6102 radio and a berg RX in it. Anything to know about that? Thanks a lot, -Mike |
| Thread Tools | |
| Discussion Parkzone F-27C Stryker | That can fly?!? | Parkflyers | 109 | Sep 26, 2012 10:54 PM |
| Discussion Parkzone's New F-27C Stryker | itspat | Parkflyers | 1 | Nov 08, 2011 07:56 PM |
| Mini-Review F-27C Stryker Review | That can fly?!? | Parkflyers | 27 | Jul 29, 2010 08:25 PM |
| Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug | WDP | Batteries and Chargers | 12 | Oct 26, 2009 08:44 AM |
| Discussion Coming soon! F-27C Stryker RTF with lipo and brushless | Solcat | Electric Plane Talk | 0 | May 31, 2006 12:34 PM |
