Old Jun 23, 2008, 09:28 AM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
Originally Posted by WorldStar40
I just brought a Styker F-27C has ribbs on the motor black, 25Amp Eflite ESC.
The motor shaft started slipping and burnt out the ESC. Had this all replaced and now ready to test fly.
Is the 25Amp ESC big enough for the stock setup?
Has anyone heard of the servo's stripping?
Shane
change the stock servos, they stand to glitch ALOT
and yes the 25AMP esc is big enough, but you can always go bigger
brian94066 is offline Find More Posts by brian94066
Old Jun 23, 2008, 10:22 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
WorldStar40,
The stock battery and ESC are near maxed out. All you can do is to upgrade to APC E 6X5.5 to increase your speed from 65 MPH to 72 MPH.
You better watch the temps of battery and ESC, especially now that summer is here.
Might need throttle control, with full throttle used sparingly.
The motor can give you more power, but you have to get rid of those two bottle necks.
Make sure that a new ESC is good for 4S and about 40A...I doubt you will prop above 35A though.
Good luck,
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jun 25, 2008, 09:21 AM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
i would go with CC phoenix 45 or higher
they're a little pricey, but they're worth it
Old Jun 25, 2008, 05:07 PM
Wingwrecker is offline
Find More Posts by Wingwrecker
I buy, I fly, I buy....
Wingwrecker's Avatar
United States, OH, Toledo
Joined Feb 2008
Gryphon,
The 40a Eflite v.2 I have only lists as being rated for a 3s lipo. Will it fry on a 4s, just not work or are they under-rating it?
Anyone else who knows is welcome to chime in as well.
Evvy
Wingwrecker is offline Find More Posts by Wingwrecker
Old Jun 25, 2008, 11:00 PM
GryphonRCU's Avatar
Joined Mar 2008
Wingwrecker,
Don't run that ESC on 4S.
It is not that it'll fry, because it can also handle 12 cell NiMh with is similar to 4S Voltage, but your main issue is the cutoff voltage.
*** Don't even fantasize about flying with it and then landing early.....I just had to say that because we all had such thoughts at some point, or known someone who did.
You will be sorry if you try it...not an option.
http://www.horizonhobby.com/ProdInfo...rushlessV2.pdf
Also the internal BEC (to feed receiver/servos) is not rated for that high voltage. 3S or 10 cell NiMh max.
________________________________________
The 40A PRO version is good for 6S, so is its switching type BEC.
http://www.horizonhobby.com/Products...rodID=EFLA1040
$10 more gets you the 60A PRO good for 120 MPH Strykers.
Gryphon
Old Jun 26, 2008, 05:10 AM
Joined Feb 2008
Originally Posted by GryphonRCU
Wingwrecker,
Gryphon
Understood. I'm not going to put my new 4s's at risk! I already have the ESC handy is why I asked. I have an 80a Mystery on the way but I need to get a UBEC for it. I'll be testing the readings with it before I take it up.
Old Jun 26, 2008, 06:45 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
I've been using the stock stryker motor, a 60 amp esc, 4 cell 2200 mah, and a 6x5.5 prop with great success. Any advice on a prop that will take me faster using this setup?
bracky72 is offline Find More Posts by bracky72
Old Jun 26, 2008, 02:03 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
yeah 6 x 4 will give you the thrust you need to go fast on 4s
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Jun 26, 2008, 02:13 PM
nwjt is offline
Find More Posts by nwjt
Permanently Signed Off.
Joined Nov 2007
Has anyone ever had to send a stryker or other parkzone plane back to ParkZone for replacement? If so, can you share your experience?
nwjt is offline Find More Posts by nwjt
Old Jun 26, 2008, 02:15 PM
retiredVTT is offline
Find More Posts by retiredVTT
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
I've flown a 16/25/3 Mega (kv 1800) on 4S 2200, 7/5 APCe, 40 amp Turnigy esc, it was a rocket before the wings separated in a dive.
This is an excellent esc with a switchable bec..
http://www.unitedhobbies.com/unitedh...eed_Controller
Gotta another one ready for Canada Day weekend...no dives this time..!
Bill
retiredVTT is offline Find More Posts by retiredVTT
Old Jun 26, 2008, 02:48 PM
GryphonRCU's Avatar
Joined Mar 2008
bracky72,
DO you have wattmeter readings?
How hot does your battery, and motor get?
What are the ESC and battery ratings?
Are you looking for more speed or more climbing?
Is risking acceptable to you?
We are waiting to get some data in.
gotboostedvr6,
bracky72 said he has stock motor, 4S, 6X5.5 and wants to go faster...6X4 will not fly faster.
nwjt,
My experiences returning to Horizon Hobby has been GREAT, except that it usually takes from 3 weeks to a month.
I learned to have spares to avoid down time.
retiredVTT,
16/25/3 is a 1700KV motor. My same setup on 3S would get radared at 72 MPH, your 4S must have been solid 20 MPH faster in level flight.
I bet your dives placed you at 100MPH or faster.
Did you have C.F. running from left to right side across the middle, or at least tape running the same way?
During acceleration and climbing, or static tests you would be pushing your pack, but at high speed the amps will unload nicely...pretty effective use of your pack.
If you want more power swinging more aggressive props consider 2500 to 3300 cells.
My brother loved it when he upgraded (2) TP 4S-3300 25C packs. For max climbing he used the same APC E 7X5. For top speed APC sport 7X7, I know APC sport 7X8 would not be an issue at all. He ran Hyperion 80A ESC.
Now has TP 5S-3300 25C
Gryphon
Old Jun 26, 2008, 02:58 PM
bobf is offline
Find More Posts by bobf
Sparky "Electrics Rule"
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
My friend has a Stryker with a Great Planes Ammo 28-56-3200 In-Runner Brushless Motor and using a 5 x5.5 prop. He has a speed senser in it. It has been measured a speeed of 114.5 mph. It is really cool.
bobf is offline Find More Posts by bobf
Old Jun 26, 2008, 03:21 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
is that in a dive?
what battery was he using?
Old Jun 26, 2008, 03:24 PM
bobf is offline
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
Yes in a long dive. He uses a TP extreme 2200 3s1p which gets very hot.
Originally Posted by brian94066
is that in a dive?
Old Jun 26, 2008, 03:38 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
wow
maybe prop it down a little?
those are expensive batteries
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
