Old Jun 15, 2008, 10:16 PM
nwjt is offline
Find More Posts by nwjt
Permanently Signed Off.
Joined Nov 2007
Originally Posted by GryphonRCU
nwjt,
Better not roll too hard or the cam and its stand might tilt to one side.
Then back to the drawing board! Probably need to use balsa. The other guy had his cam stand straight up, but that would be a lot more drag. I had mine lay down and rotated the lense. Less drag but more force in a roll as more weight is on the outside.
nwjt is offline Find More Posts by nwjt
Old Jun 15, 2008, 10:20 PM
catahuladave is offline
Find More Posts by catahuladave
Bauwingmiester
catahuladave's Avatar
Florida Gville
Joined Jul 2005
It flies great.
I did not have anyone there to run the camera we had rain off and on all weekend. I loaded two 3s2100HV MaxAmps packs in it after a range check and some radio settings, WOT and frizbee threw it by the left wing tip. I watched it dip down but with a little elevator it starting lifting up and it was gone as the started flowing better. I was amazed with how the speed picked up and it was cruising at 80mph with fairly good thrust for an EDF. The sound of the two EDFs reverberates back and forth with a high pitch whine. I have to fix the cone on one its not balanced just right. New Pretty cool flew perfect first flight no adjustments need at all. WOT was addictive and a blast but it flew just fine at half throttle. I will get some video next time.
I am so proud of it here are finished pictures of it.
DSS "catahuladave"
catahuladave is offline Find More Posts by catahuladave
Old Jun 15, 2008, 10:26 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
nwjt, you could've lay it down right on top of the canopy, less drag that way
with the CG more infront it will have less sensitivity in pitch but it will fly pretty smooth
or put it on the CG, laying down and raise it up by about a centimeter
dave, one word... NICE
brian94066 is offline Find More Posts by brian94066
Old Jun 15, 2008, 10:34 PM
nwjt is offline
Joined Nov 2007
Of course there are better ways to mount it, BUT, this orientation/view of the plane is so great. Its more of a 3rd person view than a 1st person.
If it works I will pst the video and maybe then you will see. It looks more realistic.
Old Jun 15, 2008, 11:34 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
oh ok, i get it now ^_^
Old Jun 16, 2008, 05:46 AM
Wingwrecker is offline
Find More Posts by Wingwrecker
I buy, I fly, I buy....
Wingwrecker's Avatar
United States, OH, Toledo
Joined Feb 2008
Wingwrecker,
Best solution would be to put metal gears in it.
Although Hitec 65MG on 6V makes 30.5 o.z. of torque, the hitec 81 on 4.8V still makes more torque at 36 oz., 41 o.z. on 6V.....so do not change your servos unless the crash damaged them beyond repair.
***Were you running stock push rods to connect the servo to moving surface? They flex too much and will further make your elevons useless. Figure out how to make and install 2-56 sized rods and clevices.
When/if you will go for another upgrade sometime in the future, hopefully you would still have the 4000-7000 words that I wrote you in 2 or 3 PMs.
Edit: I tried to get you to buy a different motor.
Yes but like I said before, I just wanted to try the cheap one first before jumping into Mega Motor-land. And I still intend to get the 16-25-x at some point. This GH motor will find a home in something, I'm sure.
I did find a deal on HS-81mg's for 17.99, but I don't know the vendor so I will be making a phone call today to try and verify their existence. If I'm not satisfied then I'll get the gears and do it myself.
And for sure, my next build will be reinforced. I could use some reference pics of others to guide me. I'd really like to keep weight to a minimum, of course.
Wingwrecker is offline Find More Posts by Wingwrecker
Old Jun 16, 2008, 05:56 AM
Pudknocker71 is offline
Find More Posts by Pudknocker71
Pudknocker71's Avatar
Debary, Fl.
Joined Oct 2007
Originally Posted by Diggs
I have had very good luck painting Elapour and EPP with the cheap cans of paint from Walmart. It seems to cover very well. Test it on the foam you are painting first, I am certain it would eat up some depron, but the "EPP type" foam seems to be fine with it.
Diggs
Thanks for chiming in. The Colorplace paint works very well. Needed two coats though. Left wing will be Green. Center and bottom black. Bottom w/ invasion stripes. I'm kinda mixing US and Luftwaffe paint schemes. I have some leftover malaise crosses from another GWS kit. Might go with a yellow nose. Shouldn't be any orientation problems when I get done.
EDIT ...still the last post so here goes.
Had to change the paint scheme a little. Blue tape is taking off the paint. No black down the center of the fuse. No biggie.
Pudknocker71 is offline Find More Posts by Pudknocker71
Old Jun 16, 2008, 08:54 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
new fins!!!
made out of a dollartree foamboard
feels alot lighter, no bottom exposure so it won't rip off on landings
Old Jun 16, 2008, 09:21 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
That flat black looks good on foam IMO. I used it on my funjet and really liked the way it looked.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jun 16, 2008, 09:30 PM
Hellsiege is offline
Find More Posts by Hellsiege
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
Looks great bud! Can't wait to see the video.
DSS "catahuladave"
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Old Jun 17, 2008, 10:24 PM
nwjt is offline
Joined Nov 2007
See Post #2264. need to put the mount back more towards the motor. Tons of drag. It flew very stable, but much slower.
f-27c Stryker Unique Camera Angle (6 min 26 sec)
Old Jun 17, 2008, 11:09 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
the video quality and the sound is really good, nice
Old Jun 18, 2008, 02:05 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
nwjt,
Thank you for the video. Your plane still had good performance considering the added drag.
Quality of the video was pretty good. Keep them coming.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jun 18, 2008, 07:45 AM
MACH6 is offline
Find More Posts by MACH6
MACH6's Avatar
Darwin, Australia
Joined Dec 2007
Hi
Just thought I would post my machine.
Pitch vectored thrust and pitch/roll slab canards.
MACH6 is offline Find More Posts by MACH6
Old Jun 18, 2008, 11:15 AM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
your links do not work
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 11:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 08:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 09:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 09:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 01:34 PM
