Old Sep 26, 2006, 09:23 AM
Mr.Pibb is offline
Find More Posts by Mr.Pibb
Mr.Pibb's Avatar
Lewis Center, OH
Joined Jun 2006
Originally Posted by manuel v
My stryker.
manual,
Nice looking Stryker. Can I ask what type of paint you used? I used Krylon for plastics on my first paint job of a new body. At first I thought it worked well...then I noticed that the foam is now "bumpy", not smooth like it is from the factory. I think it swelled the styrofoam. We'll see how it performs...
Mr.Pibb is offline Find More Posts by Mr.Pibb
Site Sponsor
Old Sep 26, 2006, 08:35 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
For any type of foam I use acrylicas paintings of Wallmart. craft paint off $0.77 Dlls. 2oz. for some color in special. single I mix them.
Manuel.
manuel v is offline Find More Posts by manuel v
Old Sep 27, 2006, 03:38 PM
rich22304 is offline
Find More Posts by rich22304
rich22304's Avatar
Fredericksburg, VA
Joined Apr 2006
wow
rich22304 is offline Find More Posts by rich22304
Old Sep 27, 2006, 09:49 PM
LeadSled is offline
Find More Posts by LeadSled
Just here to fly stuff
LeadSled's Avatar
Everywhere
Joined Dec 2005
Wow, that is pretty cool paint work. Question. I had to finally retire my Stryker airframe. It looked like crap and after a run in with a fence, it finally cried uncle. I had two previous accidents.
But, even without the accidents, my Stryker did not maintain the factory clean look long, and after a few belly landings the surface started to get scared up. I notice this with my F27Bs. After about 10 flights they would get a little ratty, and each airframe was good for about 20 flight before it looked rough.
I am going to build another Stryker, but I would like it to last a while. How do you keep that new foam plane look....other than not crashing into things.
LeadSled is offline Find More Posts by LeadSled
Old Sep 27, 2006, 10:14 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Clear packing tape and hand catching.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Sep 28, 2006, 11:14 PM
That can fly?!? is offline
Find More Posts by That can fly?!?
Live, Die, FLY
Kalispell, in the Rocky Mountains
Joined Jul 2006
I have a good friend named Harley, he flys for Bob Violet Models (BVM). He told me one way to add strength is to mix white glue, and water, and apply one or 2 coats. As for the bottom, I have been experamenting with Aluminum plates. I put a DX6 and a new stryker body on hold, gonna try and get her running befor this weekend. Even tho my original stryker is falry beat up, still flys like a champ.
-Dustin
That can fly?!? is offline Find More Posts by That can fly?!?
Old Sep 29, 2006, 09:38 AM
ml0126 is offline
Find More Posts by ml0126
United States, MO, Sikeston
Joined Oct 2002
Battery ?
The Parkzone battery that came with the stock stryker C has a different balaning plug than my TP batteries. Does anyone have an adpater plug or know the wiring diagram of the parkzone battery?
ml0126 is offline Find More Posts by ml0126
Old Sep 29, 2006, 09:37 PM
LeadSled is offline
LeadSled's Avatar
Everywhere
Joined Dec 2005
Need some help. I am trying to move my F27C speed control, motor, and battery to my Airtronics computer radio and Hitec 6 channel receiver. When I get everything installed and hook up the battery, I can not get the engine to arm. I have servo control, and I get the "music" from the speed control, but I do not get the engine arm "tone" and control of the engine.
When I hook everything up to the Parkzone Radio and receiver it works normal.
Anyone know what I am doing wrong?
Old Sep 30, 2006, 04:34 AM
radralph is offline
Find More Posts by radralph
My first Build
radralph's Avatar
Vancouver WA
Joined Jul 2006
sounds like the throttle isn't arming for sure. Try reversing your throttle on the radio. You're entering programming mode.
Oops, forgot. Check the throttle trim too!
radralph is offline Find More Posts by radralph
Old Sep 30, 2006, 11:11 AM
Live, Die, FLY
Joined Jul 2006
any tips on installing the DX6 Reciver?
-Dustin
Old Sep 30, 2006, 11:38 AM
radralph is offline
My first Build
radralph's Avatar
Vancouver WA
Joined Jul 2006
Why not place it where it suits your CG best? Double sided tape will do it.
Old Sep 30, 2006, 02:27 PM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
Hey guys, I have a E-flite Six series 2700KV motor kicking around....I had it in my PZ mustang till....well, it wasn't pretty. Anyone have any idea of the perfomance I might expect to see if it put this in my Stryker. As I understand the F-27C uses a 1800kv motor and gets 79mph... Acording to the Horizon page, I could a 5 x 4 to 6 x 5.5 direct drive prop with the 2700kv. I have an F-27A, which I would convert over to 72 mhz. I'm would be using a tp-2100 mah 3 cell. I'm thinking 90-95 mph, but not 100% sure, really just guessing. Thanks for your time.
Dora Nine is offline Find More Posts by Dora Nine
Old Sep 30, 2006, 02:50 PM
lowdive is offline
Find More Posts by lowdive
lowdive's Avatar
anaheim, ca
Joined Apr 2005
slap that motor on a stryker and head for the sky! it only takes a few minutes and you'll have your answer in no time
seriously, though, if an 1800kV motor can push the stryker to near 80mph i'm pretty sure that a 2700kV will do quite well. i'm running a mega 16/15/4 (2200kV) on 10cell pack of ib1200s (NiMH) and i barely kept up with my buddy's stock stryker C. i blame a lack of full charge on my part, but i also know the lipo output/weight benefits were beating me down.
considering how easy it is to swap gear on these, i would have been done testing a different motor before i finished typing out the question here..
oh, i haven't found a prop that i like more than the apc 6x4e
lowdive is offline Find More Posts by lowdive
Old Sep 30, 2006, 04:51 PM
Dora Nine's Avatar
United States, NH
Joined May 2005
Yeah...well right now I am away at work...tugboat...so I am trying to decide if I wanna spend the money on things like HS-81 MG's or not... I'll be home in a few days. If I can push my stryker to the near 100 MPH range...seems like that could be fun and most definately worth it.
Old Sep 30, 2006, 05:29 PM
Elk Grove, CA
Joined Sep 2002
Trust me....you need the HS-81MG or HS-65's. The HS-55's will work only until you land with the elevons down one time and you will strip the fine little teeth on the 55's. They can be replaced but it is a PITA and your flying is done for the day. Once I went to the 81-MG's it has been rock solid and have never touched the servos again.
As far as the 2700Kv motor....that is waaaaaay hot for 3S1P 2100 mAh cells; even good ones. I am running a 2500Kv Medusa on a Multiplex FunJet and it is FAST as well as pulling down close to the limit of the MaxAmps 2100HV cells (equal or better than the TP-2100 PL's IMO). This is on an APC 6x4.
You could drop down some in prop size, but the thrust will be less causing problems on launch....but it will probably be veryvery fast. MotoGuess says 35A on a 6x4, or 30A with over 100 mph tip speed (but very stalled at low speeds) on a Graupner 5.5x4.3. It would be a challenge to hand launch but once on step it would really go. Of course you could just use the 6x4 and limit the WOT....yeah sure
FC
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
