Old Feb 20, 2008, 11:16 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
for speed around 70-80 MPH
go with the JGF 400DF on 6x4E
it's pushing the motor a little
but that was my set up and it HAULS!!!
i think vinnie's a little conservative on his motors, the 400DF never gets hot with 6x4 and 3S 2100, and i was using the stock 25A ESC too
brian94066 is offline Find More Posts by brian94066
Old Feb 21, 2008, 09:57 PM
snoopy is offline
Find More Posts by snoopy
Microbursts hurt.
snoopy's Avatar
United States, MD, Mt Airy
Joined Jun 2005
I really like this Stryker. :-)
I'm running a Mega 16/15/4 on APC 6x4E, CC PX 35, FMA 2100 3S (18C). I'm pretty happy with that, comfortable zipping around full throttle. Keeping the same batt & ESC, is there another motor I should try? Or, should I give a 4S a try? I'm curious if there is one component in that setup I could tweak (trying not to spend too much).
Pretty good climb:
F27 Stryker Brushless Mega ACn 16/15/4 Launch #1 (0 min 30 sec)
Decent speed:
F27 Stryker Brushless Mega ACn 16/15/4 Flyby #2 (0 min 28 sec)
snoopy is offline Find More Posts by snoopy
Old Feb 22, 2008, 06:27 AM
finster is offline
Find More Posts by finster
finster's Avatar
Michigan
Joined Feb 2006
I run the same setup and the cheapest thing would be a 6x5.5 prop...thats about max for a 3s and gives best performance...Going 4s you will need a BEC and run a 5.5x4.5 prop...much better than the 3s...I do have a couple vids of my 3s and 4s on video page here
Im looking to collect a bunch of stryker vids and add them to my video page...If anyone has a new vid to share, send it to me...
finster is offline Find More Posts by finster
Old Feb 22, 2008, 02:20 PM
davemac2 is offline
Find More Posts by davemac2
Sacramento, CA
Joined Jan 2007
finster, I was looking at your site on your stryker and mega stryker builds and noticed you chose not to glass the mega stryker. Was that decision based on reducing weight? How durable was the glassed stryker?
thanks,
dave mc
davemac2 is offline Find More Posts by davemac2
Old Feb 22, 2008, 04:56 PM
hyperdyne is offline
Find More Posts by hyperdyne
Doppler wrangler
hyperdyne's Avatar
Joined Sep 2007
I am now running my stryker C with a mega 16/25/2 motor, 80A ESC, FMA co-pilot, and 6.5x6.5 speed prop.
On 3s packs, she goes around 105-110mph. On 4s its a screamer, fastest run was 128mph!
hyperdyne is offline Find More Posts by hyperdyne
Old Feb 22, 2008, 05:10 PM
finster is offline
finster's Avatar
Michigan
Joined Feb 2006
I was trying to show that 2 CF rods is all you need for that setup...I did use FG on the bottom just to keep it from getting scratched up during landing but probably didnt need it...Adding more weight and speed you would need to make it stronger with FG or extreme tape and CF rods...I seen others going crazy with CF rods making it look like a spider web thinking its stronger...more isnt always better...I added a CF rods section to my web site for a little more info...I like the FG method cuz its strong, paintable and keeps the plane stiff but it wont save you in a high speed crash...others say extreme tape is better...I havent tryied tape yet...
Old Feb 22, 2008, 06:20 PM
I.C.O.N. is offline
Find More Posts by I.C.O.N.
I.C.O.N.'s Avatar
Twin Cities, MN
Joined Feb 2006
hyperdyne, What size 3S packs are you using?
I.C.O.N. is offline Find More Posts by I.C.O.N.
Old Feb 23, 2008, 01:16 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
VIDEO!!!!
what were your amp draws and RPM?
Old Feb 23, 2008, 06:20 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Originally Posted by Diggs
His wicked 450 2700KV would work, but you would have to use a smaller prop.
http://www.donsrc.com/cart/index.php...d&productId=12
He has test data. As much as I like Don and his products, I think the ARC is the better choice here.
I have had several people use this motor on a Stryker. The Stryker does like a bigger prop though like a 6" prop. It needs thrust as the airframe is kind of big. I have two prototype 2200KV motors that may be a better fit. Dr.Kiwi tested one but it turned out this had a defect and was scrubbung the stators. But the numbers were not all that bad I thought.
The Don is offline Find More Posts by The Don
Old Feb 24, 2008, 02:43 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
they are outrunners right?
Old Feb 24, 2008, 08:04 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
Yes use a really good battery> 2200 20c + and a 6 x 5.5 and it will rip.
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Feb 25, 2008, 11:44 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
my old 400DF really rip
but this seem to be more powerful
gotta try this motor on a new fuse
Old Feb 25, 2008, 11:57 PM
GFBurke is offline
Find More Posts by GFBurke
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Ok, I have my Styker kit.
Orderd:
motor (wont use the ESC..)
APC 7x6-E
I have:
Berg 4
CC 25A ESC
1500 15C 3s
2x HS55s
Think this should move ok? Once I get used to things I'll hit up Vinnie or Don for some more power.
GFBurke is offline Find More Posts by GFBurke
Old Feb 26, 2008, 12:40 AM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
first of all that ESC is a good one why not use? it will hold 35 amp bursts.. ask me how i know
You need a 6 oz lipo to balance a stryker properly with that motor mounted behind the mount..
Any 2200 3s will do the trick or you can add some lead weight to the nose or move the motor mount forward like an inch or so or move the battery forward 2" or so.
The apc 7x6 prop works well but if you trim it to 6.5 x 6 or 6.3 x 6 its way better amp draw is really low.
a 5x5 and 4s will give you at or about 90 mph or so
Old Feb 26, 2008, 12:44 AM
GFBurke is offline
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Right on. If I can get away with these lipos that would be cool for now. Ya, how does one mount this motor? My kit has this black H already bolted on.
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
