Hi !
I've just purchased a Stryker airframe only today ! Now I'm a bit confused with all the brushless motor setups found here. I have a 3s 2100Mha 20c Lipo anda a 40Amp speed controller. I would like my stryker to go as fast as possible with this battery, so what motor should I buy and what propeller from hobbycity ? Thanks in advance. Ruben |
Saint-Méen le Grand (BZH)
Joined Jan 2007
![]() my best configuration is HXT 2445 and 4.75x4.75 cam speed prop
View Post |
| kongkong2001 | |
A moderator felt this post violated the following rule: Trolling (Obnoxious behavior).
It is temporarily hidden while kongkong2001
edits it.
Show it to me anyway.
![]() Check out the email I sent you, there are lots of options there. The ARC seems like a really good deal and should fit in the stock motor mount, I think??? Also the HXT from Hobby City is nice and cheap too. There is a 2200 and 2700 KV version. I think with the 25amp ESC, you need to stay lower on the KVs with a 6x4 prop so you don't burn it up. Also, I bet the ARC would take some abuse later if you upgraded the ESC and battery. The 4 turn has a pretty low amp draw when using a 6x4. Should have nice thrust, but won't be much faster than a stock stryker. Diggs |
" like 70-80mph max. I'm only used to about 40-45mph right now. "
I started with the Stryker B which flew about 40-50mph. Then I switched to the "C" and found that #1 It's a big change, whey faster but, easier to do all the things I wanted to do with the "B". I crashed my B all the time trying to get really high then dive to get some more speed. The C has all the thrust and speed right out of the box. You can fly slow like 20mph then rocket straight up at about 70mph. The box says it goes 80 but, it doesn't go that 80 straight line. The plane flies better in a little wind too. It seems to help the vert and straight line speed. |
Latest blog entry: Getting into 3D a little more
His wicked 450 2700KV would work, but you would have to use a smaller prop.
http://www.donsrc.com/cart/index.php...d&productId=12 He has test data. As much as I like Don and his products, I think the ARC is the better choice here. The 500T from JGF is another option, but again you need a bigger ESC IMO. That could be had from Don ![]() http://www.justgofly.com/tech500TH.htm#500T or slower but much better for amp draw. http://www.justgofly.com/tech_450T.htm EDIT: You will need a special mount if you go with an outrunner! The inrunners will likely drop in @ 28MM Diggs |
| Thread Tools | |
| Discussion Parkzone F-27C Stryker | That can fly?!? | Parkflyers | 109 | Sep 26, 2012 10:54 PM |
| Discussion Parkzone's New F-27C Stryker | itspat | Parkflyers | 1 | Nov 08, 2011 07:56 PM |
| Mini-Review F-27C Stryker Review | That can fly?!? | Parkflyers | 27 | Jul 29, 2010 08:25 PM |
| Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug | WDP | Batteries and Chargers | 12 | Oct 26, 2009 08:44 AM |
| Discussion Coming soon! F-27C Stryker RTF with lipo and brushless | Solcat | Electric Plane Talk | 0 | May 31, 2006 12:34 PM |
