Old Feb 05, 2008, 10:06 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by davemac2
And this brings up some interesting questions:
1. what is the best way to thin down the airfoil. Sanding?
2. How much thinning of the foam can u do before it becomes too weak?
2. How much weight does glassing add to the fuse on a per sq in basis?
dave mc
I can't answer these, but I do have a question for you. Why??
The Stryker is fine the way it is. If you want to really push something over 100 MPH, the Funjet is the way to go or a lynx with a pusher setup. Check out Episode #33 of ATTF. Vinnie of JGF motors talks about the Stryker and speed. He makes a lot of valid points. It is a fantastic plane, and is quick, but if you want something really fast, there are better choices than the Stryker.
Diggs
Diggs is offline Find More Posts by Diggs
Old Feb 06, 2008, 12:32 AM
3-DMan is offline
Find More Posts by 3-DMan
Inverted,that's howI roll
3-DMan's Avatar
Venutra. CA
Joined Nov 2007
Originally Posted by brian94066
a stryker will never get past 110 MPH even with 6S and a mega 16-25-3
let alone 135 straight
unless you shaved off all the unneeded foam, thin down the airfoil, glass it, put a neu 1110 in it and put it on 5 or 6S
Instead of making the covering super smooth which makes the air kind of stick and eventually slow the air flow over the wing, I have little dimmpels on the wing like a golf ball, this makes the air flow faster over the foil. And I did shave the air foil thinner and sharper to cut through the air more quickly. I also stiffened the plane by inserting a triangle of carbon fiber in the belly of the plane so in a dive or in level flight the wings don't flex up with dihedral which is being caused by lift. I haven't checked what wattege I'm pulling yet.
3-DMan is offline Find More Posts by 3-DMan
Old Feb 06, 2008, 12:37 AM
3-DMan is offline
3-DMan's Avatar
Venutra. CA
Joined Nov 2007
Originally Posted by Diggs
I am curious of this also. I have a RC Works reaper wing with very similar power system. Het 3 with a 6x4 prop 60amp ESC all being pushed by a poly 4s 4000mah pack and I can't hit 130mph in a downwind decent, much less 135 level flight. It's frame doesn't have nearly the drag of the stryker either. How did you document these speeds?
Diggs
I got the results from Winged Shadowed System's "How FastTM Airspeed Instrument. It can measure from 5mph to 500mph and it's $44.
Old Feb 06, 2008, 12:49 AM
3-DMan is offline
3-DMan's Avatar
Venutra. CA
Joined Nov 2007
Here's what you call too fast for your plane, at my local club's electric fly in this guy had a tiny pylon racer called the Stinger from Hobby Lobby and he had a Mega 16/15/2 in it. So he took it up some guy had a radar and it registered in at 205mph, then he barley bummped up elevator and snapped the wings right off, the fuse smashed in the ground, and everyone fliched because it sounded like a gun just fierd off! when he came back what was left of it the motor yanked out of the plane, the wing were splinters, and the battery was missing( they found it at the end of the day and it was thrown about 500ft from where the plane's fuse hit the ground) it was tosted!
Old Feb 06, 2008, 12:58 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
that podcast is pretty cool
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Feb 06, 2008, 08:48 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
that is possible
anything with a mega 16-15->"2"!!!!!!!! and being very thin and slippery is VERY VERY FAST!!!
brian94066 is offline Find More Posts by brian94066
Old Feb 06, 2008, 09:45 PM
davemac2 is offline
Find More Posts by davemac2
Sacramento, CA
Joined Jan 2007
Diggs
Ok fair enough, you caught me. I bought the wrong plane, so now I need to make it go fast! lol
dave mc
davemac2 is offline Find More Posts by davemac2
Old Feb 06, 2008, 09:47 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
dave mc
here's my 2 cents
MEDUSA AND NEU!!
Old Feb 06, 2008, 09:52 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Thanks!
Diggs
Old Feb 07, 2008, 07:06 AM
Skonkworkstexas is offline
Find More Posts by Skonkworkstexas
Survival is Attitude!
Skonkworkstexas's Avatar
Hallsville Texas
Joined Aug 2005
dave mc
If you thin the airfoil, and change the camber, you can really ruin it.
My thoughts...need thinner airfoil...Buy a different model!
Skonkworkstexas is offline Find More Posts by Skonkworkstexas
Old Feb 07, 2008, 12:35 PM
3-DMan is offline
3-DMan's Avatar
Venutra. CA
Joined Nov 2007
I knew that the modified airfoil would work, because I have a book on all these different types of air foils and I went under the speed foils and tested each one on peices of foam facing into a fan that's blowing colored air or smoke on to the foil and measered the drag on each one. So I decided to go with the one that had the best air flow. And it works great!
Old Feb 07, 2008, 02:32 PM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Stryker will fly without some body parts
I have two noseless Strykers and here is 333g AUW one:
http://www.rcgroups.com/forums/showp...postcount=1614
fmkit is online now Find More Posts by fmkit
Old Feb 07, 2008, 02:47 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
if you had larger stabilizers it wouldn't wash out like that
Old Feb 07, 2008, 07:43 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
those types are for really fast wings, wont really work well if ur flying slow most of the time
Old Feb 07, 2008, 08:28 PM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
I posted above about using A123 cells in my Stryker. The fuselage is 35 mm wide and a 2300 A123 cell has a diameter of around 28, so that's an absolute no go. The 1100 ones from the VPX black and decker packs are 18mm, so twice that, plus some tape is barely thicker than the fuse. This will be what I'm putting in. The capacity will be low but I should have a few fast minutes with it (4 cell pack)!
JWilliams2 is offline Find More Posts by JWilliams2
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
