Old Feb 03, 2008, 02:37 PM
3-DMan is offline
Find More Posts by 3-DMan
Inverted,that's howI roll
3-DMan's Avatar
Venutra. CA
Joined Nov 2007
Originally Posted by brian94066
i dont know about the numbers, but my medusa stryker seem just as fast on 3S
and i never heard of a 135 MPH stryker with that set up before
this might be cool to watch
One of the cool things is that when my dad has his stock Stryker C at full throttle I just pass him by like he was standing still. There's also a guy out here that has a modified Dimond Dust wing that looks like homeplate and it goes 205mph and it's electric but I haven't from him in a while.
3-DMan is offline Find More Posts by 3-DMan
Old Feb 03, 2008, 04:24 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
oooo i want a set up of that wing
brian94066 is offline Find More Posts by brian94066
Old Feb 04, 2008, 08:59 AM
Esprit 88 is offline
Find More Posts by Esprit 88
Per Ardua ad Astra
Esprit 88's Avatar
United Kingdom, England, London
Joined Jan 2005
Originally Posted by TyphoonBond
I have just read through almost all the stryker threads (wow there are alot). Just started building a stryker (friend sold it to me cheap, since he crashed and totalled the body and didn't want to rebuild). The ESC and motor are fine, so I am going to reuse them (for now) on a new body.
Question: Nobody seem to really talk about the stock C motor in depth, they just replace it. Has anyone tried running it with different props (APC 6x4, or 6x5.5, cam speed props, etc)??? What kind of results do you get?? Amps?? The most info I can find on this is that people have tried different props, but they don't provide any details.
Hi
The standard 6x4 prop works well with the stock C brushless motor. I have used a Graupner Cam Speed 5.5x5.5" prop though. Both use around 25 Amps at full throttle. The 6x4" seems to have a higher top speed, but the 5.5x5.5" more thrust. The Cam prop is much quieter!
Esprit 88 is offline Find More Posts by Esprit 88
Old Feb 04, 2008, 02:07 PM
3-DMan is offline
3-DMan's Avatar
Venutra. CA
Joined Nov 2007
Has anyone tried a speed prop with the stryker? If so, did you feel any difference in the flight?
Old Feb 04, 2008, 02:15 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
you need to be more specific
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Feb 04, 2008, 03:39 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
gotboostedvr6, how did that Hobby City motor work out for you in your Stryker? Kind of curious how well it performs...
cjbucher is offline Find More Posts by cjbucher
Old Feb 04, 2008, 04:30 PM
TyphoonBond is offline
Find More Posts by TyphoonBond
Originally Posted by Esprit 88
Hi
Anyone else have any input for me?? (reference post 1558 on page 104).
TyphoonBond is offline Find More Posts by TyphoonBond
Old Feb 04, 2008, 05:46 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
i used the 6x4E instead of the old 6x4 on the stock C motor when i last had it, it is a little faster and it does have a little more thrust, but it's not as loud =P
Old Feb 04, 2008, 10:17 PM
3-DMan is offline
3-DMan's Avatar
Venutra. CA
Joined Nov 2007
What I mean is that has anyone used a speed prop the ones with the little winglets on the tip of the prop. And if you have tried them do you notice if the Stryker picks up speed? That's what I was trying to ask.
Old Feb 04, 2008, 10:57 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
A graupner will help some but they are pricey, i dont have a stock motor in mine so i cant tell you for sure.
The hobby city batts and motor are still on the way.. dont worry Ill post up
on another note have any of you have issues with the stock elevons falling off? the stock hinges are failing on me. im currently using fiber tape in their place..
Old Feb 05, 2008, 06:35 AM
Skonkworkstexas is offline
Find More Posts by Skonkworkstexas
Survival is Attitude!
Skonkworkstexas's Avatar
Hallsville Texas
Joined Aug 2005
Originally Posted by 3-DMan
I've had my modified Stryker C for over a year now. My set up is a Mega 16/15/3 with a Evo 4s 2100 mAh 20c. The prop that I'm running is a 5x5. My rpm is 3000. the top speed in level flight is 135mph, and in a downwind vertical dive from 500ft is 145mph. It also has unlimited climb, it doesn't stall.
Here's a video on it. http://www.vimeo.com/609798
If you can't see it in the video good with the sceme here's some pics.
3-Dman, what kind of current/wattage are you talking?
Skonkworkstexas is offline Find More Posts by Skonkworkstexas
Old Feb 05, 2008, 09:55 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I am curious of this also. I have a RC Works reaper wing with very similar power system. Het 3 with a 6x4 prop 60amp ESC all being pushed by a poly 4s 4000mah pack and I can't hit 130mph in a downwind decent, much less 135 level flight. It's frame doesn't have nearly the drag of the stryker either. How did you document these speeds?
Diggs
Diggs is offline Find More Posts by Diggs
Old Feb 05, 2008, 05:48 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
a stryker will never get past 110 MPH even with 6S and a mega 16-25-3
let alone 135 straight
unless you shaved off all the unneeded foam, thin down the airfoil, glass it, put a neu 1110 in it and put it on 5 or 6S
Old Feb 05, 2008, 06:35 PM
davemac2 is offline
Find More Posts by davemac2
Sacramento, CA
Joined Jan 2007
And this brings up some interesting questions:
1. what is the best way to thin down the airfoil. Sanding?
2. How much thinning of the foam can u do before it becomes too weak?
2. How much weight does glassing add to the fuse on a per sq in basis?
dave mc
davemac2 is offline Find More Posts by davemac2
Old Feb 05, 2008, 09:34 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
dave mc
1. to me i think it's sanding
2. just sand the foam down by 3-6 mm and it will make a great difference
3. it really depends, i never glass a plane myself but it adds a couple ounces according to the fellow pilots at my field
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
