Old Jan 27, 2008, 06:33 AM
Sirius35 is offline
Find More Posts by Sirius35
Saint-Méen le Grand (BZH)
Joined Jan 2007
Originally Posted by gotboostedvr6
sirius try a smaller prop
I forget to say that after my second flight with 4.7x4.7 cam speed prop 2445 Inrunner was cold !!!
I would make measurements of consumption of this engine in the week with this propeller, but I in any case think that I should not exceed the 30A, my ESC is a 36A HXT Pro and had no show any disturb
Sirius35 is offline Find More Posts by Sirius35
Old Jan 27, 2008, 09:43 AM
southernmd_man is offline
Find More Posts by southernmd_man
Gravity's a harsh Mistress....
southernmd_man's Avatar
United States, MD, Lusby
Joined Jan 2007
Originally Posted by glucoseboy
Thanks Brian, pictures would be very helpful. I've been motivated to reduce the drag on my Stryker now so I'm looking to put the ESC back inside, but I"m conscious of trying to keep whatever airflow I can get on it.
I'm flying a moded B, and things were getting a little warm in the plane. So I drilled a hole in the battery hatch, and glued a servo arm cover/air scoop from HL over it. Adds a little drag, but everything in the electronics bay is getting plenty of air movment, and it aids in drawing air into the cover vents over the battery.
southernmd_man is offline Find More Posts by southernmd_man
Old Jan 27, 2008, 01:01 PM
glucoseboy is offline
Find More Posts by glucoseboy
glucoseboy's Avatar
SF Bay Area, CA
Joined Feb 2006
Found a picture of the stock F27C setup: (August 2007 of Quiet Flyer Magazine)
southernmd_man: Thanks for the tip. Form my modded B, I'm going to swap out the front cover with the one from the C. I'm also going to drill some real holes in the fake scoops to open the battery compartment to some more air. Then, add some holes in the rear deck for venting.
glucoseboy is offline Find More Posts by glucoseboy
Old Jan 27, 2008, 04:19 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
here are the pictures
the stryker might look beat up, but it still flies like a dream
sorry for the low quality pictures, my camera is old
brian94066 is offline Find More Posts by brian94066
Old Jan 27, 2008, 04:24 PM
glucoseboy's Avatar
SF Bay Area, CA
Joined Feb 2006
Thanks for the pics Brian, Yup, it does look beat up!
What motor mount are you using?
Old Jan 27, 2008, 04:25 PM
Sirius35 is offline
Joined Jan 2007
your F27 is old too
Old Jan 27, 2008, 08:19 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
using justgofly.com 3" L-bracket
and yes it is old, look closely you can see claw marks left by a hawk >.<
never try to chase a hawk
Old Feb 02, 2008, 05:56 AM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
OK, since losing my 3S pack that flew out of the plane, I'm going to build a 4S A123 pack, I think. The thing will weigh about 280 grams. My feeling is that weight is not a huge problem for this plane as it relies on speed more than weight being a huge factor, although I realize launches could be a bit harder. Has anybody put a 4S A123 pack in this plane and how did it work? I'm using an APC 6X4 prop on a 2700 kv motor now. I actually plan to keep it propped the same but I just won't go wide-open throttle very often.
JWilliams2 is offline Find More Posts by JWilliams2
Old Feb 02, 2008, 12:01 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
never heard of 4S A123 in a stryker before, but i think it's a little too much for the 2700 with that prop
Old Feb 02, 2008, 12:11 PM
JWilliams2's Avatar
NY State
Joined Jan 2007
On paper it certainly seems like it would be, but the 3S pack I have has a starting voltage of 12.6 vs 14.4 for the A123 setup so if I'm ok on throttle it shouldn't be brutal. Fitting the bats in the fuse may be a problem, though, in which case I'll have to do a 3S setup (3 long instead of 2X2), but then it will be slower. 4 of the smaller A123 bats would work for aggressive short flights but I cannot drop even more cash on these bats
Old Feb 02, 2008, 08:15 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
haha true, true lipos are expensive =P
try it out, run it carefully, if the motor gets too hot then keep the 3S
Old Feb 03, 2008, 07:48 AM
Skonkworkstexas is offline
Find More Posts by Skonkworkstexas
Survival is Attitude!
Skonkworkstexas's Avatar
Hallsville Texas
Joined Aug 2005
Watch the motor and ESC heat! Check with the wattmeter! Work your way up checking for heat before a long run. I may have to go to A123 myself, cause they can handle the current better!
Skonkworkstexas is offline Find More Posts by Skonkworkstexas
Old Feb 03, 2008, 11:28 AM
TyphoonBond is offline
Find More Posts by TyphoonBond
I have just read through almost all the stryker threads (wow there are alot). Just started building a stryker (friend sold it to me cheap, since he crashed and totalled the body and didn't want to rebuild). The ESC and motor are fine, so I am going to reuse them (for now) on a new body.
Question: Nobody seem to really talk about the stock C motor in depth, they just replace it. Has anyone tried running it with different props (APC 6x4, or 6x5.5, cam speed props, etc)??? What kind of results do you get?? Amps?? The most info I can find on this is that people have tried different props, but they don't provide any details.
TyphoonBond is offline Find More Posts by TyphoonBond
Old Feb 03, 2008, 02:07 PM
3-DMan is offline
Find More Posts by 3-DMan
Inverted,that's howI roll
3-DMan's Avatar
Venutra. CA
Joined Nov 2007
I've had my modified Stryker C for over a year now. My set up is a Mega 16/15/3 with a Evo 4s 2100 mAh 20c. The prop that I'm running is a 5x5. My rpm is 3000. the top speed in level flight is 135mph, and in a downwind vertical dive from 500ft is 145mph. It also has unlimited climb, it doesn't stall.
Here's a video on it.
Lighting Stryker (4 min 58 sec)
If you can't see it in the video good with the sceme here's some pics.
3-DMan is offline Find More Posts by 3-DMan
Old Feb 03, 2008, 02:12 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
Here's a video on it. http://www.vimeo.com/609798
i dont know about the numbers, but my medusa stryker seem just as fast on 3S
and i never heard of a 135 MPH stryker with that set up before
this might be cool to watch
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
