____ If you have not bought it yet...instead of that one; Consider running 16/30/2 D KV wise: (With same turns & same size) D = 1.72 Y (I think not more than 1.75 Y) It maybe more robust than 16/25/1.5RY ____ ***Hope your other project turned out nice. Gryphon |
Yuma, AZ
Joined Oct 2003
Need a little help, searched and can't find it. I have a futaba 9c flying my Stryker. I've tried the spectrum programming I've found but doesn't work.
Can someone tell me were I might find futaba programming for rudder speed brakes? I already have the rudders on separate channels. I've tried rudder to flap mixing, but that didn't work. Thanks, Steve |
Better ask in the Stryker Q thread..... |
http://manuals.hobbico.com/fut/9c-su...ies-manual.pdf |
United States, FL, West Melbourne
Joined May 2011
Two questions, I am starting a new one with a blank I bought a while back. Sanding off the mold bits for now.
Initially I will use the existing power plant. and will eventually rebuild the original. So here goes 1. I want a nice smooth finish and I like the lightweight gliding. I was thinking of coating with a spackle/water/paint mix for finish or paint with WBPU and laying down a little silkspan. Anyone got some advice? Second, what would a 30 amp setup give me over the stock motor? |
Did you get sorted with your mix? |
I believe this is the best way to get the strength and finish you're looking for. 2) 30A on what voltage? 30A on a 3S LiPo will not be very different from the stock Stryker C. Not what I would consider an "upgrade" anyway.
Joined May 2011
Joined May 2011
http://www.headsuprc.com/servlet/the...ushless/Detail http://www.headsuprc.com/servlet/the...ushless/Detail |
| Thread Tools | |
| Discussion Parkzone F-27C Stryker | That can fly?!? | Parkflyers | 109 | Sep 26, 2012 10:54 PM |
| Discussion Parkzone's New F-27C Stryker | itspat | Parkflyers | 1 | Nov 08, 2011 07:56 PM |
| Mini-Review F-27C Stryker Review | That can fly?!? | Parkflyers | 27 | Jul 29, 2010 08:25 PM |
| Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug | WDP | Batteries and Chargers | 12 | Oct 26, 2009 08:44 AM |
| Discussion Coming soon! F-27C Stryker RTF with lipo and brushless | Solcat | Electric Plane Talk | 0 | May 31, 2006 12:34 PM |
