Old Nov 16, 2012, 09:10 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
One possible solution to stock mount with broken tabs.
I prefer to see the mounts that Gary makes. But here is alternate option:
I did this with hardened washer.........BIG MISTAKE....way way way too hard to do outside of a nicely setup shop.
Try to use softer metal.
I have seen similar things done with plastic coke bottle caps for light weight motors.
Let the pics do the talking.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Nov 17, 2012, 01:06 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Gryphon
Thanks that helped out much.
eckace1 is offline Find More Posts by eckace1
Old Nov 17, 2012, 04:37 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Originally Posted by Arcteryxxx View Post
Love the colors, Flame! Care to share a picture of the whole plane?
Hey Bud - Just finished this latest build about 5 minutes ago, hopefully I will be able to maiden it tomorrow
Radio programming done, rebinded, etc
Build details: MEGA 16/35/2C, CC100, UBEC, HS82's, 4-40 hardware, Bad Ass Fins Thanks Murdo , using 5S 3000mAh 30C for now, 2" Elevons, Tape hinge, Fuse heat treated, typical CF layout
Will post video of Maiden ASAP
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Nov 17, 2012, 04:44 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
A coral snake Stryker!!!!!!!
Me like
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 17, 2012, 06:51 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
red on black - friend of jack / red on yellow - kill a fellow, isnt that what they say about the coral snake. you should write that on the plane.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Nov 19, 2012, 08:24 AM
bostomper is offline
Find More Posts by bostomper
Joined Aug 2010
Went to work on the plane this morning---haven't touched it in 4 months. Tried to take the prop off for safety and could not budge the spinner. Used a fairly long shaft thru the spinner and could not get it to budge. Any suggestions? Heat? WD40? help--Bo
bostomper is offline Find More Posts by bostomper
Old Nov 20, 2012, 01:09 AM
hondaboy92hatch is online now
Find More Posts by hondaboy92hatch
hondaboy92hatch's Avatar
United States, WA, Vancouver
Joined Feb 2005
HET 1w40
Hi,
I was wondering if anyone has tried a Het 1w40 in their stryker? also I need a ftronger motor mount.
Joe
hondaboy92hatch is online now Find More Posts by hondaboy92hatch
Old Nov 20, 2012, 04:06 AM
GryphonRCU's Avatar
Joined Mar 2008
hondaboy92hatch,
That motor can be a fairly decent 3S motor (power wise).
For all out with 3S , you will need a LARGE pack and HIGH AMP ESC.
The KV is pretty high.....too high for most folks.
I would not recommend 4S, but others might?????
3S is a safe bet and you will enjoy it more.
It will make serious power with a high C rated LARGE 3S, propped for HIGH AMPs.
4mm shaft is a plus compared to 3.2mm.
Good luck,
Gryphon
Old Nov 20, 2012, 06:49 PM
Joined Feb 2005
hondaboy92hatch,
Good luck,
Gryphon
hI Gryphon,
What prop would you reccomend on 3s? I was just looking at the het because I was on the eflux sight the other day. I am open to other motors would like to run no more than 4s. I was also thinking about a het 2w25 I had one of those motors years ago. who is the best source for carbon rods?
Old Nov 20, 2012, 07:13 PM
GryphonRCU's Avatar
Joined Mar 2008
It depends on a few things, here are some initial questions:
What is the max speed you like to reach in level flight without any help from dive or wind?
Keep in mind that your future needs may dictate more speed. With higher capable system purchased now you can always prop down for now. Later on a $3 prop can increase your speed. (In long run it'll be cheaper instead of buying another system again). Just throwing out food for thought.
Do you have the ESC and battery for this project or you will buy them as needed?
If you have one of them, what is it?
For any given speed, you need at least certain amount of power (Watts).
The more cells that you run, the lower AMPs you will need for same Watts.....meaning you can run lower AMP rated ESC.
I hear you....initially you like to cap cell count at 4S.
Strykers have been run up to 12S.
Most ESCs are capable of 6S.
Keep your charger's max cell count in mind because some are only good for 3S or 4S. No need for surprises.
Gryphon
Old Nov 20, 2012, 07:16 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Originally Posted by hondaboy92hatch View Post
hI Gryphon,
i run the het2w25 on a 4s 3000mah battery , i scoot along at around 125mph flat and around 130+ on a dive , i love that motor .
you can also run a aerodrive sk3 3659/1900kv motor on a 7x6 prop on a 4s from what ive read it will get you moving in the 150 ball park, i have that motor as well, but im still messing around with the het ,
last i have a mega motor on a twinjet i forgot what number it is to lazy to get up and look to see .. its a motor that Moparmyway used
on a funjet its on one of his Youtube videos . i belive that funjet was doing around 160mph or better .
IMO its really based on what you can afford
if it was up to me i would only run mega motors ,i cant afford it, so i have to use whats within my budget i have no regret about the buying the motors ive listed .
i enjoy my het and i like the fact that i can get extreme speeds 190mph + out of a 50.00 motor "sk3".. and if i crash and burn that plane i dont have to worry that the motor was a mega motor that cost me over 150.00
just my opinion
i usually get my rods from bphobbies
bphobbies has the 6mm x 1000mm flat rods for 6 for 10.00 i say thats a steal at that price considering that the 3mmx1000 flat rod is double the price
THESANDMAN is offline Find More Posts by THESANDMAN
Old Nov 21, 2012, 11:10 AM
Joined Feb 2005
I dont really have a big area to fly in so if I could get an honest 130 I would be happy. I will need to buy the components as well.
Joe
Old Nov 24, 2012, 02:39 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Who knew going from 3s to 4s would make such a huge diffrence.
Ok I'm new to this 4s thing but really 3s1p 2200 MD 2505-2800 32amps and 335 watts.
4s same motor 48amps and 710watts with a apc6x4.
I think I need to prop down just a bit but I had no idea 1 extra cell would make that much diff.
Old Nov 24, 2012, 04:32 PM
my_names_nobody is offline
Find More Posts by my_names_nobody
full throttle flyer
Joined Nov 2012
my guesstimate is you went from 80mph to at least 115mph . big difference
my_names_nobody is offline Find More Posts by my_names_nobody
Old Nov 24, 2012, 05:37 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
eck,
It's not making complete sense but it's sensible. Power goes up with the square of the voltage (or current), so you'd would expect to see around 596 Watts on 4s if you were going up from a baseline of 335 Watts for 3s. (4s/3s)^2 -> 1.78 and 1.78 x 335 Watts = 596 Watts
Reality was 710W/335W -> 2.12 times increase in power.
In your case the 3s pack had sagged more than the 4s pack, so the increase in power was a little higher than the expected calculations.
335 Watts @ 32 Amps would be a 3s pack sagging down to 10.4 Volts
710 Watts @ 48 Amps would be a 4s pack sagging down to 14.8 Volts
(14.8/10.4)^2 -> 2.02 and 2.02 x 335 Watts = 676 Watts
With your current measurements you'd expect (48A/32A)^2 -> 2.25 and 2.25 x 335 Watts = 754 Watts
I think the difference between all these numbers (754/710/676) probably boils down to round off on the current, i.e. fractions of an amp.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
