Old Nov 12, 2012, 01:23 AM
Hallmark is offline
Find More Posts by Hallmark
Australia, SA, Munno Para
Joined Feb 2012
Not sure if I posted this in the thread already, but here's how to put air brakes (using the rudders) if you have a Spektrum DX6i radio.
Parkzone F-27Q Stryker DX6i Air Brakes Programming (7 min 1 sec)
Hallmark is offline Find More Posts by Hallmark
Old Nov 12, 2012, 02:09 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Brolley,
If you want to build a discharger I can help you.
Several guys have done it.
From 1 hour for the build, up to several hours.
Depends on how fancy and how big you want it to be.
Biggest one built, in biggest state (Texas), can handle 4000+++W.
The 12V (50W) track lighting bulbs can handle 5S max.
5S draws max AMPs at just over 6A if I remember right.
In series 10S is max.....but then 3S draws very little AMPs.
I can show you how moving some jumper wires can put every pair of lights in series or stay in parallel.
My 14 light discharger (7-8 toggle switches) can handle 1550W till battery gets weaker.
72 light discharger in Texas can handle this much:
PM if interested.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Nov 12, 2012, 11:57 AM
brolley is online now
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
I think my charger will do it but not sure how fast. TP 1010 charger has discharge function with the 210 balancer.
Flew the Stryker today. First flight not so good. Bungee launch was great, first few circuits were great then lost control. Got control back about 10 feet from the deck..... enough time to level the wings and flair.
NO DAMAGE!!!, except for a broken prop.(wiping the sweat off my brow).
Found my Stryker 50 yards away with a flashing RED and solid amber lights. Must have had a signal hold for a few seconds.
Second flight swapped receiver (AR 6210 same style as first) and used original satellite... no problems. Flew great. APC 7x6 drawing only 77 amps but not fully unloaded. Gonna try 7x7 at 2:00.
Anyway I bought this original AR6210 on e-bay. Was advertised as new but received it in a plastic ziplock, not original Spektrum packaging. I think I got taken!
So far though, it's a good day!
brolley is online now Find More Posts by brolley
Old Nov 13, 2012, 08:20 PM
brolley's Avatar
Joined Dec 2008
A few more pics.
Flew today with the new Mega... 22-20F5DE! Awesome motor! 7x6 prop 4S 3300 pulled 108 amps. Great acceleration, carves really nice, floats pretty good too. 3.4 pounds auw.
I think I have room to prop up, motor was barely warm in 50*F weather.I don't have the graph in front of me but will post it later if anybodys interested.
Old Nov 14, 2012, 05:41 PM
tippy1404 is offline
Find More Posts by tippy1404
Joined Sep 2012
stryker 7x8 run
needing some more volts.....any other suggestions??goal is 150.....138mph right now according to a bushnell radar gun.
video is sideways.
stryker 22 35 1 5es (0 min 54 sec)
tippy1404 is offline Find More Posts by tippy1404
Old Nov 15, 2012, 12:25 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Suggestion:
Go out further and/or have more time at full throttle
moparmyway is offline Find More Posts by moparmyway
Old Nov 15, 2012, 08:08 PM
eckace1 is online now
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
I need some expert advise on mounts.
I was wanting to try and mount a MicroDans 2505-2800 motor to my stock mount.
I unscrewed the stock motor and all 4 plastic tabs from the stock mount were broken
Is there a mount I could purchase that would work with the MD motor?
It uses a mount attached to the bearing tube 8mm tube?
Thanks for any help.
eckace1 is online now Find More Posts by eckace1
Old Nov 15, 2012, 08:40 PM
brolley's Avatar
Joined Dec 2008
Micro Dan mount
eckace
Is this what you're looking for?
Old Nov 15, 2012, 08:47 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by brolley View Post
eckace
I have that adaptor.
my stock styker mount tabs are broken.
Thanks though.
Ps I do like those cam speed props though
Old Nov 16, 2012, 05:04 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Can you still buy foam cores?
Old Nov 16, 2012, 05:09 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Search the net for PKZ1267 .
Some of us started piling them up a year and a half ago
Still got five and none to spare.....
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 16, 2012, 05:16 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Thanks for the help
Now I just need to figure out how to mount my MicroDans 2505 on it.
Old Nov 16, 2012, 05:29 PM
Arcteryxxx's Avatar
Joined Feb 2010
Thanks for the help
Just if you haven't found it yet, heres a link....and it's still in stock!
http://www.amainhobbies.com/product_...lage-Unpainted
If you can't find a mount, make it yourself. It's not that hard
Old Nov 16, 2012, 06:43 PM
brolley's Avatar
Joined Dec 2008
You can find them on ebay.
Old Nov 16, 2012, 08:16 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Harder than you think as the only mounting option is the 8mm bearing tube.
here is the motor http://www.gobrushless.com/shop/inde...f=MD2505-SP-LE
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
