Old Nov 08, 2012, 07:23 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
36mm MPI heat sinks:
38mm long and 59mm long(extra $2).
http://www.maxxprod.com/mpi/mpi-29b.html
You will be fine with just the shorter one.
I might consider the longer one and customize it as needed.
***if covering the area of the motor with the (3) pins, then you can mark the area inside of the heat sink and then grind those areas a little. Otherwise the heat sink will not sit flush.
Brolley,
When I make a wooden elevon, air molecules will have to line up single file if they want to go through.
I am not the best guy to ask about sealing the hinge line.
The true speed kings can help you more.
If you have APC Sport 7X4 check to see what the draw is on 4S (static).
It might be good prop for maiden without being too fast. Since this ratio prop will unload higher % AMPs, it is OK to run it if static is on higher end than previously discussed.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Nov 09, 2012, 12:03 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Brolley: search this forum for "wipers". This is how you seal the hinge line.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 09, 2012, 01:06 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Go to 3.49 of:
Making a Tape Hinge-Line (5 min 15 sec)
However I'm finding full tape Ritewing style hinges very good and quick to do:
Ritewing elevon attachment (10 min 26 sec)
Peter M is offline Find More Posts by Peter M
Old Nov 09, 2012, 08:58 AM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
I am in the process of building another stryker, trying the tape hinge method for the first time, so far it feels very secure.
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Nov 09, 2012, 09:06 AM
Arcteryxxx's Avatar
Joined Feb 2010
Love the colors, Flame! Care to share a picture of the whole plane?
Old Nov 11, 2012, 07:13 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Sealing the hinge line...
Easiest method is to use 3M Blenderm tape, sold as parkflyer hinge tape in hobby shops. You fold the tape in half lengthwise and stuff it into the hinge gap, then wrap it and stick it to the surface of the wing trailing edge and elevon. Do it on both sides.
Blenderm tape fixes the issue of air "leaking" through the hinge gap, so it reduces drag there and makes the elevons more effective.
You will, however, still have the "valley" from the bevel of the elevon. So that's still a source of drag when using this method.
Wipers like Arcteryxxx mentioned will both seal the gap and make a flat surface across the hinge. They can be made from packing tape. Don't use Extreme tape, as it's too stiff and can flutter rather than staying pasted to the elevon surface like it should.
If you do wipers on a centered hinge, with a V-shaped bevel cut on the elevon, you'll need a wiper on the top and bottom surface, or it won't seal anything.
My personal favorite hinge is a Storage Tape hinge, Ritewing style. Single bevel on the elevon and an automatically sealed gap. You can also install a tape wiper on the bottom.
murdnunoc is offline Find More Posts by murdnunoc
Old Nov 11, 2012, 07:35 PM
FLAME747 is offline
Katy, TX
Joined Dec 2009
Hey Arcteryxxx still building it, I'll post more pics later
FCA
Old Nov 11, 2012, 07:56 PM
brolley is offline
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
Speed comparison
For those of you who fly Ritewings and Strykers... wondering which is more slipperiest .
What I'm getting at.... With exactly the same setup which one would be faster?
I'm thinking about getting a Voltron data logger. Has anybody used one? Do you like it?
Murdo, I sent you a pm about a motor.
Been trying to get a video of my Ritewing D40 dopplered. It's under electric airplane videos if interested. A friend got a Bushnell radar gun but we're having trouble getting it to work right.
brolley is offline Find More Posts by brolley
Old Nov 11, 2012, 09:05 PM
GryphonRCU's Avatar
Joined Mar 2008
Hello Doppler experts,
Here is brolley's video.
http://www.rcgroups.com/forums/showthread.php?t=1766944
It is not on max volts or max AMPs....but he can use the Doppler results.
Gryphon
Old Nov 11, 2012, 09:28 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Hey Brolley,
I get 115, 110, 96, 109, 118mph on your upwind passes.
Add whatever your estimated headwind component was to get your true airspeed.
You can see the big difference a nice long runup makes, as the last pass was the fastest on a spent battery. But you were on the gas for a good 5 seconds before the camera.
Either that or your batteries were in thermal runaway, producing more volts!!
Seriously though, how are your batteries doing??
I read 31,600 RPM on your motor during the flight, which would indicate about 19.3V for that RPM on your 1915KV motor.
Old Nov 11, 2012, 09:37 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Also just a note on Doppler...
I had my RC Speedo app listening to the computer speakers as I was running the Hyperdyne desktop doppler program, and the RCSpeedo is within a couple mph on all passes. With no work!!
Also had the same experience at the field with a guy using RCSpeedo on my plane. When I went home the results I got on the desktop program were nearly the same as he was calling out in the video.
RCSpeedo is a great tool for everyday speed checks!
Just make sure that if you get 4 passes between 115-125mph, and one pass at 218mph, you know which one to throw out
Old Nov 11, 2012, 09:41 PM
GryphonRCU's Avatar
Joined Mar 2008
Thanks Murdo.
G.
Old Nov 11, 2012, 09:54 PM
brolley is offline
brolley's Avatar
Joined Dec 2008
Originally Posted by GryphonRCU View Post
Thanks Murdo.
G.
Ditto... Thanks Murdo.
That's disappointing! I thought the Nano-Techs were losing their punch(if they ever had any). About 6 flights on them. I'm going back to TP!
Is it necessary to break-in the batts if you want them to last?
Old Nov 11, 2012, 10:01 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Absolutely break them in!!
Higher C-rating batteries are more touchy to being treated nicely than lower grade packs.
I've gotten good experience from the Nano-tech 65C packs when broken in and keeping them at storage voltage any time they're not flying. I don't even charge the night before flying.
Also, I'm just doing a little dirty math for fun on your RPM and voltage. You may have something different with in-flight data log on your voltage.
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
