Old Oct 29, 2012, 03:26 PM
brolley is offline
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
Originally Posted by moparmyway View Post
Looks like a Sikorsky or a Bristow
You mean like this one?
brolley is offline Find More Posts by brolley
Old Oct 31, 2012, 04:37 PM
tippy1404 is offline
Find More Posts by tippy1404
Joined Sep 2012
Looking for a safe prop size to start with. 6s 3300, hv 120, mega 22/35/1.5es.
no load data
tippy1404 is offline Find More Posts by tippy1404
Old Oct 31, 2012, 04:45 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
no load data
Any APC 6.5 pylon is safe, also medium pitch 7 inch props I guess. I run mine with APC Q40 7.4x8.1 on 5S. Motor burned with 8x8 on 5S....
EDIT: Sorry mate, I was a little too quick to post. I was referring to the 22/35/1.5ER, so the data don't apply...
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Oct 31, 2012, 07:49 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
tippy1404,
The no load ICE log attachment is not usable as you have posted....if trying to show the KV.
I suggest you zoom in so that the span of the graph is the same as ICE window.
You can place the curser 1 second after peak AMPs....we can then read the data from the top line of table below the graph called "mouse".
better yet (for KV) :
...maybe left edge of window 1.0 seconds after full throttle, and right edge 1 to 2 seconds later (shorter duration if test was shorter). Normally we log at 10 times per second for tests....even a half second wide window is ok enough that way.
Anyway, if you zoom in this much, we can just use the displayed "average" values.
Edit: I added a sample chart.
RPM / voltage = KV
if you ran the motor few times, use first graph.
make sure you start your test with motor at room temp.
Warmer = shows higher KV
Cooler = shows lower KV.
___________________________
Note: always disregard the AMPs as reported by ICE during KV test. Numbers this far below 40A as reported by ICE can not be trusted. called ( Io ).
If you want to know the Io value (no load AMPs) use your Wattmeter.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Oct 31, 2012, 09:54 PM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
What?
Foambird is offline Find More Posts by Foambird
Old Nov 01, 2012, 04:03 AM
geedee is offline
Find More Posts by geedee
Chester, UK
Joined May 2010
Spares
Does anyone in the UK or Europe know where I can get nose and canopy spares?
Several stores claim to have them, but they are on backorder.
Many thanks
geedee is offline Find More Posts by geedee
Old Nov 07, 2012, 04:44 PM
Joined Sep 2012
Stryker 1st Data Run
6s 3300 35-70c, hv 120, mega 22/35/1.5es, 7x6 prop.....trying to figure out what prop to try next.
Old Nov 07, 2012, 07:04 PM
brolley is offline
brolley's Avatar
Joined Dec 2008
Nice job Tip! I would run the same prop again but with longer WOT. She what it looks like unloaded.
Old Nov 08, 2012, 05:42 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Tippy,
Is that photo saying your Stryker is stove hot?
Yeah, longer runs and a 7x7 would be your next step. Trying some Q40 or cut down 8 inch Sport props would be the next step after that. Just go a step at a time and feel your way.
Also consider another cell and/or a bigger capacity battery as your current battery isn't holding great voltage under load.
Peter M is offline Find More Posts by Peter M
Old Nov 08, 2012, 08:51 AM
Arcteryxxx's Avatar
Joined Feb 2010
Tip for Tippy: get a MPI heatsink for your 22/35.
Old Nov 08, 2012, 10:43 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
He also need a pedicure.
My wife said your foot looks like it needs some love!
Hahaha!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Nov 08, 2012, 02:57 PM
mxz1998 is offline
Find More Posts by mxz1998
Canada, AB
Joined Jun 2011
Well I got my Stryker rebuilt and just for fun I added 1.5 inch rudders. Hope to remaiden on Saturday. Anybody else tried rudders, knife edge, etc?
mxz1998 is offline Find More Posts by mxz1998
Old Nov 08, 2012, 03:17 PM
Arcteryxxx's Avatar
Joined Feb 2010
Multiple pilots have tried it before on a B or C model. Lots of posts around.
And then the Q came along....
Old Nov 08, 2012, 05:47 PM
GryphonRCU's Avatar
Joined Mar 2008
Tippy,
Make sure your hingeline is sealed.
Increase your AMPs while still on 6S with respect to motor temp and battery capability.
I also think that your motor is about a 7S max motor in this application (very capable Low KV motor).
Do not run 6.5" diameter prop on 7S. Run 7".
If you ever get a 7S, the cells need to be more capable than your current cells.
Compared to both more AMPs "and" another cell; You may currently have your motor at 60% of max Watts for single high speed passes.
Expect conservative 20MPH speed increase if you decide to push that far....possibly 25MPH increase.
Arctery and PeterM can help you more than me given their previous experiences with 22/35/1.5E (S or R? ) and 22/30/1.5SE (respectively).
I think MPI has 36mm heat sinks in 2 different lengths. The more of the motor you cover the cooler it will run. Some guys run 1 1/2 or 2 heat sinks.
Good luck,
Gryphon
Old Nov 08, 2012, 06:43 PM
Joined Sep 2012
Thanks for all the input. Next run 7x7, heat sinks on the motor, sealed hinges and maybe a little more yellow she gets away from me pretty quick.
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
