Old Oct 25, 2012, 10:41 AM
blanik213 is offline
Find More Posts by blanik213
BLANIK213
blanik213's Avatar
United States, NY, Phoenicia
Joined Feb 2008
Hey Mopar your right, the prop will out perform an EDF setup but the jet like cool factor is what will make these projects worthwhile.Time to raise the bar in terms of taking your streamlining skills to the next level .We have all seen others install EDF units on a variety of foamies but what you and Murdnunoc are planing will push that envelope like you did with prop power and exceed anyone's EDF expectations for these planes . Any form of ducting or modified nacelle will increase the likelihood of creating something that satisfies the need for speed and the whoa factor.
A new chapter begins LOL .
blanik213 is offline Find More Posts by blanik213
Old Oct 25, 2012, 11:08 AM
brolley is offline
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
Thanks guys
28mm motor mount is ordered. Airframe is coming along nicely. Epoxy is on. Sanding and hopefully primer tonight. Anybody have a location for a bungee hook.
I'll post some pics tonight.
brolley is offline Find More Posts by brolley
Old Oct 25, 2012, 03:15 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by brolley View Post
Thanks guys
28mm motor mount is ordered. Airframe is coming along nicely. Epoxy is on. Sanding and hopefully primer tonight. Anybody have a location for a bungee hook. I'll post some pics tonight.
Put it just aft of the 1/2 way point of where the battery will sit.
Further from that point will give you a nose down attitude on the bungee after release
Closer to the CG and you will get a higher angle of attack (AoA or nose up) to make getting a heavy airborne easier.
So long as you dont exceed 800 grams of battery weight, just aft of the battery 1/2 way point will be just fine if your CG is less than 3/4" nose heavy.
moparmyway is offline Find More Posts by moparmyway
Old Oct 25, 2012, 07:17 PM
mxz1998 is offline
Find More Posts by mxz1998
Canada, AB
Joined Jun 2011
So guys I need some help. Let some one fly my Stryker and they crashed it for me. Got her back together but for level flight I need a lot of down elevater and if I hit the throttle it will shoot upwards. Cog is spot on. What could be the problem?
mxz1998 is offline Find More Posts by mxz1998
Old Oct 25, 2012, 08:05 PM
moparmyway's Avatar
New York
Joined Jan 2009
I am willing to bet that the fuse is bannanna'd
Sounds like you have squished the nose and tail up a little so there is a bannanna shape to it.
Take a picture from the side, looking at it sitting as flat as you can and post her up here.
Also could have bent a pushrod
Old Oct 25, 2012, 10:47 PM
mxz1998 is offline
Canada, AB
Joined Jun 2011
Now that I look at it your right! Rear couple inches are clearly bent upwards. Any good fixes or a new fuselage?
Old Oct 26, 2012, 03:53 AM
moparmyway's Avatar
New York
Joined Jan 2009
Usually its time for another fuse, but some Dudes try to straighten it as best as possible and put in a nose to tail CF tube then fly a little slower, and its fine ....................... so long as you dont try to push the speed !
Old Oct 28, 2012, 05:21 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Nice....
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Oct 28, 2012, 06:24 AM
moparmyway's Avatar
New York
Joined Jan 2009
The elevons came out very nice !!
Looking good so far, except I cant tell what you have done for re-enforcements.
Post 15373 shows it though ..................... GREAT job !!!
Old Oct 28, 2012, 06:10 PM
tippy1404 is offline
Find More Posts by tippy1404
Joined Sep 2012
Added some fiberglass reinforcement to the leading edges. Waiting for the Castle quick connect and a little more TLC and she will be ready.
tippy1404 is offline Find More Posts by tippy1404
Old Oct 28, 2012, 07:30 PM
moparmyway's Avatar
New York
Joined Jan 2009
Looks like a MEGA in the first picture ..............
The second picture .......... is that a helicopter behind the glass ?
Old Oct 28, 2012, 07:47 PM
Joined Sep 2012
Yes it is. Need to get this castle quick connect so i can do a no load data to determine a safe prop size.
Old Oct 28, 2012, 10:14 PM
moparmyway's Avatar
New York
Joined Jan 2009
Quick connect isnt needed
You need Castle Link
What MEGA is it ??
Looks like a Sikorsky or a Bristow
Old Oct 28, 2012, 11:31 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
San Francisco Giants Sweep Detroit Tigers in the world series.
Yeay!!!!
That is some MEGA power right there.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
