Old Oct 20, 2012, 03:49 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
So going by the fact of inefficiency loss (33%)
Then 4KW should get you to almost equal to the power of the 7X7 prop setup!
Which means you will go about a little bit faster toward to end of your runs!
But your punch-out won't be the same!
Now EDF's sounds freaking cool.
I am interested in using one of those 10 and 12 blade EDF's that are out now.
They spound more realistic, and seem to run cooler!
80 mm fan is a good size, to start with.Good luck brother!
Damm rain started and they are talking about snow down to the 3500 foot level.
Which means we got about 2 weeks in Oregon!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Oct 20, 2012, 07:00 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
This big motor might just make close to those 4000W at EDF RPM and power levels.
murdnunoc is offline Find More Posts by murdnunoc
Old Oct 21, 2012, 03:37 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by murdnunoc View Post
And yes, Mopar...
... I know how this looks.
Dude,
It looks like youre building an EDf Stryker !!
Me too !!!!
i am happy to see another EDF Stryker .................... many ways to get it done !!
moparmyway is offline Find More Posts by moparmyway
Old Oct 21, 2012, 04:58 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Any further news on yours, Mopar??
Old Oct 21, 2012, 07:03 PM
moparmyway's Avatar
New York
Joined Jan 2009
Working through the design concepts and practical application as we speak
Old Oct 21, 2012, 08:43 PM
Milwaukie , Oregon
Joined Feb 2003
Hahahaha
I just pulled a new 90mm out of a box.
I won't have it done anytime soon!
Old Oct 22, 2012, 06:13 AM
moparmyway's Avatar
New York
Joined Jan 2009
What kind of 90mm EDF did you get ?
Old Oct 22, 2012, 10:20 AM
Milwaukie , Oregon
Joined Feb 2003
My friend, bought one and thought he would let me play with it.
https://www.hobbyking.com/hobbyking/..._Fan_Unit.html
Well I am going to play with it. rite after I mount a motor to it and put it with anohter in the A-10. I have heard many nice things about these newer EDF.
Old Oct 22, 2012, 10:50 AM
moparmyway's Avatar
New York
Joined Jan 2009
MY GOSH !!!!!!!
i thought you were gunna give a link to an aluminum EDF ...................
You will have tremendous thrust with a 12 blade fan, but how will the top speed be ???
I suppose we will just have to see !!
Are you gunna choke down on the discharge to increase the e-flux speed ?
Old Oct 22, 2012, 10:57 AM
Milwaukie , Oregon
Joined Feb 2003
The EDF is going to a combat models 60" A-10 Warthog.
I still have to build the kit
Combat Models A-10 flight (3 min 30 sec)
Old Oct 22, 2012, 11:04 AM
moparmyway's Avatar
New York
Joined Jan 2009
Sorry Doc,
But that video of an A-10 wallowing in the turns and playing chicken shiiiiit with WOT for 5 seconds doesnt make my blood flow ....................... even the grassy takeoff seemed boring !!
33% power landing ??????????
And it looked like a crash ?????????/
I hope your A-10 will be better than this video !!!!!!!!
I suppose if it aint a Stryker ............................................. well you know !!!
Old Oct 22, 2012, 11:20 AM
Milwaukie , Oregon
Joined Feb 2003
They built it to be flown at WWII shows.
It is nice.
But it is mostly a Hangar Queen!
Mine is not going to be made for the hangar.
I am looking at a 8S setup.
8.5 lb plane needs 200 watts a lb = 1700 watts x 2 = 3400 watts
Really I am wishing it stays together when I punch it!
And yes I will be vaccum the wing!
Old Oct 23, 2012, 03:47 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
Some inspiration &encouragement for murdo:
NASA cruise efficient STOL aircraft concept (0 min 36 sec)
I do wonder whether "robbing" the high-pressure flow off of the lower side is going to require a higher angle of attack and an increase in drag, but at least one of NASA's CESTOL concepts is doing something similar...
Yep EDF is for sure not the most efficient way to squeeze speed. I'm doing it for the challenge and a new experience. Plus... we all know a jet's COOL factor makes up for the inefficiency.
Having 40% of the fan's intake below the plane should also take some advantage of the higher air pressure on the bottom of the airfoil to ram more air into the fan.
I'll also be happy to compare the integrated fan setup with a top mounted one, if that's the route any other EDF Strykers have used in this power range.
I'm only choking down the fan's thrust tube to 82% instead of the 75-80% I'd use for a more slippery airframe.
I'll be cleaning up the intake areas on both top and bottom to get the smoothest air possible into the fan.
The Eflite 80mm fan takes a 28mm inrunner, so I'm going to use the biggest 28mm Mega I have to slam it with 3kW and 52,000 RPM or better.
16/45/1.5RCE at 1985kv would run around that on 9S.
3kW on a 7x7 prop will push my Strykers to around 170mph, so yeah, the speed will take a hit with the 28mm setup.
But the airframe may also get a fan and motor upgrade at some point, too
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Oct 23, 2012, 05:10 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
interesting shape..i like it...
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Oct 23, 2012, 05:24 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
http://www.youtube.com/watch?v=Sa-w6M5UR5U
I think the concern is valid. Only makes sense that (assuming the higher pressure actually does make it into the fan) there would be less pressure differential, causing reduced lift.
I won't really fret about losing some lift on high speed stuff, though. The Stryker has a lifting airfoil at 0 degrees angle of attack. And the faster you go, the more lift the airfoil generates unless you lower the AoA. I haven't proven it, but my suspicion is that a 150+mph Stryker is actually flying at a negative AoA, causing increased drag.
So I'm happy to dump some of my lift into the power system!!
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
