Old Oct 10, 2012, 08:08 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
These are my favorite design.
Every one pictured below is the exact same design, sharpened and epoxied.
moparmyway is offline Find More Posts by moparmyway
Old Oct 10, 2012, 04:31 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by moparmyway View Post
Like below ...........
Thanks for the photos.
I have the motor mount supplied by MD.
eckace1 is offline Find More Posts by eckace1
Old Oct 14, 2012, 01:05 AM
Hornetnz is offline
Find More Posts by Hornetnz
United States, NC, Raleigh
Joined Jun 2005
Are there any ~$50 motors that will get my upgraded Stryker to 130+ flat & level on 4s? I'm using a MEGA 16x15x3 i think now and its just under 100 level flight.
Hornetnz is offline Find More Posts by Hornetnz
Latest blog entry: 93" AJ Laser 230z
Old Oct 16, 2012, 09:38 PM
tippy1404 is offline
Find More Posts by tippy1404
Joined Sep 2012
Fast/Heavy Stryker build 1
Description:
Description:
tippy1404 is offline Find More Posts by tippy1404
Old Oct 16, 2012, 10:00 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Originally Posted by tippy1404 View Post
im staying tuned. this ship looks fast and wicked just laying there
THESANDMAN is offline Find More Posts by THESANDMAN
Old Oct 17, 2012, 04:16 AM
moparmyway's Avatar
New York
Joined Jan 2009
What motor and motor mount are you using ?
What color is the bottom ?
Old Oct 17, 2012, 09:56 AM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Define heavy. Is that a KDE mount?
Please list your setup, video of speed runs would be nice
FCA
Side note my order from lone star balsa should arrive today
FLAME747 is offline Find More Posts by FLAME747
Old Oct 17, 2012, 11:33 AM
Joined Sep 2012
Motor- 22/35/1.5es, kde direct modified mount to fit 36mm, 4lbs, its just primer right now. Hv120, 3300 6s. Kind of curious what prop to start with. Any input would be great.
Old Oct 17, 2012, 12:59 PM
moparmyway's Avatar
New York
Joined Jan 2009
Hi Tippy,
You wouldnt happen to have a no load data graph or file from your ICE esc for your 22-35-1.5se would you ?
How close is it to 1535kv ?
Then I will answer your prop question ............. also what "C" rating are the 3300 ??
Also, what are your elevons made of and how are they attached ??
What kind of strengthening did you do to the fuse ?
Any glass or resin ?
What are your verticals made of and how are they attached ?
Are you throwing it or bungee ?
OK, answer those and I will answer your prop question.
Old Oct 17, 2012, 06:06 PM
Joined Sep 2012
Haven't got to do any data logging yet. The 3300 6s is 30c-70c, going to use elevon wood stock, and going to attach them using the rite wing style with tape and adhesive, the fuse has carbon rods through it in numerous spots using gorilla glue and then covered with a bondo substance called icing, the verticals are 4mm wide wood paneling, going to use a bungee launcher, i work with brolley who is also building a stryker
Old Oct 17, 2012, 09:29 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Tippy and Brolley,
Both your builds are looking great!
Different construction techniques are evident in each build, and each has great elements.
Tippy,
You have an awesome motor. Look forward to hearing how it makes your bird scoot.
There'll be a lot of power going to that motor mount area. I didn't see any carbon reinforcement under that spot. I think you'd get a lot of security and performance benefit from some reinforcement in that area.
You might be able to extend the nose-to-tail carbon if it's a hollow tube by inserting a smaller tube into the current one, and making a splice joint that goes all the way to the trailing edge of the motor mount area.
Any fiberglass planned for this build? The carbon sparring you have in there now should make the bird good to 130mph. Add Mopar's epoxy coating method and I'd say good to 160mph. Above that and any bird I'd fly would have full 3/4-1oz. glass on it.
Medium-hard balsa for the trailing edge will beef up the hinge line for no worries there.
Your motor should be capable of 175mph+ level, no-wind.
murdnunoc is offline Find More Posts by murdnunoc
Old Oct 17, 2012, 09:32 PM
FLAME747 is offline
Katy, TX
Joined Dec 2009
2" elevon stock came in
Only tapered on 1 side
Will call lone star tomorrow ask if they can make some that is tapered on both sides
FCA
Old Oct 17, 2012, 09:34 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Brolley,
I have to say flat out brilliant on your carbon layout!!
The steep short sections near the wingtips will help fight any twisting motion in the wing. Like it.
How fast/fun are ya shooting for?
Can you share the intended power system?
Old Oct 17, 2012, 09:47 PM
Joined Sep 2012
Good call mopar. We'll figure out something, thanks. Ill update a no load data log tomorrow.
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 11:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 08:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 09:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 09:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 01:34 PM
