Old May 26, 2012, 09:11 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I am. I glide it around quite a bit.
mclarkson is offline Find More Posts by mclarkson
Old May 26, 2012, 10:30 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
You should just pick up a 2836 2350kv and run a APC 6 x 4 sport prop.
Start out with a 3s batt and later step up to 4s with no other changes needed.
I love that setup.
It's cheap, fast and even runs in the stock mount if you hog it out a little with a dremel sanding drum.
IFlyRCs is offline Find More Posts by IFlyRCs
Old May 27, 2012, 06:40 AM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
I love that setup.
i agree and i love that set up as well and dont forget cheap clone apc props from HK
ive been running that set up on all my stykers and funjets and scratchbuilt pusher jets for over a year
THESANDMAN is offline Find More Posts by THESANDMAN
Old May 27, 2012, 03:17 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
2836 ?
That is not what I had in mind when I said he needs a good motor.
But I guess it all depends on a person's budget.
To get help with Turnigy motors:
http://www.rcgroups.com/forums/showthread.php?t=1213360
______________________________________________
A friend just stuffed his Stryker into ground...The fuse is smashed beyond repair.
Gary's motor mount is still in its place in the back of fuse and holding on to the 180+ gram motor.
He might post a pic....or let me post it.
****The motor mount just more than paid for itself.
http://www.customrcparts.com/index.p...products_id=58
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jun 02, 2012, 09:23 AM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
Well heading out with my latest build today
Mega 16/30/1.5SEC
2500 4s 7x6 sport
HS 82
AR 7000
ICE LITE 100
Stryker was maidened on Wednesday,I'm hoping to get some video to share.
rimripper is offline Find More Posts by rimripper
Old Jun 02, 2012, 11:50 AM
GryphonRCU's Avatar
Joined Mar 2008
Rim,
7X6 ....oooh testing the limits because you can (given your cool Canadian air).
Better now than later on in summer.
That will be some great power in that 7" prop.
Vertical acceleration runs will see max AMPs for longer.
Be extra safe/careful today if the build is on light side,
2000 posts huh, way to go Rim.
Gryphon
Old Jun 03, 2012, 09:24 AM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
Well I did get to get out for a flight yesterday,it was quite windy,but the Stryker took it in stride!!!!
I find with perfect COG in the dots,it's really sensitive to inputs.
I did do the "dive" test also,when in a full dive with no power it will stay in the desired angle of attack with the R stick hands free.
That is the proper way for dive COG testing is it not??
Old Jun 03, 2012, 09:58 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
It sure is, now you gotta nail it as you are running straight ......... if she stays true, you are good to go, if she goes up or down, its a thrust line issue !!!!!
moparmyway is offline Find More Posts by moparmyway
Old Jun 03, 2012, 10:05 AM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
Ok so any pitch up or down,and I need to adjust mount presure on front or back of mount,in whichever direction it needs to be adjusted,correct?
Old Jun 03, 2012, 10:07 AM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
I also meant to bring up that after yesterday's flight,I got home to pull the ice file,and all it showed was the boot up sequence....
Heading out today again.
Old Jun 03, 2012, 10:43 AM
moparmyway's Avatar
New York
Joined Jan 2009
You got it Rim !!
Now, lets see some video of it in action !!!!!!
Old Jun 03, 2012, 09:55 PM
NOTAR 600 is offline
Find More Posts by NOTAR 600
ohio usa
NOTAR 600's Avatar
Joined Nov 2007
Hello stryker team! What a great season for flying we are having! I can't believe how often I've crashed with my original F27C brushless motor grinding the prop into the ground at full throttle....until my reflexes finally turned off the power. Many times I thought this motor had a bent shaft due to the extreme forces it has been subjected to time and time again. But in the end I always find that after careful inspection....it turns out to be a bent adapter...or I had the adapter cranked too tight.....or I reamed out the prop off center. This skinny motor shaft is still perfectly straight as the day it was made. I even took the motor apart and beat on it with a hammer once. It must be made out of cryptonite!
NOTAR 600 is offline Find More Posts by NOTAR 600
Old Jun 04, 2012, 07:31 AM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
That's nothing! I put my motor in the cement truck that the Mythbusters blew up. Still works as good as new!!
(sorry couldn't help myself... )
cjbucher is offline Find More Posts by cjbucher
Old Jun 04, 2012, 10:17 AM
ohio usa
NOTAR 600's Avatar
Joined Nov 2007
Ok....well then.....I'll try putting mine in that car they blow off the runway behind the boeing airliners blasting jet engine!
Old Jun 04, 2012, 01:03 PM
cjbucher is offline
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Originally Posted by notar 600 View Post
ok....well then.....i'll try putting mine in that car they blow off the runway behind the boeing airliners blasting jet engine!
mike
lol!
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
