Old May 03, 2012, 09:16 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
OK, best prep for a new Fuse. Before glassing etc.
Best sanding material
Cleaning fluid? Isopropyl?
You guys have build more of these than anyone I know.
After prep, best lightweight treatment? WPU, Epoxy?
Thanks in advance
Rick
Rickflaguy is offline Find More Posts by Rickflaguy
Old May 04, 2012, 12:09 AM
erashby is offline
Find More Posts by erashby
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
stick motor mount
Originally Posted by Rickflaguy View Post
OK, I can buy a Q setup (motor and ESC from a local friend. I need a cheap mount so I can buy the motor and ESC. Later I will upgrade. Any ideas? Is the stick in a groove a no go or is it a good start for now?
The stick mount is a sturdy mount. I have crashed my 300W wing at about 70 mph and the motor mount remained undamaged and the thrust angle unchanged. The key is to keep the mass of the motor as close to in-line with the stick. Here are some picks of my motor mount setup. The motor mount is $1.95 at headsuprc.com.
http://www.headsuprc.com/servlet/the...sh--for/Detail
erashby is offline Find More Posts by erashby
Old May 04, 2012, 12:25 AM
erashby is offline
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Thanks in advance
Rick
IMO glassing is not worth the hassle and is harder to repair.
I ultra coated my last stryker, but also would not recommend that (see pics below). My next Stryker will be laminated. It is stronger than ultracoat or monokote. It is as easy to do as any iron on coating. It really stiffens up the foam. It looks just as good as glassing, well when the plane is flying and atleast 20 feet away.
Old May 04, 2012, 03:29 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Thanks in advance
Rick
Build it with CF tubing, minimum number determined by intended max speed
Coat the fuse with a good epoxy (with glass if you wish) and heat treat it, then let it cure 2-3 days (no cleaning fluid necessary this way)
Best sanding material .................. you wont need any this way !
moparmyway is offline Find More Posts by moparmyway
Old May 04, 2012, 04:33 AM
Joined May 2011
Pardon the idiot newbie question but laminating is ?
The LHS guy told me someone in Satellite beach (Florida) sells an epoxy blend made just for glassing fc foam. Anyone hear of them?
Old May 04, 2012, 05:13 AM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
laminating, in this context, is... frequently a transparent thermoplastic covering with a thin film of hot melt adhesive on one side. More or less the same stuff as is used to make plastic coated ID badges. For example http://www.alofthobbies.com/new-stuff-5mil.html
more info... http://www.rcgroups.com/forums/showthread.php?t=790302
Also, not to contradict the elders but I like a quick wipe of acetone and then alcohol, on a paper towel, to clean up the oils off the surface of z-foam & epo. It doesn't damage the foam and I believe it helps any covering or coating adhere better.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old May 04, 2012, 08:02 AM
moparmyway's Avatar
New York
Joined Jan 2009
No contradiction .............
But please allow me to foray down the road a little ............this process is still very unfamiliar with lots of dudes.
With the heat treatment I suggest, (regardless of including glass or not) after painting on a coating of good epoxy, the foam opens up and sucks in the epoxy, much like capillary action and solder. This heat treating works on the foam as it is, no prep necessary. When the epoxy cures, you can paint right over it, then add another light coat of epoxy over your paint to protect the design, (no more heat treating) and you have yourself one very sturdy and strong piece of foam with an exoskeleton ........ a 3 dimensional epoxy/foam matrix that is just about impossible to "peel off" and wont crack or break off in pieces like if the foam was prepped with alcohol, acetone, or any other solvent/cleaner before covering with epoxy.
Old May 04, 2012, 11:43 AM
Joined Mar 2010
Ah, so you're applying heat to open the cells after you apply the first coat of epoxy, and then the cells shrink to clamp a thin film of epoxy when the heat comes off. That makes me one of the dudes who, duh, wasn't quite getting it from your original posts about popcorn.
Sounds like a technique to practice on some debris.
I had mistakenly thought that your process was to heat treat the surface, as one might to release dented foam, and then coat it - so it seemed like here you were suggesting heat to kick of the epoxy and flash volatile oils off the foam surface.
Thanks for taking the foray.
Old May 04, 2012, 12:20 PM
moparmyway's Avatar
New York
Joined Jan 2009
Anytime Dude !!
The cells do not shrink when the heat comes off, they just stop popping and stay as is.
After you remove the heat, maybe they continue to "pop" for a second if you have applied too much heat, or got too close to the foam, but they definately do not shrink.
Best to do like you stated, try it on a piece of scrap. Once you get it just right, you will like the outcome.
Just remember, you need a good epoxy (1:1 vinyl based ones arent good) and let the epoxy cure for at least 2-3 days without touching or moving it, no matter what !!!
Old May 05, 2012, 02:36 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Not a C but close......
Mega 22/50/1.5RE, 7 cell 4000 and Q40 7.4x7.5 make it go OK!
More details here - http://www.rcgroups.com/forums/showp...&postcount=145 - if you are open to the way of the future....
Peter M is offline Find More Posts by Peter M
Old May 05, 2012, 03:14 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Very cool, Peter!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old May 05, 2012, 06:54 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Congratulations on your maiden Peter.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old May 05, 2012, 08:19 AM
Joined May 2011
I don't quite get the website. Giving 2 dimensions. 18'x5mil leaves an infinite set of lengths fro thin air to infinity. How long are the rolls and what kind of paint does it take?
Old May 05, 2012, 12:43 PM
Joined Mar 2010
Hmm, maybe this page will make it clear:
http://www.canuckengineering.com/new...mil-cp-18-wide
As to paint, google could probably get you there pretty quick:
http://www.google.ca/search?q=paint+...e:rcgroups.com
....http://www.rcgroups.com/forums/showthread.php?t=1076935
Old May 05, 2012, 01:24 PM
moparmyway's Avatar
New York
Joined Jan 2009
I am getting a stiffy !!!!!
Congrats on that awesome terror !!!!
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
