Old Aug 26, 2006, 05:45 PM
beanie is offline
Find More Posts by beanie
Ann Arbor, Michigan, United States
Joined Sep 2003
great pic H-J. wow! $3000... i wish i coulda gotten one.
'you've got mail!'
enjoy
-beanie
beanie is offline Find More Posts by beanie
Old Aug 26, 2006, 05:50 PM
beanie is offline
Joined Sep 2003
ok, next step was to glue the formers into place. this goes pretty quick as well. i just marched down the fuse from BH#1 down to BH#7.
-beanie
Old Aug 26, 2006, 05:59 PM
beanie is offline
Joined Sep 2003
i was being cheap, so i used 6mm FFF for the entire build, including the sheeting. using 3mm may have saved some weight, but right now the plans are set up for 6mm sheets. to keep scale, if someone uses 3mm sheets, then the bulkheads should be enlarged by the appropriate amount.
-beanie
Old Aug 26, 2006, 06:43 PM
DCobra is offline
Find More Posts by DCobra
Live to fly, fly to live!
DCobra's Avatar
New Bern, NC
Joined Dec 2003
Did the FFF work well for sheeting? Is that the new stuff or the dwindling stock of good FFF?
Im anxious to try the Green Guard as sheeting on a future build.
Paul
DCobra is offline Find More Posts by DCobra
Old Aug 26, 2006, 06:49 PM
J Morgan is online now
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I must be different because I got some of the new "bad" fanfold and like it. It only has plastic on one side and is very pliable. Since I strip the foam and glass anyway it saves some trouble.
J
J Morgan is online now Find More Posts by J Morgan
Old Aug 26, 2006, 06:56 PM
DCobra is offline
DCobra's Avatar
New Bern, NC
Joined Dec 2003
So you're liking the new foam as long as you glass it?
The Green Guard is pretty pliable as well, for me it will come down to cost per bundle when I run out of my current stock of FFF and (FREE!)Green Guard.
Paul
Old Aug 26, 2006, 07:05 PM
beanie is offline
Joined Sep 2003
i like the new FFF for the sheeting. like J said, its a little more flexible, so its great for sheeting curves without breaking. i try and save the good old stuff for the pieces that need to be a little more firm... like wings, stabilators and fins.
-beanie
Old Aug 26, 2006, 07:14 PM
beanie is offline
Joined Sep 2003
next is installing the motor mount support. it is tucked under BH#7. then the hard stick motor mount is glued in. i designed this section so that there is quite a bit of support from the motor mount support, BH#7, aft planform and the fin. it gets sandwiched in there nicely and tightly. i had no problems mounting it straight on for my mig-25, so i did the same here. i keep everything to scale... so no cheating on the fin, wings, stabilators. this is important because of the degree of sweep the mig-21 has in the stabilators. you'll need to lay the stabilators and fin in place. then put the motor in with its appropriate prop to make sure you cut the motor mount long enough such that the prop doesn't hit the swept fin or stabilators.
now on to the ailerons...
-beanie
Old Aug 26, 2006, 08:57 PM
beanie is offline
Joined Sep 2003
ok, before the skinning is placed, i decided to install the aileron linkages. for this bird, i opted to keep her looking a little more sleek and placed the servo inside the fuse. i just used 1 servo for the ailerons... gettin' poor, need to conserve $ and resources
i used 0.055" piano wire. 90 degree bend into the aileron. then run it along the edge of the LE of the aileron. then through a plastic tube and finally another 90 degree bend upwards.
a trench is cut out for the plastic tube. the aileron LE is sanded to a wedge to allow easy movement. i drilled a hole into the aileron for the control rod to insert into. then the plastic tube is glued to the fuse planform.
-beanie
Old Aug 26, 2006, 11:14 PM
beanie is offline
Joined Sep 2003
aileron hook up. i used some commercial aileron linkages from the LHS on my first build. but, on the second version, i borrowed AC's idea of simply using heat shrink as the junction. i used a couple layers to strengthen it. i had problems with the original commercial linkages because the 0.055" piano wire was too thin for it to grip to. we'll have to see how she holds up. the second version has control surfaces with much less slop.
i used the same plastic tubing as guide rails to help prevent flexing of the control rod.
a servo holder was made from FFF as well.
-beanie
Old Aug 26, 2006, 11:19 PM
DCobra is offline
DCobra's Avatar
New Bern, NC
Joined Dec 2003
What was the brand of those linkages Ben? I've needed similar stuff and had to cobble it together...I like those setups, even with the heatshrink.
Paul
Old Aug 26, 2006, 11:24 PM
beanie is offline
Joined Sep 2003
hey paul, i think i got dubro linkages. i don't have a part number cuz i tossed it quite a while ago. the problem with the heat shrink is that it still slides around a bit. i would recommend a tiny dab of epoxy or CA to fix it in place. i still had a little slop despite that (all of my planes are kinda sloppy). but when i used AC's method on the second build, there is WAY less slop. i'm sold on his aileron linkage method as well as finishing method. i did have some concerns that over time, the metal pushrods would cut into the heat shrink and lead to failure at some point... but i'm sure, my plane won't survive that many flights for this to happen (i've got way too dumb thumbs). ie, the 25 missions needed for the b-17 crews in WWII is a statistical impossibility for me
-beanie
Old Aug 27, 2006, 12:54 AM
DCobra is offline
DCobra's Avatar
New Bern, NC
Joined Dec 2003
Lol Ben...just keep her 3 mistakes high and you'll do fine!
The majority of my crashes come when I'm down playing in the dirt, or yanking and banking too hard.
If I could make myself fly in lazy circles, I'd have 25 flights easily. Take that approach and you'll be amazed at how long your planes will last.
Thanks for the heads up on the Dubro linkages.
Paul
Old Aug 27, 2006, 06:46 AM
beanie is offline
Joined Sep 2003
before the sheeting is applied, i installed all the electronics. we've got the ailerons done. next is the esc and motor wiring. i fall into the group of people that lengthen the motor-esc wires as opposed to lengthening the esc-batt group. this has worked for me so far. i know others swear by the other method. despite the debate, doesn't seem like it makes all that much difference at the short extension lengths we are using.
anyway, i twist the wires, wrap them in aluminum foil and then thread them through their own holes in the bulkheads. i didn't want them rubbing up against the metal control rods running down the middle.
-beanie
Old Aug 27, 2006, 07:23 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Paul
EXACTLY! Just about the time you think you're Maverick, it brings you down to Earth!
J
Mini-HowTo Mig-21 Fishbed Build cdebaca Pusher Prop Jet Models 152 Aug 16, 2006 09:06 PM
Mig 21 Ducted fan Jet Kit + For Sale Endeavour105 Aircraft - Fuel - Airplanes (FS/W) 4 Feb 07, 2005 03:13 PM
Mig 21 Ducted fan Jet Kit + For Sale Endeavour105 Aircraft - Fuel - Airplanes (FS/W) 15 Feb 05, 2005 04:26 PM
Mig 21 Ducted fan Jet Kit + For Sale Endeavour105 Aircraft - Fuel - Airplanes (FS/W) 0 Jan 24, 2005 05:01 PM
MIG-21 FishBed leesops Electric Ducted Fan Jet Talk 22 Sep 13, 2003 12:31 PM
