Old Aug 26, 2006, 10:14 AM
jinithith2 is offline
Find More Posts by jinithith2
Just a sip
jinithith2's Avatar
Hudson, OH
Joined Jul 2006
how to repair damaged parts under sheeting?
Would it be really difficult to repair parts under sheeting?
thanks in advance!
jinithith2 is offline Find More Posts by jinithith2
Old Aug 26, 2006, 10:46 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
It is easy for a master craftman. It is hard for a klutz. Superman, using his X-ray power, makes it easy.
It you want advise, describe the boo-boo exactly with every fact. A picture would be helpful.
Ollie is offline Find More Posts by Ollie
Old Aug 26, 2006, 11:21 AM
Just a sip
jinithith2's Avatar
Hudson, OH
Joined Jul 2006
I was just wondering cause I'm a first time builder and I'm debating on whether or not sheeting would make repairs unnecessarily difficult.
Let's just say one of the fuse formers collapsed or shattered under the sheeting.
What would I do?
Old Aug 26, 2006, 12:12 PM
Ollie is offline
Punta Gorda, FL
Joined Apr 2002
Design the structure better with lighter weight and higher strength. If the former shattered, it depends on the former. Is the former made of balsa sheet with one grain direction, built up balsa former with two or more grain directions, lite ply, birch ply? It depends on the fuselage dimensions and the uses of the model. It depends on the spacing between the formers. Repair is easier with wood glue type and amount. The wood is 5 to10 times strength with the grain compared to cross grain strength. A simple former with one grain is weak because of its cross grain strength. A built up former or ply wood former is much better.
Are you worried about the former shattered because hanger rash or flying crash? Be careful!
Avoid the boo-boo by careful flying. Don't fly beyond you flying skills. If you don't have enough flying skills, get a teacher to help you flying at high alitude.
Old Aug 26, 2006, 12:20 PM
Just a sip
jinithith2's Avatar
Hudson, OH
Joined Jul 2006
You can go to my Stuka buil thread or my blog to see the pics of the formers, but for now, that is gonna have to be the best solution-don't crash
Old Aug 26, 2006, 12:21 PM
Just a sip
jinithith2's Avatar
Hudson, OH
Joined Jul 2006
oops, this thread is supposed to be in builder's workshop... dang!
Old Aug 26, 2006, 12:35 PM
Ollie is offline
Punta Gorda, FL
Joined Apr 2002
Put two 1/16 x 1/16 " balsa sticks to build up the former so it doesn't crack short cross grain either end of the former. No problem!
Old Aug 26, 2006, 12:42 PM
Just a sip
jinithith2's Avatar
Hudson, OH
Joined Jul 2006
aha! I'll try that, thanks for the advice!
Damaged MiniBlade Wing - How to Repair? screamin' eagle Slope 17 Apr 05, 2005 06:40 PM
Projeti wouldn't fly... how to repair missing foam ericdod Foamies (Kits) 18 Oct 09, 2002 12:13 PM
Crashed Lite Stick - How to Repair? (Newbie ??s) SouthernFlyer Parkflyers 6 Sep 12, 2002 11:22 AM
How to cut accurate parts from plans? cold boy Beginner Training Area (Aircraft-Electric) 2 Jun 17, 2002 04:50 PM
How to Repair an astro 40 BuyPlaneBill Beginner Training Area (Aircraft-Electric) 1 Jan 11, 2002 10:19 PM
