Old Aug 25, 2006, 01:35 PM
nik112233 is offline
Find More Posts by nik112233
Simi Valley, CA
Joined Feb 2005
Question
Multiplex radios' max safe charge current?
Can you guys please advise what is considered a safe charge current for Multiplex radios when charging with the battery pack in the radio? (Also from practical experience, please)
I have a 2500mAh NiMH pack and I am currently using 0.8A but would like to go higher if I could...
Nik
nik112233 is offline Find More Posts by nik112233
Old Aug 25, 2006, 02:25 PM
Brian Wa is offline
Find More Posts by Brian Wa
UK
Joined Sep 2002
It all depends on the size of the fuse in the charging circuit in the transmitter.
If you charge at a higher amperage than the fuse is rated at, then it will blow.
The Multiplex 3030 had a 1 amp fuse fitted,
The Multiplex 4000 has a 2 amp fuse fitted.
An easy modification is to fit a Multiplex 6 pole socket directly to the Battery, this way you can charge at 8 amps if you wish, with a home made lead.
You have to remove the rear cover of the TX to charge.
Very handy for quick charging at competitions, I have used this system off and on for about 12 years.
Multiplex radios are unique in that they usually use 6 cell packs in their TX's
Brian
Brian Wa is offline Find More Posts by Brian Wa
Old Aug 27, 2006, 11:29 PM
spatial is offline
Find More Posts by spatial
fullhouse newbie
spatial's Avatar
Melbourne, Australia
Joined Dec 2004
If it's an evo the max current for charging with the battery in the TX is 1.5A.
Section 8.4 of the manual covers the do's and don'ts in detail.
spatial is offline Find More Posts by spatial
Old Aug 28, 2006, 01:05 PM
Simi Valley, CA
Joined Feb 2005
Thank you both for the info, I get the idea. To be more specific - I have the Cockpit MM.
How to calculate safe-maximum current draw from a pack ? ARE Electric Plane Talk 4 Jan 09, 2002 06:45 PM
What is safe charge rate for 2000 Nimh Panasonics ? Al P Electric Plane Talk 5 Jul 18, 2001 12:22 AM
what is max rate to charge NiMH? atsiang Electric Plane Talk 4 May 25, 2001 06:36 PM
