Old Aug 25, 2006, 04:51 AM
dr.5euss is offline
Find More Posts by dr.5euss
Joined Aug 2005
Barges
Hello,
I was wondering what the best way to make a barge hull is? Is blue foam a good idea, or balsa? Also, is there some putty stuff you guys put on and sand?
Any pictures of barges would also be appreciated - I'm thinking of making one in 1/24, but 8ins wide and 1ft long.
dr.5euss is offline Find More Posts by dr.5euss
Old Aug 25, 2006, 05:25 AM
herrmill is offline
Find More Posts by herrmill
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
What type of barge?
What type of barge are you wanting to build?
Here are several types that you can chose from among the many available on Google.
herrmill is offline Find More Posts by herrmill
Old Aug 25, 2006, 05:28 AM
dr.5euss is offline
Joined Aug 2005
Hi Hermill,
Sorry I didn't specify - like the 55.0 KB one.
Old Aug 25, 2006, 06:47 AM
herrmill is offline
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
US bulk cargo barge
That is a typical bulk cargo barge used on most US waterways. Having lived on the Ohio River, I've crawled over a few of them as a boy.
You may want to look at the Dumas kit that offers both one raked bow & one box barge that matches their American Beauty tow boat kit. Both the barge & the tow boat links are shown below along with photos from their site.
http://www.npr.org/templates/story/s...toryId=5686878
http://www.dumasestore.com/catalog/p...roducts_id=198
Old Aug 25, 2006, 07:16 AM
towboatjoe is offline
Find More Posts by towboatjoe
River Rat
towboatjoe's Avatar
Flatwoods, KY
Joined Feb 2006
A 1:24 barge 8"x12" would be more of a rigging flat. A standard size barge is 195' x 35' and 200' x 35' which is 1:24 scale would be 100" x 17 1/2" for the 200 footer.
Smaller barges are the short barges that go into unit tows which are usually 145' long. Also there the rigging flats I mentioned which can range from 12' up to 40'. There's crane flats averaging from 30' to 200' and various speciality barges that can range anywhere from 30' to 640'.
Here's some more examples for you.
towboatjoe is offline Find More Posts by towboatjoe
Old Aug 25, 2006, 07:36 AM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Hi Joe,
Well, Dr. 5euss asked the right question of the right guy, as you and River Bill are as in the know on these things as anybody.
Making a barge is as easy as making a box, or you can get fancy on the ends and ramp them up a bit, put skegs on, etc.
Besides Dumas, Microglass makes a fiberglass generic version, 36" long by about 9" wide that will fit many applications.
Probably the best bet is to get some doorskin plywood, and some epoxy, and just be creative.
der kapitan is offline Find More Posts by der kapitan
Old Aug 25, 2006, 07:43 AM
River Rat
towboatjoe's Avatar
Flatwoods, KY
Joined Feb 2006
I would use bass wood to frame up the hull and place sheet foam in it after sealing the wood with a sealer ( just in case you ever got a leak)
See if this will work for what you're looking for.
Old Aug 25, 2006, 07:50 AM
River Rat
towboatjoe's Avatar
Flatwoods, KY
Joined Feb 2006
You're right there kapitan. It's always a good idea to make a convertible deck when you're building only one barge so you can convert it into different types of barges.
I built a pallet of oil drums that I lift from my AmClyde crane deck over to other boat decks and the adults seem to be intriged by it more than the kids.
One thing about barges. You can build anything and somewhere out there I'm sure you can find something close to what you created.
Old Aug 25, 2006, 07:54 AM
dr.5euss is offline
Joined Aug 2005
Wow, thanks for all the replies !
That plan seems good. I've just nipped out and bought some thin balsa and thicker stuff for the supports. I'll let you know how I get on!
Old Aug 25, 2006, 08:11 AM
dr.5euss is offline
Joined Aug 2005
Hi,
Did/do some barges have flat ends? I think it would be easier for my first build.
Also, if it's 8 inches wide, how 'tall' does it need to be?
Old Aug 25, 2006, 09:47 AM
DanL is offline
Find More Posts by DanL
DanL's Avatar
United States, MN, Brainerd
Quesion for TBJoe
I built four 1/48 scale "box" barges to use together as a tow. They are 35 x 145 scale ft (8.75" x 36"). Two have the upward slanted bow/front deck and two are plain box ends. They have double bollards at each of the four corners.
Some questions, please. How are the barges lashed together? Also, I don't have a towboat, but a regular "pointed" bow, 98 scale ft tug. Does that type of tug ever push tows? How are they rigged if they do?
I'll post the barge pics and some construction notes if anyone is interested.
DanL is offline Find More Posts by DanL
Old Aug 25, 2006, 10:03 AM
Boatfox is offline
Find More Posts by Boatfox
Give the dog a bone
Boatfox's Avatar
USA, NV, Las Vegas
Joined Aug 2005
This may help...Barge CAD interactive
Barges are lashed together with steel cables, chain, ratchets and big steel bars to beat upon the equipment (toothpicks). Pointy tugs almost NEVER push the barges, but the do come up on the sides for a hip tow in tight quarters or in harbors. The bow of the tug points ~20-30 degrees into the centerline of the barge. Rear spring line, forward bow backing line, and stern line are the minimum attachments to the barge. One of us must have a picture of this arrangement somewhere.
Edit found it. Here is a nice overview of towing too.
Boatfox is offline Find More Posts by Boatfox
Old Aug 25, 2006, 10:46 AM
Joined Jun 2005
towboatjoe said:
"You're right there kapitan. It's always a good idea to make a convertible deck when you're building only one barge so you can convert it into different types of barges.
One thing about barges. You can build anything and somewhere out there I'm sure you can find something close to what you created."
Yes Joe, it's a good idea to make them versatile
On barge sizes, I built one about 15 years ago that was 8 3/4" by 35 1/2"", which was just the right size to carry a 12-pack of beer, the cans laying side by side crosswise. The beer, of course, was just there to ballast it down---.
It was pushed by a little 15" utility tug, which I still have, but the barge is now down in New Zealand being used as a video camera float. I still have the mold, and the barge shell is available from Microglass.
Karl
Old Aug 25, 2006, 11:08 AM
DanL is offline
DanL's Avatar
Boatfox...Thank you!
Great info! The one and two barge rigs are perfect for my tug. It has an operating rear winch that can be used for the stern line.
Does one tug ever take up to four barges? How might that be rigged?
What if anything is used between the barges to buffer them and prevent metal-on-metal contact?
der kap - great idea for ballast!!!!!!
Old Aug 25, 2006, 11:15 AM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
Decide on type of barge as they vary so much depending on what kind of service they are seeing. River barges tend to be shallower than an ocean going ( can draft up to 30') . Some of the barges do have flat ends--depends on the usage. Good ratio for a barge is 4 to 1 for most applications. Build it to be handled like a barge so it should be able to handle abuse.
keith S is offline Find More Posts by keith S
