Old Aug 24, 2006, 10:26 PM
BigJetFan is offline
Find More Posts by BigJetFan
Joined Aug 2006
Question
Electric Conversion of Great Planes Venus 40 ARF
I just won a Venus 40 ARF at my club (San Fernando Valley RC Flyers)meeting and I am thinking of converting it to electric. I am considering one of the new E-flite glo sized outrunners, either the '46' or the '60'.
Has anyone out there converted this plane or does anyone have suggestions for a conversion? The wingspan is 55, area 568 sq. in. weight 4.8 to 5.3 pounds (glow).
BigJetFan is offline Find More Posts by BigJetFan
Old Aug 25, 2006, 05:54 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
AXI 4120/18, APC 12x10E prop, Castle Creations Phoenix 45, True RC 5S1P 4000mAh Li-Po battery.
Ken Myers is offline Find More Posts by Ken Myers
Old Aug 25, 2006, 08:31 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
There are a couple of LOOOOOoooooong threads on the E-Venus in the Sports Planes forum.
GregG is offline Find More Posts by GregG
Old Aug 26, 2006, 09:52 PM
davidsons is offline
Find More Posts by davidsons
davidsons's Avatar
Joined Feb 2004
I'm running a Hacker B50-13S (6.7:1 gear) with Tanic 5s 3650's and 15x10E prop. If you are going to use one of the Eflite outrunners and want to fly the Venus the way it's meant to be flown, you need to use the Power 60 on 6s with 15x10 or 16x8E prop and PHX 80 or equiv esc along with a UBEC or seperate battery for the rcvr....UBEC is lighter. The Power 46 will NOT cut it. By the way...this is a SWEET electric conversion and so far it's the best plane in my fleet. We'll see if my Fliton Inspire 60 changes that. One important note, if you go with the Power 60 you will be more nose heavy than the Hacker setup I'm running which is slightly nose heavy with no room for me to move the battery's back which are about the lightest candidates for the amp requirement. I had to add some lead to the tail. It flew pattern great a little nose heavy but it's much better with the cg closer to neutral...does an awesome blender into inverted flat spin. With that said, if I had it to do over, I would move the rudder and elevator servos to the tail so I did not have to add "dead" weight. With the Power 60, this will most likely be a must to get the cg correct. It may add some time to your build but I guarantee it will reward you in the air.
Look forward to hearing how this setup works out as it's about $100.00 less on the power setup. Please keep us posted.
Steve
davidsons is offline Find More Posts by davidsons
Old Aug 26, 2006, 10:24 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
BigJetFan,
My picks would be:
#1 Hacker B50 10L+5.2:1, TP 5S 2P 4000, 15x10 APC-E
#2 Hacker B50 13S+6.7:1, TP 5S 2P 4000, 15x10 APC-E
#3 Axi 4130/16, 6S 2P 4000, 15x10
#4 E Flight 60, TP 6S 2P 4000, 15x10
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Discussion My Great Planes Venus .40 Conversion Part 3 enigmabomb Sport Planes 709 Oct 06, 2011 04:00 PM
For Sale Great Planes Venus 40 with motor and radio belouder Aircraft - Fuel - Airplanes (FS/W) 3 Mar 08, 2007 06:42 PM
For Sale Great Planes Venus II ARF NIB Red Aircraft - Fuel - Airplanes (FS/W) 2 May 12, 2006 12:15 PM
For Sale Great Planes Spitfire 40 ARF wing only ncpiperpilot Aircraft - Fuel - Airplanes (FS/W) 1 Nov 27, 2005 07:37 PM
My Great Planes Venus .40 Conversion enigmabomb Sport Planes 499 Jun 05, 2004 01:16 PM
