A GWS pico receiver and around 3-4 gm servos would be much better. The Pico servos are 5.4gm, and the Spektrum receiver is a tank, for a plane like this.
The 12mm Feigos direct drive work well in these planes, with a lightweight ESC like a CC Tbird 9. I actuall got the FW190 to fly with that setup, at 5oz with the fuse sheeted, but its to difficult to fly at that weight. Really need to keep them at 4oz and under. Also need a batt that will meet the current demand of the motor. Many of the 250-350mah range start to fall off at 2.5-3A. I have a Hyperion Velicity Lite 3s-350 that is 1.25oz, a bit heavier than most that size, but can output an easy 7A, and is rated at 9, I believe. Bill |
I only have a spektrum tx, so I am stuck with it =/ Be nice if they made a 4CH version.
My motor is going to be much lighter than a Fiegao. My batteries will put out 5A continuous, which should be fine. I am hoping for a thrust to weight ration of higher than 1:1...should make things a bit more managable. High alpha "plop" landings might be possible. |
The Feigao is actually only 5 grams more than the little CDR. In any case, the model is overpowered with a 12mm GWs brushed fan motor and 2 cells,already. The Feigao would be maximum overkill. |
| Thread Tools | |
| Guillow's Thomas Morse Scout E-conversion started | craab | Scale Electric Planes | 44 | Jan 06, 2011 02:40 AM |
| Discussion Guillow's P-40 Rubber Power to Elec RC, Help! | arcticflyer | Indoor and Micro Models | 47 | Oct 07, 2006 05:22 AM |
| Guillow's CURTISS P-40 WARHAWK Conv. | justincgdick | Scale Electric Planes | 24 | Jun 03, 2005 08:05 AM |
| Article Hangar 9's Twist 40 ARF E-Conversion Review | Steven Horney | Electric Plane Talk | 7 | May 25, 2005 03:29 PM |
| Guillow's P-40 Conversion | herc75 | Scale Electric Planes | 14 | Nov 17, 2002 04:51 PM |
