This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Aug 26, 2006, 09:26 PM
RyanF is offline
Find More Posts by RyanF
RC Addict
RyanF's Avatar
Providence Village, TX
Joined Feb 2005
Originally Posted by spinnetti
For reference, this is about the same numbers I get for the SK400 on 2S..., and about what motocalc predicted for 2s also... Is there a Tower motor in this line that would give similar performance on 2s (my 4 blade only pulls 5A on 2s)?
A couple of this setup with a 2400 pack would be nuts in the P-38
Check out the TP 2410-18:
Configuration: Propeller: Volts: Amps: Thrust:
Direct Drive 1047 7.4V 9.7A 18oz / 510grams
Direct Drive 1050 11.1V 12.7A 25.3oz / 718 grams
Direct Drive 8040 14V 14.8A 31.1oz / 883 grams
specs
RyanF is offline Find More Posts by RyanF
Old Aug 26, 2006, 09:51 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
spinnnetti
The numbers I have for the 2210-12 star are
970 KV
0.37 Amp
0.615 ohms
2.1 oz Weight
But I have never tested a 2210-12 star to verify the parameters.
kensp is offline Find More Posts by kensp
Old Aug 26, 2006, 10:10 PM
jamesdr is online now
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Potential GWS-38 flyers -
I've been literally dreaming of this plane. The manuver is a BIG loop, with a Victory roll coming out, arching up to the left. But I don't see landing gear in my dreams! So the question is - do I want to make a ROG or belly lander? Your collective thoughts (or dreams?).
Jim
jamesdr is online now Find More Posts by jamesdr
Old Aug 26, 2006, 10:17 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
I am belly landing untill I can afford these.
http://www.rc-warbirds.com/product_i...roducts_id/330
Ken
Old Aug 27, 2006, 02:19 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Originally Posted by RAY GWS
Dear all & Eric,
.........................................3. As the power system or ESC, RDs are flying GWS38 every day. Trying to have the best recommendation for you. I will check with them on Monday to see if anything new.
Get one of them out there with a video camera please Ray
Roger Lombard is offline Find More Posts by Roger Lombard
Old Aug 27, 2006, 08:38 AM
spinnetti is offline
Find More Posts by spinnetti
SCCA, EAA, M.E.
spinnetti's Avatar
United States, TX, Frisco
Joined Nov 2001
Originally Posted by kensp
spinnnetti
970 KV
0.37 Amp
0.615 ohms
2.1 oz Weight
Thanks Ken...
You gonna belly land with 3 blade props, or just using 2 blade? Could be interesting...
I started making my own scale retracts for my FW... will be similar to the robarts big ones; take a shot at building your own.. its kinda fun...
(to stiffen the aluminum tube, I fill with probond/gorilla glue)
spinnetti is offline Find More Posts by spinnetti
Old Aug 27, 2006, 09:09 AM
rdeis is online now
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Jim
Make a ROG first, once it's trimmed out and flying nicely then pull the gear off.
rdeis is online now Find More Posts by rdeis
Old Aug 27, 2006, 09:22 AM
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
rdeis
That is an option. Hand launching on a maiden is always a gut turning event - you have 5' of altitude and virtlually no airspeed. I like those mini spring air retracts Ken. I may get those and fit them into my NPS GWS-38 (after I have worked the kinks out of the first one.)
Jim
Old Aug 27, 2006, 12:08 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Thanks Ken...
I plan to use the 9 x 7.5 two blader untill I get the retracts, then go to with 3 blade props.
Ken
Old Aug 27, 2006, 09:46 PM
SCCA, EAA, M.E.
spinnetti's Avatar
Joined Nov 2001
Ken
I tried to belly land my newly converted 109E --> 109G6 with a 3 blade prop today .. hmm didn't work so well, and popped a blade out (so I put landing gear on it). The 3 blader sure looks a lot better than the 2 blade
Old Aug 28, 2006, 12:33 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Woo hoo! Just got a confirmation email from Joyce that I am now an official Early Bird participant, and got the invitation to buy the P-38. Placing my order this week!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Aug 28, 2006, 02:53 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Pat
How long ago did you send in the application form?
kahloq is offline Find More Posts by kahloq
Old Aug 28, 2006, 03:15 AM
RAY GWS is offline
Find More Posts by RAY GWS
Joined Jul 2004
Will ask them to do so.
here are what they are trying. Will update you all.
Wing Span: 1200mm (47.2 in)
Wing Area: 19.9 dm2 (308.5 sq. in)
Length: 853mm (33.6 in)
Flying weight: 720g ~ 780g (25.4 oz~12.9 oz/sq ft)
Power system: GWS 2208~2212 BL motors /EPS300C~EPS350C or EPS400C
Propeller: GWS 8043, 8040HD/9047, 9050HD/1047, 1060HD (Pls check motor spec
for matched size)
Battery: 11.1V 1500mah 10C+ ~2200mah 6C+ Li-Po/ 9.6V 1500mah AA Ni-Mh
Receiver: GWS 6~8ch Receiver
Servo: NARO×4
Speed Controller: GWESC25~35A×2 for brushless motor/ICS400×2, ICS600/
ICS400LiX2, ICS600Li
RAY GWS is offline Find More Posts by RAY GWS
Old Aug 28, 2006, 12:30 PM
dogon1013 is offline
Find More Posts by dogon1013
Watts Rule, Glows Drool
dogon1013's Avatar
orlando, FL
Joined Mar 2003
Ray,
Are there gonna be 2 brushless options for the GWS38? one with 2208's, one with 2212's ?
I was only aware of the 2208 version.
dogon1013 is offline Find More Posts by dogon1013
Old Aug 28, 2006, 02:03 PM
Tanguy&Laverdure is offline
Find More Posts by Tanguy&Laverdure
France
Joined Aug 2005
I think GWS38 doesn't need brushless motors. They are too fast... Especially if we want scale performances.
Tanguy&Laverdure is offline Find More Posts by Tanguy&Laverdure
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
