This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Nov 26, 2006, 08:32 PM
dogon1013 is offline
Find More Posts by dogon1013
Watts Rule, Glows Drool
dogon1013's Avatar
orlando, FL
Joined Mar 2003
I always lean towards spoilerons, instead of flaperons.....no chance of inducing tip-stalling. But I have not tried it on the 38. It already seems to float very well and landings are no problem, plus there are flaps already molded in the wing so if you really wanted flaps, I would try them.
BTW, the Ultrafly ESC's I am using have a nice soft-cutoff feature. they actually pulse the motors before they hit cutoff, so you know it's coming, and then the cutoff startes with a reduction of power (It'll only let you get to about 50% power).
dogon1013 is offline Find More Posts by dogon1013
Old Nov 26, 2006, 08:50 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
dogon 1013
The GWS 15 Amp ESCs have a similar soft shut down. They reduce the throttle as they aprouch the shut down voltage. The ESC takes about 20 seconds to reduce the throttle from WOT to almost zero and then the ESC shuts down the throttle completely.
I think that this was a deliberate design philosophy by GWS as they are featuring a lot of twins now.
Ken
kensp is offline Find More Posts by kensp
Old Nov 26, 2006, 09:01 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
I seem to remember reading that you can control two brushless motors from one GWS vrushless esc. I couldn't do it with my E-Flite esc's. Haven't tried the GWS's yet. Before anyone jumps all over me I know that the best thing to do is use two esc's but I'm curious.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Nov 26, 2006, 09:14 PM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
From the pics of the underside of the wings, looks like the flap lines are nicely etched onto the underside of the wings. Won't it work better to put in one more servo and put the flaps in the scale location? I think it would work better too.
chewy
chewytm is offline Find More Posts by chewytm
Old Nov 26, 2006, 10:33 PM
Joined Jan 2004
chewy-- No doubt about it. Individual flaps would be better than flaperons as they'd leave full aileron throw for better control. This 38 has a pretty nice size wing and a good bit of area so I bet in can stand a bunch more grams in micro servos and controls for rudder and flap. That's five micro servos now R x 2/A/E/F.
Old Nov 26, 2006, 10:47 PM
chewytm is offline
Joined Jul 2006
I think you would need a park BEC due to the nos of servos or maybe drive different servos from the two different BECs. Unless your BECs can be paralleled like Castle claims.
I think the last time I used flaperons, it caused a tip stall in my Cessna 5 feet from the ground. Total wipe-out. The plane landed just fine without the flaperons. I tried it two or three times with the flaperons on and they were all disasters. I think flaperons are a no-no in most cases. Maybe I just had the plane too slow, but flaps are supposed to help in that case, not causing tip stalls.
chewy
Old Nov 27, 2006, 01:28 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
chewy
I beg to differ. When I use the flaperons on my Formosa II I do not have tip stall problems. But I do need a shotgun to get it to land as it just floats forever. The secret is to have full span ailerons and not to have a great deal of flap movement compared to aileron movement. My Formosa II also has Elevator Flap coupling .
Ken
Old Nov 27, 2006, 05:21 AM
Joined Jan 2004
On my P-47 the flaperons go down only about 3/16 to 1/2" or so. I'll try to measure it tonight. The trick is to get the nose down when you apply the flaps. Flaps steepen the descent without adding too much speed and less floating unless you add power. Tip stalling is from slowing too much.
Yes to the BEC for me.
Old Nov 27, 2006, 06:38 AM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
What's a good, inexpensive BEC to get?
Red 61 is offline Find More Posts by Red 61
Old Nov 27, 2006, 07:45 AM
CaptEvo is offline
Find More Posts by CaptEvo
CaptEvo's Avatar
Joined Jul 2004
Power Option
GWS-38 is on xmas wish list
I have 2 of these combo, do you think it'll work?
AM230811 Outrunner brushless motor + Jeti ECO 12 brushless controller
http://www.hobby-lobby.com/atlas2308.htm
Atlas 2308/11:
Motor weighs 43 grams (1-1/2 oz.), 28.5mm (1-1/8") diameter, 24.1mm (15/16") from back to front. Hardened 3.17mm (1/8") shaft with 2 ball bearings. Similar to PM220834
CaptEvo is offline Find More Posts by CaptEvo
Old Nov 27, 2006, 08:43 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
CaptEvo
Should work. HL says it is good for a 16oz plane and you are basically running two planes at around 15 oz each. Mine is on the heavy side at 36 oz. Just keep it on a diet when you build.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Nov 27, 2006, 11:03 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
ParkBEC. http://www.dimensionengineering.com/ParkBEC.htm
I have 4 of them, but I've never used them. I have several planes that have multiple servos in them(more then 3 or 4) and have never had issues. I use mostly e-flite esc's, but do have several 18amp CC's , 3 x 25amp CC, and 1 60 amp CC. I have 5 servos in my GWS38. Not all servos get activated or used all the time at any given time. The two for elevator function at the same time and so do the two for ailerons, but the nose wheel servo is not in use while flying, so for me anyhow...only 4 servos will be in use while in flight.
Most of my electrics have 4 servos and I do not use the PArkbec in any of them and these do use the rudder while in flight. The PArkBEC is nice tho if your worried or concerned. I bought the 4 simply because I was going to use them in my 78" electric powered B-17, but have since decided that I will simply use a separate battery for the rx/servos.
If you want, I'll sell you one of the ParkBEC's I have.
BTW, my GWS38 is setup where both BECs are functional...neither of them has had the red wire cut....these are 18 amp CC's and so far no issues.
kahloq is offline Find More Posts by kahloq
Old Nov 27, 2006, 11:40 AM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
.....Flaps steepen the descent without adding too much speed and less floating unless you add power. Tip stalling is from slowing too much.
If you reflex the ailerons up, instead of down (spoilerons) you also increase the drag which will steepen the descent, of course you do loose some lift, which is actually a benefit for a very floaty model like the 38. and since you are decreasing the AOA (angle of attack) at the tips, the tips will NEVER stall before inside of the wings, so you eliminate the possibility of a tip stall.
Like KenSP said, flaperons is OK for full span ailerons (like formosa), but the 38 has tip ailerons only, so using flaperons on it would increase tip-stalling likely hood.
BTW 2-ESC's with BEC's paralleled eliminates the need for a stand-alone BEC....And since this is a twin, that works out well. Castle ESC's and Ultrafly ESC's can be paralleled (I have the Ultrafly) without any issues. Other brands may work too.
Old Nov 27, 2006, 01:33 PM
L0stS0ul is offline
Find More Posts by L0stS0ul
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
I'm using the CC ThunderBird ECS's and I believe they do not recommend using the thunderbirds in parallel. When I did my power setup tests I had forgotten to take the pin out of one of them but quickly rectified that before the next test. Not going to chance an overload
L0stS0ul is offline Find More Posts by L0stS0ul
Old Nov 27, 2006, 01:44 PM
Red 61 is offline
Outcast outlaw
Joined Aug 2004
Okay, a couple of responses:
Cool -- you might have a deal if you also have a servo rate reducer you can throw into the deal. If not, I'll just order directly from their web site. (Thank you for the offer!)
While this may be true, one of the Castle Creations Phoenix 25 ESCs on my Flying Styro P-38 overheated simply because the BECs were connected in parallel... I started a thread about the issue in the Castle Creations forum -- the answer was that one BEC must dissipate the extra (unused by a servo) voltage as heat. I disconnected the second BEC, and it never overheated again.
So, it sounds like you can connect two CC Phoenix xx BECs in parallel, as long as you are actually USING enough (more than 4) servos. Otherwise, you are better off clipping the pin.
One final note -- I'm interested in the BEC because of a P-51 I am putting together... It will be "full house", with retracts (4 servos), and the Phoenix 25 is only rated for 3 servos on a 3s LiPo... (This is also why I'm interested in the servo rate reducer).
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
