This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Nov 03, 2006, 11:53 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Red
Are you using some type of inflight data collerctor - like an Eagletree datalogger? I got one a few weeks ago and have tried it once. It seemed to work but I did learn that to be truly effective you have to fly a predetermined profile consisting of time, throttle settings, etc otherwise you have a bunch of numbers and graphs with no correlation. (Was that at full throttle climb or down wind dive???)
Jim
jamesdr is offline Find More Posts by jamesdr
Old Nov 03, 2006, 12:15 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Originally Posted by Red 61
LOL -- no, I want less draw, less thrust, and MORE SPEED!
Ah, something for nothing then. Heh. Try going down to 7x7 then. You'll need a LOT less thrust to inprove both draw and speed.
...The above should yield 6.748 amps at WOT -- but I am getting closer to 11 amps...
8x8 prop is hard to simulate. It prolly doesn't account for the effects that only show up when pitch and diameter are close to the same.
Or you entered the wrong gear ratio
rdeis is offline Find More Posts by rdeis
Old Nov 03, 2006, 12:56 PM
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
Honestly though, I'm confused, because the electric motor calculator web site I use has never been wrong before -- this time it was waaaaay off! Color me surprised...
Thunder Power 2100 mAh 3-cell LiPo
Himax 2025-4200
5.67:1 gear ratio
8x8 APC prop
No biggie -- I'll figure out something!
Very strange. If you use the E-Flite Park 400 instead, everything else the same, result is 8.08A. These are just about the same motor, so I think the constants for the Himax are way off base. Even the E-Flite numbers seem a bit low. Wonder what Motocalc would show?
10Thumbs is offline Find More Posts by 10Thumbs
Old Nov 05, 2006, 12:08 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
While we are talking Me262 Early Birds, may be GWS should order a new larger box which able to contain P38 together with very little increase of the EMS charge!
I know there are so many flyers missed P38 Early Birds programe, last time we only run samll qty foam shot then we trim the tooling mode.
You can place order of GWS38 to be together with GWS262!
How do you think?
Wish this help a lot of GWS flyers who love GWS38.
You can have both of them before Christmas!
You can receive kits at mid of Nov. 2006.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Nov 05, 2006, 09:48 AM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
That sounds great but were already a week into november. TO recieve them by mid november we'd have to order them in the next few days and have them shipped out very quickly. I'm getting excited to see the 262 and would consider the 38 if the cost was okay.
Vintauri is offline Find More Posts by Vintauri
Old Nov 05, 2006, 10:45 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Originally Posted by GWS4CEO
While we are talking Me262 Early Birds, may be GWS should order a new larger box which able to contain P38 together with very little increase of the EMS charge! ..............................
The price to ship one 262 to the UK was $40, the price Joyce gave me to ship 3 in the same box was nearly $90 so I don't see how putting a 38 and a 262 in one box is going to result in "very little increase in the EMS charge" Mr Lin - you might want to check that again.
Roger Lombard is offline Find More Posts by Roger Lombard
Old Nov 05, 2006, 10:58 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
I know usually, first 500g cost you very unreasonable high to cover the basic charge of paper work.
But what I really means is using a larger volume box, the surface of the carton will not increased as volume, while the kit foam pcs not so heavy!
Old Nov 05, 2006, 04:58 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Finally Maidened
I finally got White Lightnin' in the air. Bottom line up front - SUCCESS !
White Lightnin' is glassed with WBPU and tissue paper, painted with Apple Barrel acrylics (airbrushed). She is meant to resemble Lefty Gardner's White Lightnin' that used to be on the air race circuit. Anyway - here are the numbers:
GWS38 kit
2 HS55's for ailerons, a GWS Naro for the elevator
HiTec 05S receiver
2 TowerPro 2409-12 BL motors
2 TowerPro 15A ESCs
APC 8*4 props
CommonSenseRC 2100mAh 15c battery
All up weight minus the battery is right at 30 oz.
D/R set to 40% ailerons, 50% elevator
Expo is 60% ailerons, 50% elevator
CG is at 60mm.
Today was a warm November day with light to calm winds. I checked all the control surfaces (several times). Since she is a belly lander, I had Wannabe give her a throw. I throttled up to about 80% and gave the go ahead. In the post brief, he said she basically flew out of his hands - plenty of power! She climbed up easily and need just a bit of down and right trim. She cruised easily at 60%, looped from level flight with big loops at 80% and has a very nice axial roll to the right and left. I made a few full throttle high speed, low passes with a pull-up and turn - Man, what a sight! The sound of the twins was great! She slows nicely and doesn't have any nasty fall off at low speed other than just loosing altitude quick. I have flaperon's mixed but for the maiden, keep them stowed ways - maybe next time. Four minute alarm sounds on the transmitter and it's time for home. One low pass to line up, an easy turn to final and she landed perfectly on the little patch of ground tarp we call home. I was beaming! She's a keeper.!!!
Flight duration 4:36. Battery pack temp was just right. With 11.17v remaining, it took one hour to recharge the battery - I put 2100mAh back into the battery.
Jim
Old Nov 05, 2006, 06:28 PM
Jagzilla is offline
Find More Posts by Jagzilla
I fly for Beer
Jagzilla's Avatar
Chilliwack, B.C. Canada
Joined Sep 2004
Way to go, Jamesdr!! It looks great, and sounds like it performs well for you. I'm happy for you.
Jag
Jagzilla is offline Find More Posts by Jagzilla
Old Nov 05, 2006, 06:36 PM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
Sweet paint scheme, Jamesdr!
Red 61 is offline Find More Posts by Red 61
Old Nov 05, 2006, 06:48 PM
rudedog is offline
Find More Posts by rudedog
CAN WE MAKE IT FLY?????
rudedog's Avatar
Concord,N.C.
Joined Oct 2003
nice looking bird,and balanced out @ 60mm too sweet
rudedog is offline Find More Posts by rudedog
Old Nov 05, 2006, 07:22 PM
dogon1013 is offline
Find More Posts by dogon1013
Watts Rule, Glows Drool
dogon1013's Avatar
orlando, FL
Joined Mar 2003
Did it seem nose-heavy at 60mm CG? I know some people have brought the CG back to 90mm with good results.
dogon1013 is offline Find More Posts by dogon1013
Old Nov 05, 2006, 07:25 PM
Scoobyvroom is offline
Find More Posts by Scoobyvroom
Jack of all trades!
Scoobyvroom's Avatar
Rockford, MN
Joined Jul 2003
Gws P-38
Well I maiden the 38 today, set CG right at 60mm and she flew super nice. Great addition to the fleet. Only thing I wished was that the nose gear had the spring portion in it. On the last landing of the night I landed kind of close to the edge of the field and the nose gear dug in on a burm and bit it. Ripped the nose gear right out. Other than that, she is a really great flyer, in loops even witht he one sided elevator pushrod loops were nice and straight. Wind was low maybe 5-10mph and handle it fine. The 38 is nice with a little extra weight, compared to the rest of the GWS line up.
Setup
ESC 2x Himodel 18amp ESC
Battery 1x E3 10c 2200mah 11.1v Lipo
Servos 2xGWS pico 2XBluebird 306
RX Berg micro 4L
Motors Tower pro 2409-18 Star
Prop 2xGWS 8x6
Static testing
WOT 18amps
Scoobyvroom is offline Find More Posts by Scoobyvroom
Old Nov 05, 2006, 08:04 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
dogon
I did not notice any nose heaviness although the only time I was inverted was looping/rolling. Next time out I'll try inverted and see how much conpensating elevator I need to maintain aititude.
Scooby
Congrats!
Jim
Old Nov 05, 2006, 08:12 PM
MERLIN V16 is offline
Find More Posts by MERLIN V16
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
James and Scooby
congratulations on your flights. Both planes look exceptional!
Merlin
MERLIN V16 is offline Find More Posts by MERLIN V16
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
