This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Oct 25, 2006, 02:20 PM
Fiasco is offline
Find More Posts by Fiasco
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
[QUOTE=kahloq]
Originally Posted by Fiasco
If you have two programmable mixes on your radio,
Mix 1: throttle master to rudder slave
Mix 2: rudder master to throttle slave
QUOTE]
Not enough mixes for differential throttle. Requires 3.
And yes, diff thrust is useable in the air, steerable nosewheel is not. I wanted to do it just to have some semblance of rudder for cross wind landings.
Using two mixes as described above is exactly how I have differential thrust on my GWS A-10 set up.
Fiasco is offline Find More Posts by Fiasco
Old Oct 25, 2006, 02:47 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
[QUOTE=kahloq]
QUOTE]
Only if you want the nosewheel steering as well. Plug one ESC to throttle, the other one to rudder, and use the mixes above.
The nosewheel is harder, and does indeed take 3 mixes. Try this:
Mix rudder 100% to channel 5, (probably with 50% offset). This should have channel 5 mirroring the rudder channel exactly.
Then mix CH5 to throttle and throttle to CH5. ESCs go in 5 and throttle, nosegear still goes in the rudder channel.
If you can disable the gear switch (I can assign it to another function, for example), then do. Bumping that switch in flight would be very bad...
rdeis is offline Find More Posts by rdeis
Old Oct 26, 2006, 03:43 PM
cincy is offline
Find More Posts by cincy
Plane Crazy
cincy's Avatar
Cincinnati, OH
Joined Feb 2003
Nice pics. Boards sure have quieted down a bunch after the initial earlybird rush. Any word on shipments of these to hobby stores in the US? Horizon Hobby is showing early November availability. Tower hobbies shows mid November (and is 6 dollars cheaper too!)
cincy is offline Find More Posts by cincy
Old Oct 26, 2006, 04:07 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I would say first shipments should be on LHS shelves by Thanksgiving at the latest. But, be sure that these initial shipments will most likely sell out fast. I would talk to an LHS owner who has these ordered, and ask them to call you as soon as they come in.
We're having a large fly-in here at the end of January. I convinced one of the LHS owners to order a supply of these kits and offer them for sale during the show. There are two of us with P-38s signed up as pilots for the show, so we will be showing them off. He'll probably sell out the first day.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Oct 26, 2006, 04:12 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Now that we have them in hand, we're too busy building and flying to do much talking!
In fact, I have a second one that I need to finish up tonight for a friend.
Pat
Old Oct 26, 2006, 05:13 PM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
I don't have mine in hand yet!
I have been wondering about the tail of the GWS-38... I know there's some kind of piece at the tail which makes the tail removable for transportation -- is there a modification which makes it more permanent (both stronger and nicer looking)?
Thanks!
Red 61 is offline Find More Posts by Red 61
Old Oct 26, 2006, 05:45 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Guy,
The tailplane simply slides into slots in the vertical stab. The vert stab has small plastic "tabs" that protrude inwards, and rest on the top and bottom of the tailplane. The bottom tab has a nut and you simply secure everything together with a single screw.
For a more permanent installation, leave the tabs off and just epoxy the tailplane into the vert stab slots, and then fill in the gaps. I have a kit that is disassembled at home and will take pics of it tonight to show you what I'm describing.
Pat
Old Oct 26, 2006, 06:29 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Dear Early Birds who own the test production GWS38 on hand,
Would you like to send you videos to GWS to be add on video links?
Send to: Debby@gws.com.tw
GWS4CEO is offline Find More Posts by GWS4CEO
Old Oct 26, 2006, 06:30 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Thanks!
Ooops!
What's happening?
Old Oct 26, 2006, 07:24 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
[QUOTE=Fiasco]
Uhhh ok but what radio you using? And do you have both motors following throttle stick too?
kahloq is offline Find More Posts by kahloq
Old Oct 26, 2006, 07:58 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Originally Posted by GWS4CEO
Ooops!
What's happening?
Mr Lin, I don't think he ordered as an earlybird.
Pat
Old Oct 26, 2006, 08:19 PM
Red 61 is offline
Outcast outlaw
Joined Aug 2004
Ooops!
What's happening?
Joyce sent me an e-mail saying she would have GWSUSA take care of it. That's the last I heard of the GWS-38.
Originally Posted by crxmanpat
Here's pics to go along with my post #773.
Got it -- thanks for the pics! That looks like an easy modification -- no where near as difficult as I expected.
Old Oct 26, 2006, 09:49 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
For the results of my first test flight with diferential thrust activated see
Single post
Entire thread
Ken
kensp is offline Find More Posts by kensp
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
